I am upgrading my workstation from a 32-bit OS (XP) to a 64-bit OS (Windows 7). I currently run a 32-bit version of AutoCAD 2011 and assume that the license reflects that. I wish to use a 64-bit version of the program. How do I convert the 32-bit license to a 64-bit license? Thanks in advance for any help.
Solved by TravisNave. Go to Solution.
The license isn't specific to the CPU architecture. Your 2011 license is good for either installation. 😃
So, all I have to do is download the 64-bit version, install it, and activate it. Correct?
Oh, and thanks for the exceptionally fast response.
That is correct! And you are quite welcome!
