Hi. So I'm a student and I've been trying to install Maya multiple times and it gives me an error immediately upon starting the install. Here is the error log. Any help would be appreciated. I've deleted my temp folder
2014/4/19:20:48:18 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:20:48:18 Rob *** TITAN Path_Length: 143
2014/4/19:20:48:18 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:20:48:18 Rob *** TITAN Launch
2014/4/19:20:48:18 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:20:48:18 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI4D64.tmp
2014/4/19:20:48:35 Rob *** TITAN === Setup ended ===
2014/4/19:20:48:21 Rob *** TITAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:20:48:34 Rob *** TITAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:20:48:35 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:20:48:46 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:20:48:46 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:20:48:46 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:20:48:53 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:20:48:53 Rob *** TITAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:20:48:57 Rob *** TITAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:20:48:57 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:20:49:37 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/19:20:49:38 Rob *** TITAN Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:20:49:43 Rob *** TITAN Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:20:49:43 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/19:20:50:13 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/19:20:50:13 Rob *** TITAN Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:51:25 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:52:58 Rob *** TITAN Download User Resume DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:53:29 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:53:32 Rob *** TITAN Download User Resume DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:54:02 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:55:53 Rob *** TITAN Download User Resume DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:56:23 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:56:52 Rob *** TITAN Download User Resume DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:57:33 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:57:41 Rob *** TITAN Download User Resume DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:58:12 Rob *** TITAN Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:58:15 Rob *** TITAN Download User Cancel DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:58:15 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:20:58:15 Rob *** TITAN Download Aborted DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/19:20:58:21 Rob *** TITAN === Setup ended ===
2014/4/19:20:59:42 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:20:59:42 Rob *** TITAN Path_Length: 143
2014/4/19:20:59:42 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:20:59:42 Rob *** TITAN Launch
2014/4/19:20:59:42 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:20:59:42 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIBFD5.tmp
2014/4/19:20:59:45 Rob *** TITAN === Setup ended ===
2014/4/19:20:59:43 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:20:59:43 Rob *** TITAN Path_Length: 143
2014/4/19:20:59:43 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIBFD5.tmp
2014/4/19:20:59:43 Rob *** TITAN Launch
2014/4/19:20:59:43 Rob *** TITAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:20:59:43 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:20:59:49 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:20:59:49 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:20:59:49 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:20:59:59 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:20:59:59 Rob *** TITAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:20:59:59 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:20:59:59 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/4/19:20:59:59 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:21:00:05 Rob *** TITAN === Setup ended ===
2014/4/19:21:02:44 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:02:44 Rob *** TITAN Path_Length: 143
2014/4/19:21:02:44 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:02:44 Rob *** TITAN Launch
2014/4/19:21:02:44 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:21:02:44 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI8526.tmp
2014/4/19:21:02:47 Rob *** TITAN === Setup ended ===
2014/4/19:21:02:45 Rob *** TITAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:02:45 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:02:50 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:02:50 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:02:50 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:02:59 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:21:02:59 Rob *** TITAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:02:59 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:21:02:59 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/4/19:21:03:00 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:21:03:19 Rob *** TITAN === Setup ended ===
2014/4/19:21:03:49 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:03:49 Rob *** TITAN Path_Length: 143
2014/4/19:21:03:49 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:03:49 Rob *** TITAN Launch
2014/4/19:21:03:49 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:21:03:49 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI8507.tmp
2014/4/19:21:03:54 Rob *** TITAN === Setup ended ===
2014/4/19:21:03:50 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:03:50 Rob *** TITAN Path_Length: 143
2014/4/19:21:03:50 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI8507.tmp
2014/4/19:21:03:50 Rob *** TITAN Launch
2014/4/19:21:03:51 Rob *** TITAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:03:51 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:03:56 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:03:56 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:03:56 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:03:57 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:21:03:57 Rob *** TITAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:03:57 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:21:03:58 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/4/19:21:03:58 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:21:04:27 Rob *** TITAN === Setup ended ===
2014/4/19:21:04:44 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:04:44 Rob *** TITAN Path_Length: 143
2014/4/19:21:04:44 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:04:44 Rob *** TITAN Launch
2014/4/19:21:04:44 Rob *** TITAN CommandLine
2014/4/19:21:04:44 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI5ACC.tmp
2014/4/19:21:04:47 Rob *** TITAN === Setup ended ===
