I've been trying to download the Revit 2012 on my new computer and its not working. This is the error shown:
Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
I already deleted all of the C++2005 files from my comp, but it still doesn't work.
I read on the forum that maybe creating a temp folder can resolve it, but it doesn't say where to create the folder. Please help.
Thanks!
Solved by TravisNave. Go to Solution.
@Anonymous
Welcome to the Autodesk User's Community..
Download and install per:
1. Clean out your personal temp (%temp%) folder. Set Windows UAC to never notify and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product. At this point you could cancel the installation or create a deployment.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous,
You should've started a new thread. But that is okay. Here is your error:
Autodesk® 2018 Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the Virtual Agent by following the directions here:
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions/previous-version-virtual-agent
Good Luck!
2017/6/9:11:49:21 USER LAPTOP-QLOO2B92 Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/6/9:11:49:21 USER LAPTOP-QLOO2B92 Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2017/6/9:11:49:21 USER LAPTOP-QLOO2B92 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/6/9:11:49:21 USER LAPTOP-QLOO2B92 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
this is the report that autodesk installation written
what is this and what can i do
@Anonymous
1619 error is never the reason why it fails. Please provide the entire log and not a few lines from it. Also make sure the log doesn't contain personal info such as your serial #.
Mark Lancaster
@Anonymous
Again you only providing a few lines of the failed installation log file.. Not sure why you are not providing the entire log. Is there a reason?
Mark Lancaster
thanks a lot Mark i did it now from your answer to somebody by autodesk virtual agent,)
Hi Mark, et.al
Annoying story here that resonates with everyone else, unfortunately:
Installed Revit 2017 on a Windows 10 Bootcamp partition and had trouble with libraries never finishing loading but Revit seemed to run fine, except when I played with a material which needed the library and then it would crash but was working away. When I would try again and again to install the libraries it would get to 3gig or something and fail and I would just go back to working in the main program. Spoke to the IT guy at work and he went and downloaded the 2 big spx files and suggested that I use CCleaner which I did and then first time I tried to extract it half worked but then would not launch, and thereafter it just wouldn't extract at all, the window just disappearing. I kept running around the various threads here exploring changing Virus settings, downloading the files again myself, installing the Revit_2017_MasterXML files, deleting temp directories etc and it just seems to get worse and worse. If I didnt have software already on the partition I would wipe it, reinstall windows and start all over again.
Anyhow, here is the error log from the last attempt, I would appreciate your thoughts.
Cheers
JR
2017/7/11:20:37:17 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:20:37:17 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:20:37:17 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI427.tmp
2017/7/11:20:37:17 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:20:37:19 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:37:19 Julian Raxworthy DESKTOP-KETSS0S Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:37:20 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:37:48 Julian Raxworthy DESKTOP-KETSS0S Download Aborted SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:37:48 Julian Raxworthy DESKTOP-KETSS0S Error downloading. Please Install Now again from the Autodesk website. 2017/7/11:20:38:20 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S CommandLine /akamai /sid a1b3A00000B2AS8QAN /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a..."
2017/7/11:20:37:16 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI427.tmp
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S CommandLine /akamai /sid a1b3A00000B2AS8QAN /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a..."
2017/7/11:20:38:39 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI49C6.tmp
2017/7/11:20:39:09 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI49C6.tmp
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:38:40 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:39:08 Julian Raxworthy DESKTOP-KETSS0S Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:20:39:09 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JULIAN~1\AppData\Local\Temp\_AI49C6.tmp\Setup\RevitSetup.dll
2017/7/11:20:39:09 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/7/11:20:39:10 Julian Raxworthy DESKTOP-KETSS0S PageOpen LaunchDialog
2017/7/11:20:39:20 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\JULIAN~1\AppData\Local\Temp\_AI49C6.tmp\Setup\RevitSetup.dll
2017/7/11:20:39:20 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/7/11:20:39:38 Julian Raxworthy DESKTOP-KETSS0S PageOpen LicenseDialog
2017/7/11:20:39:38 Julian Raxworthy DESKTOP-KETSS0S PageOpen ProductInfoDialog
2017/7/11:20:39:38 Julian Raxworthy DESKTOP-KETSS0S PageOpen ProductSelectionDialog2
2017/7/11:20:39:52 Julian Raxworthy DESKTOP-KETSS0S PageOpen FullProgressDialog
2017/7/11:20:39:53 Julian Raxworthy DESKTOP-KETSS0S Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2017/7/11:20:39:53 Julian Raxworthy DESKTOP-KETSS0S Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2017/7/11:20:39:54 Julian Raxworthy DESKTOP-KETSS0S Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:20:39:59 Julian Raxworthy DESKTOP-KETSS0S Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:20:39:59 Julian Raxworthy DESKTOP-KETSS0S Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JULIAN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/7/11:20:40:00 Julian Raxworthy DESKTOP-KETSS0S Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/7/11:20:40:01 Julian Raxworthy DESKTOP-KETSS0S Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:20:40:05 Julian Raxworthy DESKTOP-KETSS0S Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:20:40:05 Julian Raxworthy DESKTOP-KETSS0S Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JULIAN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/7/11:20:40:06 Julian Raxworthy DESKTOP-KETSS0S Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/7/11:20:40:07 Julian Raxworthy DESKTOP-KETSS0S Download Play RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2017/7/11:20:40:12 Julian Raxworthy DESKTOP-KETSS0S Download Aborted RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2017/7/11:20:40:12 Julian Raxworthy DESKTOP-KETSS0S Install Autodesk® Revit® Content Libraries 2017 Failed Download Failed, Installation aborted, Result=1603
2017/7/11:20:40:13 Julian Raxworthy DESKTOP-KETSS0S Download Play CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CLM_x...
