Installation & Licensing
Message 1 of 18
5531 Views, 17 Replies
Installation error.
I'm trying to install AutoCAD on Windows 7 64-bit. I've shut all background programs off and even tried to install 32 bit. I keep getting an error:
CRC failed in x86\acad\Program Files\Root\Inventor Server\Bin\JtTk56.dll
Unexpected end of archive
17 REPLIES 17
Message 2 of 18
hashim.mundol
If its from DVD/USB please try to copy the install files locally. (c:\)
If you it's from a download, please try another download without Antivirus or any other security software enabled, may be using another browser.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 18
ablespr
I'm having this same problem I uninstalled AVG, I turned off my firewalls, I used mozilla and I tried internet explorer. I still can't download it please help!! I have superantispyware thats it for spyware could that affect it?
Message 4 of 18
Is there any solution for such a problem?
Autodesk_3ds_Max_Entertainment_Creation_Suite_Premium_2012_English_Win_32bit.exe: CRC failed in x86\Softimage\Data1.cab.The file is corrupt
3rdParty\DirectX\Dec2005_d3dx9_28_x86.cab. The file is corrupt
3rdParty\DirectX\DEC2006_d3dx10_00_x86.cab. The file is corrupt
 3rdParty\DirectX\DEC2006_d3dx9_32_x86.cab. The file is corrupt
3rdParty\DirectX\DEC2006_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\dxnt.cab. The file is corrupt
3rdParty\DirectX\dxupdate.cab. The file is corrupt
 x86\max\ETransmitGlob.cab. The file is corrupt
3rdParty\DirectX\Feb2005_d3dx9_24_x86.cab. The file is corrupt
 3rdParty\DirectX\Feb2006_d3dx9_29_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2006_XACT_x86.cab. The file is corrupt
 3rdParty\DirectX\FEB2007_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2010_X3DAudio_x86.cab. The file is corrupt
 3rdParty\DirectX\Feb2010_XAudio_x86.cab. The file is corrupt
x86\max\IGES_SAT_STEP_ALIASCommon.cab. The file is corrupt
x86\max\IGES_SAT_STEPTranslator.cab. The file is corrupt
x86\max\InventorServerAM.cab. The file is corrupt
 x86\max\InventorServerFW.cab. The file is corrupt
 x86\max\InventorServerFWLoc.cab. The file is corrupt
 x86\max\InventorServerPM.cab. The file is corrupt
x86\max\InventorServerPMLoc.cab. The file is corrupt
3rdParty\DirectX\Jun2005_d3dx9_26_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2006_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_d3dx10_34_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_d3dx9_34_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_d3dx10_38_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_X3DAudio_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_XAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_D3DCompiler_43_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_d3dcsx_43_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_d3dx10_43_x86.cab. The file is corrupt
 3rdParty\DirectX\Jun2010_d3dx11_43_x86.cab. The file is corrupt !
3rdParty\DirectX\Jun2010_XAudio_x86.cab. The file is corrupt
x86\max\LiveUpdate.cab. The file is corrupt
x86\max\LTU_x86_release.cab. The file is corrupt
x86\Mudbox\LTU_x86_release.msm.cab. The file is corrupt
3rdParty\DirectX\Mar2008_d3dx10_37_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2008_X3DAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2008_XAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2009_d3dx10_41_x86.cab. The file is corrupt
Tags (1)
Message 5 of 18
hashim.mundol
If it's a downloaded file, please disable all the security softwares (Antivirus,Antispyware etc.)
use another browser to download.
if it's media please request for a replacement media, if copying the files locally doesn't work.
Hashim Mundol
Autodesk, Inc.
Message 6 of 18
hashim.mundol
in reply to: ablespr
some more tips here
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
you should try to disable antispyware too.
Hashim Mundol
Autodesk, Inc.
Message 7 of 18
ablespr
I used mozilla, internet explorer I removed avg turned off my firewall and closed my super antispyware and downloaded microsoft.net 4.0 still cannot get it to work??
Message 8 of 18
hashim.mundol
Have you tried to download the trial version ?
with or without download manager ?
if you are not a student you could order for a replacement media.
Hashim Mundol
Autodesk, Inc.
Message 9 of 18
ablespr
could you give me a link for the trial also what is download manager?
Message 10 of 18
I'm on my second DVD disk bundle from our reseller and having the same issue with Windows 7 32-bit and 64-bit.  Tried CMD console and copying with Robocopy as well.  Stops on dxnt.cab with CRC error 23, 0x00000017.  No antivirus is installed, Windows Defender is disabled.  Any other suggestions?
Message 11 of 18
hashim.mundol
Please try to download the file or copy using an DVD reader (over the network)
This file should be intact on the DVD else we would have had lots of issues reported by customers.
Hashim Mundol
Autodesk, Inc.
Message 12 of 18
What do you mean by "DVD reader"?
Message 13 of 18
If you mean inserting the DVD disk into a DVD reader device (tray) that's all I've done. Tried running setup from that directly, then tried to copy the DVD content to the hard drive and run from there. Neither works. Still get the CRC error
Message 14 of 18
hashim.mundol
No, I meant another DVD drive on another machine.
Or if you have an external DVD reader.
We need to isolate the issue with your DVD drive itself.
Hashim Mundol
Autodesk, Inc.
Message 15 of 18
in reply to: hashim.mundol
Well dang.  It was indeed the DVD drive. Thank you. 🙂
Message 16 of 18
Tras haber descargado el archivo (1,96 Gb):
Autodesk_Robot_Structural_Analysis_Professional_2012_Multilingual_Win_32-64bit
intento descomprimirlo para comenzar la instalación pero aparece el siguiente error:
Error
Some installation files are corrupt.
Please download a fresh copy and retry the installation.
CRC failed in x64\RSA\RSA_FOLDER\System\Exe\Beam1.exe
Espero respuesta. Gracias.
Message 17 of 18
TravisNave
Error
Problemas al descargar el software de Autodesk y / o errores de CRC se pueden evitar mediante el uso de otro navegador web, o utilizando el método de descarga navegador alternativo.
Para obtener información más detallada sobre este proceso, consulte el siguiente blog consejo aquí:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download-manager.html
Yo recomendaría que trate de descargar su producto con Matt, el asistente virtual siguiendo las instrucciones aquí:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Autodesk Forums:
Message 18 of 18
dmsc1967
Administrator Productivity