2014/4/19:21:04:45 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:04:45 Rob *** TITAN Path_Length: 143
2014/4/19:21:04:45 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI5ACC.tmp
2014/4/19:21:04:45 Rob *** TITAN Launch
2014/4/19:21:04:48 Rob *** TITAN === Setup ended ===
2014/4/19:21:05:20 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:05:20 Rob *** TITAN Path_Length: 143
2014/4/19:21:05:20 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:05:20 Rob *** TITAN Launch
2014/4/19:21:05:20 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:21:05:20 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIE771.tmp
2014/4/19:21:05:34 Rob *** TITAN === Setup ended ===
2014/4/19:21:05:21 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:05:21 Rob *** TITAN Path_Length: 143
2014/4/19:21:05:21 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIE771.tmp
2014/4/19:21:05:21 Rob *** TITAN Launch
2014/4/19:21:05:22 Rob *** TITAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:05:34 Rob *** TITAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:05:34 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:05:40 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:05:40 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:05:40 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:05:41 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:21:05:42 Rob *** TITAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:05:46 Rob *** TITAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:05:46 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:21:05:47 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/4/19:21:05:47 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:21:05:53 Rob *** TITAN === Setup ended ===
2014/4/19:21:08:39 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:08:39 Rob *** TITAN Path_Length: 143
2014/4/19:21:08:39 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:08:39 Rob *** TITAN Launch
2014/4/19:21:08:39 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:21:08:39 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIF23B.tmp
2014/4/19:21:08:52 Rob *** TITAN === Setup ended ===
2014/4/19:21:08:40 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:08:40 Rob *** TITAN Path_Length: 143
2014/4/19:21:08:40 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AIF23B.tmp
2014/4/19:21:08:40 Rob *** TITAN Launch
2014/4/19:21:08:41 Rob *** TITAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:08:52 Rob *** TITAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:08:53 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:08:58 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:08:58 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:08:58 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:08:59 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:08:59 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:08:59 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:09:00 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:09:00 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:09:08 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:09:08 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:09:12 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:09:12 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:09:12 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:09:14 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:21:09:15 Rob *** TITAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:09:19 Rob *** TITAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:09:19 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:21:09:19 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/4/19:21:09:19 Rob *** TITAN PageOpen InstallCompleteDialog
2014/4/19:21:11:15 Rob *** TITAN === Setup ended ===
2014/4/19:21:17:42 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:17:42 Rob *** TITAN Path_Length: 143
2014/4/19:21:17:42 Rob *** TITAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/19:21:17:42 Rob *** TITAN Launch
2014/4/19:21:17:42 Rob *** TITAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-44943795 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:21:17:42 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI3AFD.tmp
2014/4/19:21:17:58 Rob *** TITAN === Setup ended ===
2014/4/19:21:17:44 Rob *** TITAN === Setup started on TITAN by Rob *** ===
2014/4/19:21:17:44 Rob *** TITAN Path_Length: 143
2014/4/19:21:17:44 Rob *** TITAN Current Directory C:\Users\ROB***~1\AppData\Local\Temp\_AI3AFD.tmp
2014/4/19:21:17:44 Rob *** TITAN Launch
2014/4/19:21:17:45 Rob *** TITAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:17:57 Rob *** TITAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/19:21:17:58 Rob *** TITAN PageOpen LaunchDialog
2014/4/19:21:18:03 Rob *** TITAN PageOpen LicenseDialog
2014/4/19:21:18:03 Rob *** TITAN PageOpen ProductInfoDialog
2014/4/19:21:18:03 Rob *** TITAN PageOpen ProductSelectionDialog2
2014/4/19:21:18:05 Rob *** TITAN PageOpen FullProgressDialog
2014/4/19:21:18:05 Rob *** TITAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:18:09 Rob *** TITAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/19:21:18:09 Rob *** TITAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/19:21:18:10 Rob *** TITAN Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
Solved by robwiese149. Go to Solution.
Nevermind. It finally installed after a simple reboot and downloading via web browser. Go figure.
Hi.
I'm also a student and I'd like to proceed with this topic.
I'm stuck with this problem but while trying to install Revit Architecture 2015 R2.
Heres goes my log file:
"2015/3/11:18:17:29 Rodrigo *** === Setup started on *** by Rodrigo ===
2015/3/11:18:17:29 Rodrigo *** Path_Length: 155
2015/3/11:18:17:29 Rodrigo *** Current Directory C:\Users\Rodrigo\AppData\Local\Tmp\_AIDB10.tmp
2015/3/11:18:17:29 Rodrigo *** Launch
2015/3/11:18:17:29 Rodrigo *** Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Rodrigo\AppData\Local\Tmp\_AIDB10.tmp\Setup\RevitSetup.dll
2015/3/11:18:17:29 Rodrigo *** Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/3/11:18:17:32 Rodrigo *** PageOpen LaunchDialog
2015/3/11:18:17:34 Rodrigo *** PageOpen LicenseDialog
2015/3/11:18:17:40 Rodrigo *** PageOpen ProductInfoDialog
2015/3/11:18:17:57 Rodrigo *** PageOpen ProductSelectionDialog2
2015/3/11:18:18:23 Rodrigo *** PageOpen FullProgressDialog
2015/3/11:18:18:23 Rodrigo *** Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Users\Rodrigo\Downloads\Autodesk_Revit_2015_Brazilian_Portuguese_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2015/3/11:18:18:24 Rodrigo *** Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546"
I've downloaded it with the Autodesk Download Manager.
I've tried to install this package from Microsoft's web site but still didn't work either. It simply keeps asking me to reboot before installing but even after rebooting it gives me the same "reboot" message.
What can assure me that if I download via browser I won't have the same problem again?
Thanks for any help.