2017/7/11:20:47:17 Julian Raxworthy DESKTOP-KETSS0S Download Aborted CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CLM_x...
2017/7/11:20:47:17 Julian Raxworthy DESKTOP-KETSS0S Download User Cancel CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CLM_x...
2017/7/11:20:47:18 Julian Raxworthy DESKTOP-KETSS0S Download Play CANCELMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CANCE...
2017/7/11:20:47:18 Julian Raxworthy DESKTOP-KETSS0S PageOpen InstallCompleteDialog
2017/7/11:20:47:27 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S CommandLine /PK 829I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2017/7/11:21:32:13 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI9B0A.tmp
2017/7/11:21:38:02 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:21:32:14 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:21:32:14 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:21:32:14 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI9B0A.tmp
2017/7/11:21:32:14 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:21:32:16 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2017/7/11:21:32:17 Julian Raxworthy DESKTOP-KETSS0S Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2017/7/11:21:32:17 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2017/7/11:21:34:30 Julian Raxworthy DESKTOP-KETSS0S Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2017/7/11:21:34:30 Julian Raxworthy DESKTOP-KETSS0S Error downloading. Please Install Now again from the Autodesk website. 2017/7/11:21:38:02 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S CommandLine /akamai /sid a1b3A00000B2AS8QAN /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a..."
2017/7/11:21:48:08 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp
2017/7/11:21:50:19 Julian Raxworthy DESKTOP-KETSS0S === Setup ended ===
2017/7/11:21:48:10 Julian Raxworthy DESKTOP-KETSS0S === Setup started on DESKTOP-KETSS0S by Julian Raxworthy ===
2017/7/11:21:48:10 Julian Raxworthy DESKTOP-KETSS0S Path_Length: 155
2017/7/11:21:48:10 Julian Raxworthy DESKTOP-KETSS0S Current Directory C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp
2017/7/11:21:48:10 Julian Raxworthy DESKTOP-KETSS0S Launch
2017/7/11:21:48:11 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:21:48:12 Julian Raxworthy DESKTOP-KETSS0S Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:21:48:12 Julian Raxworthy DESKTOP-KETSS0S Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:21:50:18 Julian Raxworthy DESKTOP-KETSS0S Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2017/7/11:21:50:18 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp\Setup\RevitSetup.dll
2017/7/11:21:50:18 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/7/11:21:50:19 Julian Raxworthy DESKTOP-KETSS0S PageOpen LaunchDialog
2017/7/11:21:50:33 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp\Setup\RevitSetup.dll
2017/7/11:21:50:33 Julian Raxworthy DESKTOP-KETSS0S Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/7/11:21:51:13 Julian Raxworthy DESKTOP-KETSS0S PageOpen LicenseDialog
2017/7/11:21:51:13 Julian Raxworthy DESKTOP-KETSS0S PageOpen ProductInfoDialog
2017/7/11:21:51:13 Julian Raxworthy DESKTOP-KETSS0S PageOpen ProductSelectionDialog2
2017/7/11:21:51:46 Julian Raxworthy DESKTOP-KETSS0S PageOpen FullProgressDialog
2017/7/11:21:51:47 Julian Raxworthy DESKTOP-KETSS0S Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2017/7/11:21:51:47 Julian Raxworthy DESKTOP-KETSS0S Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2017/7/11:21:51:48 Julian Raxworthy DESKTOP-KETSS0S Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:21:51:54 Julian Raxworthy DESKTOP-KETSS0S Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:21:51:54 Julian Raxworthy DESKTOP-KETSS0S Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JULIAN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/7/11:21:51:55 Julian Raxworthy DESKTOP-KETSS0S Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/7/11:21:51:56 Julian Raxworthy DESKTOP-KETSS0S Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:21:52:02 Julian Raxworthy DESKTOP-KETSS0S Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2017/7/11:21:52:02 Julian Raxworthy DESKTOP-KETSS0S Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JULIAN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/7/11:21:52:02 Julian Raxworthy DESKTOP-KETSS0S Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/7/11:21:52:03 Julian Raxworthy DESKTOP-KETSS0S Download Play RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2017/7/11:21:52:14 Julian Raxworthy DESKTOP-KETSS0S Download Complete RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2017/7/11:21:52:14 Julian Raxworthy DESKTOP-KETSS0S Installing Autodesk® Revit® Content Libraries 2017: TRANSFORMS=":en-us.mst;C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/11:22:00:27 Julian Raxworthy DESKTOP-KETSS0S Install Autodesk® Revit® Content Libraries 2017 Succeeded
2017/7/11:22:00:27 Julian Raxworthy DESKTOP-KETSS0S Download Play CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CLM_x...
