Dear support team
I have installed a network admin image and trying to intall from the share drive. the License server is installed and the service is running too. but at the step of autocade mechanics 2011 the installation fails and gets roll back.
Is there a repository of the error coders in installation. also how to slove the issues.
=== Setup started on xxxxxx by xxxxxx ===
2010/6/30:09:14:07 Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2010/6/30:09:14:12 Install Autodesk Design Review 2011 Failed Failure is ignored, Result=1603
2010/6/30:09:18:23 Install .NET Framework 2.0 SP2 Update KB958481 Succeeded
2010/6/30:09:19:44Install .NET Framework 3.0 SP2 Update KB958483 Succeeded
2010/6/30:09:20:17 Install .NET Framework 3.5 SP1 Update KB958484 Succeeded
2010/6/30:09:21:00 Install DirectX 9.0 Runtime Succeeded
2010/6/30:09:21:19 Install FARO LS 1.1.406.58 Succeeded
2010/6/30:09:23:44 Install Autodesk Material Library 2011 Succeeded
2010/6/30:09:26:13 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/6/30:09:26:27 Install AutoCAD Mechanical 2011 Failed Installation aborted, Result=1603
2010/6/30:09:27:45 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/6/30:09:29:38 Rollback Autodesk Material Library 2011 Succeeded
2010/6/30:09:29:40 Rollback FARO LS 1.1.406.58 Succeeded
2010/6/30:09:29:40 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/6/30:09:29:40 Rollback .NET Framework 3.5 SP1 Update KB958484 Failed Failure is ignored, Result=1619
2010/6/30:09:29:40 Rollback .NET Framework 3.0 SP2 Update KB958483 Failed Failure is ignored, Result=1619
2010/6/30:09:29:40 Rollback .NET Framework 2.0 SP2 Update KB958481 Failed Failure is ignored, Result=1619
2010/6/30:09:29:41 Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
Try this solution:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11783943&linkID=9240617
Hope help!
Dear support
Team thanks and it help to certain extend by checking different settings and also the UNC share requriement.
