I use windows though bootcamp on a macbook pro.
Impression 3 will not install because it says that my graphics card is not good enough. See the attached image.
My graphics card is a AMD Radeon HD 6750M which I know should be powerful enough to run this software.
Solved by david.lau. Go to Solution.
If you are in Windows mode, I would update your graphics driver. This will be tricky because Apple controls the updates for them.
https://discussions.apple.com/thread/2806376?start=0&tstart=0
