Has anyone found a way to disable the cancel button using the setup.exe in AutoCAD 2014? I am using this command,
Setup.exe /W /qb /I Img\Setup.ini /language it-IT and has changed some things inside the INI but could not find it to work.
I don't want to go back with the previous setup that I have done in the past with AutoCAD 2013, whereas I had to install each MSI's one by one via separate scripts just to have the disable cancel button using /qb!. This time, I want to have 1 point of entry for changes which I believe is easier to maintain and spot issues and do changes as minimal as possible to the original installer.
On the other hand, I am quiet happy with how Autodesk managed to create a tool for deployment. I hope that in the future versions, there would also be a space for this wish list (disable cancel button with basic UI) which I believe is very applicable to every enterprise out there.
A good example is Office Customisation Tool (OCT) of Microsoft Office where you can add, delete files and folders as well as control the shortcuts, and many more.
This is a tough question, I was talking to a developer and the suggestion is to try following 2 flags:
/qr
/qn
Thanks for looking into this.. but it does not work. It will still show a full GUI mode and you have to click for it to continue.
I am thinking that the cancel button can be controlled somewhere in these 3 DLL files thru function.
..\Img\Setup\
SetupAcadUi.dll
SetupCtrls.dll
SetupUi.dll
If someone can take a look into that, it would be great..