2017/7/11:22:00:27 Julian Raxworthy DESKTOP-KETSS0S Download Complete CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CLM_x...
2017/7/11:22:00:27 Julian Raxworthy DESKTOP-KETSS0S Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\JULIAN~1\AppData\Local\Temp\_AI308F.tmp\x64\CLM\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/11:22:00:46 Julian Raxworthy DESKTOP-KETSS0S Install Autodesk Licensing Manager Succeeded
2017/7/11:22:00:46 Julian Raxworthy DESKTOP-KETSS0S Download Play RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2017/7/11:22:06:33 Julian Raxworthy DESKTOP-KETSS0S Download Aborted RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2017/7/11:22:06:33 Julian Raxworthy DESKTOP-KETSS0S Install Autodesk® Revit® 2017 Failed Download Failed, Installation aborted, Result=1603
2017/7/11:22:07:35 Julian Raxworthy DESKTOP-KETSS0S Rollback Autodesk Licensing Manager Succeeded
2017/7/11:22:08:15 Julian Raxworthy DESKTOP-KETSS0S Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
2017/7/11:22:08:15 Julian Raxworthy DESKTOP-KETSS0S Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/7/11:22:08:15 Julian Raxworthy DESKTOP-KETSS0S Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Your download is failing due to the method you're using..
1. Clean out your personal temp (%temp%) folder. Set Windows UAC to never notify, full admin rights, and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
Mark Lancaster
Hi, I have the same problem to install revit 2018 and tried to use your method to installed it, but it still failed.
2019/1/22:09:04:55 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:09:04:55 Path_Length: 155
2019/1/22:09:04:55 Current Directory C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:09:04:55 Launch
2019/1/22:09:04:55 CommandLine
2019/1/22:09:04:55 Current Directory C:\Users\shirl\AppData\Local\Temp\_AIF6C0.tmp
2019/1/22:09:05:16 === Setup ended ===
2019/1/22:09:05:00 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:09:05:00 Path_Length: 155
2019/1/22:09:05:00 Current Directory C:\Users\shirl\AppData\Local\Temp\_AIF6C0.tmp
2019/1/22:09:05:00 Launch
2019/1/22:09:05:00 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AIF6C0.tmp\Setup\RevitSetup.dll
2019/1/22:09:05:00 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:09:05:15 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AIF6C0.tmp\Setup\RevitSetup.dll
2019/1/22:09:05:15 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:09:05:18 PageOpen LaunchDialog
2019/1/22:09:07:45 PageOpen LicenseDialog
2019/1/22:09:07:50 PageOpen ProductInfoDialog
2019/1/22:09:07:50 PageOpen ProductSelectionDialog2
2019/1/22:09:08:12 PageOpen FullProgressDialog
2019/1/22:09:08:12 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2019/1/22:09:08:37 Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 0
2019/1/22:09:08:37 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2019/1/22:09:08:37 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2019/1/22:09:08:54 Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 return code: 0
2019/1/22:09:08:54 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2019/1/22:09:08:54 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:09:09:13 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:09:09:13 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:09:09:13 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:09:09:32 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:09:09:32 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:09:09:32 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2019/1/22:09:09:52 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 0
2019/1/22:09:09:52 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2019/1/22:09:09:52 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2019/1/22:09:10:09 Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 return code: 0
2019/1/22:09:10:09 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2019/1/22:09:10:09 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2019/1/22:09:10:19 Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2019/1/22:09:10:19 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2019/1/22:09:10:19 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2019/1/22:09:10:28 Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2019/1/22:09:10:28 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2019/1/22:09:10:28 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2019/1/22:09:10:42 Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2019/1/22:09:10:42 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2019/1/22:09:10:42 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2019/1/22:09:10:58 Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2019/1/22:09:10:58 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2019/1/22:09:10:58 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:09:11:01 Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2019/1/22:09:11:01 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2019/1/22:09:11:01 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:09:11:05 Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2019/1/22:09:11:05 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2019/1/22:09:11:05 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:08 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:09:11:08 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:16 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:09:11:16 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:23 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:09:11:23 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:29 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:09:11:29 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:33 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:09:11:33 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:40 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:09:11:40 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:47 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:09:11:47 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:09:11:53 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:09:11:53 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:09:12:20 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:09:12:20 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:09:12:20 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Users\shirley\Downloads\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:09:12:42 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:09:12:42 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:09:12:42 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:09:12:46 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:09:12:50 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:09:12:54 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:09:12:56 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:09:13:00 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:09:13:03 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:09:13:07 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:09:13:09 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:09:13:10 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:09:13:11 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:09:13:11 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:09:13:23 PageOpen InstallCompleteDialog
