Installation & Licensing
TravisNave
Message 11 of 17 (644 Views)
Re: Installation error: 1606. Could not access network location setup
06-10-2013 08:34 AM in reply to: 3bplanproje
There's always a log.  Even on failed installs.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Distinguished Contributor
Message 12 of 17 (640 Views)
06-10-2013 09:35 AM in reply to: 3bplanproje
To get access to the temp files, open windows explorer and type %temp% in the address box and hit enter. This will take you to the temp directory. Sort the files by "Date Modifed" and you should see the log files.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
TravisNave
Message 13 of 17 (637 Views)
06-10-2013 09:40 AM in reply to: Darin.Green
Thanks Darin.  I have been debating making an article describing these steps as well, since it is generally a common occurrence here.
Message 14 of 17 (632 Views)
06-10-2013 09:44 AM in reply to: 3bplanproje
Although we don't have the log files, it appears the issue is related to user directories being mapped to different locations. To check this, navigate within the registry to the following key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
If any of these paths are pointing to a different location other than the defaults begining with %USERPROFILE% then that would explain the issue. Change the modified path to the defaults which you can find attached:
Darin Green
Member
Message 15 of 17 (620 Views)
06-10-2013 10:03 PM in reply to: cookml
These are my log files
Member
Message 16 of 17 (584 Views)
06-17-2013 05:56 AM in reply to: 3bplanproje
I sent the log files last week
I am waiting solution for this problem
Message 17 of 17 (580 Views)
06-17-2013 06:15 AM in reply to: TravisNave
Log out and log in with the Administrative account and try the installation again.
Darin Green
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
