Installation & Licensing
Help.AutoCAD have stopped working when I input the activation code
3 REPLIES 3
ningyu12
215 Views, 3 Replies
Is there anybody who had the same problem???
In my lab, eight computers have the same problem!!!.
3 REPLIES 3
ningyu12
in reply to: ningyu12
Autocad technical support?
ampster401
You've dialed the wrong number,
This is "peer" support.
You might have better luck in the Installation & Licensing forum;
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
TravisNave
Free educational licenses are not permanent.  Your period may have ended.  You will need to apply for an extension.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
