Installation & Licensing
How do I change license from 32-bit to 64-bit?
3 REPLIES 3
876 Views, 3 Replies
I am upgrading my workstation from a 32-bit OS (XP) to a 64-bit OS (Windows 7).  I currently run a 32-bit version of AutoCAD 2011 and assume that the license reflects that.  I wish to use a 64-bit version of the program.  How do I convert the 32-bit license to a 64-bit license?  Thanks in advance for any help.
3 REPLIES 3
TravisNave
The license isn't specific to the CPU architecture.  Your 2011 license is good for either installation.  😃
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
So, all I have to do is download the 64-bit version, install it, and activate it.  Correct?
Oh, and thanks for the exceptionally fast response.
TravisNave
That is correct!  And you are quite welcome!
Autodesk Forums:
Administrator Productivity
