Dave,
In your license file, you show that you have two Increment line items for
both ACDLAND and A-CIVDES, both for one seat each. Each of those lines in
your license file will have an "ISSUED=" date. For like features (e.g.
ACDLAND), if the Issued date is different, only last one generated will
authenticate. However, if the date is the same, then the seats will be
added together.
Based on the problem you outline, it sounds like your two ACDLAND lines have
a different ISSUED date and the two A-CIVDES have the same ISSUED date - at
least that would explain the behavior.
If that is the case, you simply need to contact your reseller or Autodesk
customer service to have the two ACDLAND licenses re-issued on the same date
so the seats will be added together.
Greg Suppes
"Dave Lewis" wrote in message
news:tm7c50dtiu4m7pbbac7n0sif8n6hbppkj3@4ax.com...
> OK I don't understand this then
> I have 2 serials of LDD R3, but it says I only have 1.
> I have 2 serials of civil design and it says I have 2.
> So whats the deal?
> ADLM
> Feature usage info:
> Users of 40200ACDLAND_3_0F: (Total of 1 license issued; Total of 1
license in use)
> "40200ACDLAND_3_0F" v1.000, vendor: adskflex
> floating license
> XXXXXXXXXXX USER XXXXX (v1.000) (DELL_SERVER_3/27000 105), start Mon
3/15 13:07
> Users of 40500A-CIVDES_3_0F: (Total of 2 licenses issued; Total of 0
licenses in use)
> Users of 40700CADOV_2002_0F: (Total of 1 license issued; Total of 0
licenses in use)
> from .lic file
> INCREMENT 40200ACDLAND_3_0F adskflex 1.000 permanent 1 \
> INCREMENT 40500A-CIVDES_3_0F adskflex 1.000 permanent 1 \
> INCREMENT 40700CADOV_2002_0F adskflex 1.000 permanent 1 \
> "jerry milana"
> |>Dave,
> |>First try running a server status using LMtools. Look for feature
> |>40200ACDLAND_3_0F and see how many seats your license manager thinks you
> |>have. Keep in mind that you can only have one INCREMENT per feature
number
> |>in your license file. If two exist then only the last one generated
will
> |>authenticate, they will not be additive. So each increment must reflect
the
> |>full seat count for a given feature.
> Dave Lewis
> CAD Manager
> http://www.cadthinking.com
> Just say no to HTML Posts!
