Installation & Licensing
Distinguished Contributor
Message 1 of 9 (894 Views)
INV Pro 2012 install fail
894 Views, 8 Replies
05-02-2011 07:25 PM
I was able to install AMCAD from Product Design Suite Ultimate but not INV. During installation, setup does not find Web Services Enhancements (WSE) 3.0.msi so I have to browse to it manually. Each time, setup fails at this point:
Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Failed Installation aborted, Result=1612
Any suggestions?
TravisNave
Message 2 of 9 (882 Views)
Re: INV Pro 2012 install fail
05-03-2011 07:43 AM in reply to: mooresk257
Try downloading and installing it separate from your Autodesk installation and see if it still fails on install from Microsoft.
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=018a09fd-3a74-43c5-8ec1-8d789091255d
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Contributor
Message 3 of 9 (850 Views)
05-10-2011 09:15 AM in reply to: mooresk257
I had this same issue.  Autodesk believes it is an issue when a machine has multiple mapped network drives to the machine.  They explained it to me, but still doesn't make sense.
However, this should resolve the issue for you.
  1. Copy media to local machine
  2. Edit "Setup.ini" and remove the WSE 3.0 prerequisite for Inventor and Vault depending on what you are installing.
  3. Save "Setup.ini"
  4. Run "Setup.exe" and continue with install
TravisNave
Message 4 of 9 (844 Views)
05-10-2011 10:54 AM in reply to: mdurst
Yes, that is a work around for installation that would work.  However, without WSE properly installed you might have problems with your content center, vault, etc.
Active Contributor
Message 5 of 9 (842 Views)
05-10-2011 11:03 AM in reply to: TravisNave
Yes that is correct.  With the testing I did, WSE 3.0 was installed properly on the machine.  I uninstalled and reinstalled it manually thinking the Inventor 2012 installer wasn't seeing it as installed.  Even though it was installed correctly the Inventor 2012 installer still thought it wasn't and kept trying to install it which is where it would fail.
So like TravisNave said, make sure WSE is installed on your machine properly.
TravisNave
Message 6 of 9 (839 Views)
05-10-2011 11:07 AM in reply to: mdurst
Excellent.  Thanks for the follow-up!
Member
Message 7 of 9 (311 Views)
12-21-2012 06:49 AM in reply to: mooresk257
i get this one too
i try install inventor pro 2012 on windows 8
2012/12/21:20:39:26    ACW    UZDEROS    Installing Microsoft Visual C++ 2010 Redistributable (x86): G:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\ACW\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/21:20:39:33    ACW    UZDEROS    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Succeeded
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {8D20B4D7-3422-4099-9332-39F27E617A6F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {55D9E026-DCB0-46FF-B60A-68B972228CF6}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {450063AA-643B-417C-8CF5-405BA3F4EF40}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {106EC844-9F5E-4B72-BB3B-1E47D274A944}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {FACF203E-0F4D-489A-B80C-D185253C8FCB}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1A2948E0-9445-42BE-9D01-472952F2657F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {9A346205-EA92-4406-B1AB-50379DA3F057}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {C46C3C20-039E-4D7C-869F-9C0C05D65C06}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {577D60CB-0D5E-48D1-8850-84098AD34804}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {0576A3D0-0000-0409-0000-491C453655D7}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {4780F600-0000-0409-0000-114715ACF216}    Failed
2012/12/21:20:39:34    ACW    UZDEROS    Installing Autodesk® Design Review 2012:   INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\"  ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:00    ACW    UZDEROS    Install    Autodesk® Design Review 2012    Succeeded
2012/12/21:20:40:00    ACW    UZDEROS    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:19    ACW    UZDEROS    Install    Autodesk Material Library 2012    Succeeded
2012/12/21:20:40:21    ACW    UZDEROS    Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:44    ACW    UZDEROS    Install    Autodesk Material Library 2012 - Base Image Library    Succeeded
2012/12/21:20:40:44    ACW    UZDEROS    Installing DirectX® Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/21:20:40:54    ACW    UZDEROS    Install    DirectX® Runtime    Succeeded
2012/12/21:20:40:55    ACW    UZDEROS    Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:43:03    ACW    UZDEROS    Install    Web Services Enhancements (WSE) 3.0 for Microsoft .NET    Failed    Installation aborted, Result=1603
2012/12/21:20:43:04    ACW    UZDEROS    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/12/21:20:43:34    ACW    UZDEROS    Rollback    Autodesk Material Library 2012 - Base Image Library    Succeeded
2012/12/21:20:43:58    ACW    UZDEROS    Rollback    Autodesk Material Library 2012    Succeeded
2012/12/21:20:44:10    ACW    UZDEROS    Rollback    Autodesk® Design Review 2012    Succeeded
TravisNave
Message 8 of 9 (302 Views)
12-21-2012 09:16 AM in reply to: albertuschw
Sorry but Windows 8 is not a supported platform for Inventor 2012.  You will have to wait for the next release or install Inventor on Windows 7 for the time being.
Member
Message 9 of 9 (290 Views)
12-23-2012 05:42 AM in reply to: mooresk257
how about inventor 2013... my friend can install on windows 8 and i still stuck about WSE too -_-
can windows 8 has double booting? windows 7 and windows 8
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