2019/1/22:09:14:11 === Setup ended ===
2019/1/22:20:42:19 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:20:42:19 Path_Length: 155
2019/1/22:20:42:19 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:20:42:19 Launch
2019/1/22:20:42:19 CommandLine
2019/1/22:20:42:19 Current Directory C:\Users\shirl\AppData\Local\Temp\_AI7B75.tmp
2019/1/22:20:42:39 === Setup ended ===
2019/1/22:20:42:23 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:20:42:23 Path_Length: 155
2019/1/22:20:42:23 Current Directory C:\Users\shirl\AppData\Local\Temp\_AI7B75.tmp
2019/1/22:20:42:23 Launch
2019/1/22:20:42:23 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AI7B75.tmp\Setup\RevitSetup.dll
2019/1/22:20:42:23 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:20:42:38 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AI7B75.tmp\Setup\RevitSetup.dll
2019/1/22:20:42:38 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:20:42:41 PageOpen LaunchDialog
2019/1/22:20:44:56 PageOpen LicenseDialog
2019/1/22:20:45:03 PageOpen ProductInfoDialog
2019/1/22:20:45:03 PageOpen ProductSelectionDialog2
2019/1/22:20:45:10 PageOpen FullProgressDialog
2019/1/22:20:45:10 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:20:45:32 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:20:45:32 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:20:45:32 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:20:45:49 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:20:45:49 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:20:45:49 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:20:45:50 Microsoft Visual C++ 2015 Redistributable (x86) return code: 1638
2019/1/22:20:45:50 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2019/1/22:20:45:50 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:20:45:51 Microsoft Visual C++ 2015 Redistributable (x64) return code: 1638
2019/1/22:20:45:51 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2019/1/22:20:45:51 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:45:55 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:20:45:55 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:03 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:20:46:03 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:10 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:20:46:10 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:15 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:20:46:16 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:18 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:20:46:18 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:27 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:20:46:27 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:33 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:20:46:33 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:46:39 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:20:46:39 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:20:47:05 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:20:47:05 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:20:47:05 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:20:47:25 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:20:47:25 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:20:47:25 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:20:47:28 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:20:47:31 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:20:47:34 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:20:47:35 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:20:47:38 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:20:47:41 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:20:47:44 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:20:47:45 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:20:47:46 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:20:47:46 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:20:47:54 PageOpen InstallCompleteDialog
2019/1/22:20:52:19 === Setup ended ===
2019/1/22:20:52:29 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:20:52:29 Path_Length: 155
2019/1/22:20:52:29 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:20:52:29 Launch
2019/1/22:20:52:29 CommandLine
2019/1/22:20:52:29 Current Directory C:\Users\shirl\AppData\Local\Temp\_AICBEB.tmp
2019/1/22:20:52:46 === Setup ended ===
2019/1/22:20:52:31 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:20:52:31 Path_Length: 155
2019/1/22:20:52:31 Current Directory C:\Users\shirl\AppData\Local\Temp\_AICBEB.tmp
2019/1/22:20:52:31 Launch
2019/1/22:20:52:31 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AICBEB.tmp\Setup\RevitSetup.dll
2019/1/22:20:52:31 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:20:52:45 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AICBEB.tmp\Setup\RevitSetup.dll
2019/1/22:20:52:45 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:20:52:46 PageOpen LaunchDialog
2019/1/22:20:53:35 PageOpen LicenseDialog
2019/1/22:20:53:38 PageOpen ProductInfoDialog
2019/1/22:20:53:38 PageOpen ProductSelectionDialog2
2019/1/22:20:53:46 PageOpen FullProgressDialog
2019/1/22:20:53:46 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:20:54:01 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:20:54:01 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:20:54:01 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:20:54:16 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:20:54:16 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:20:54:16 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:20:54:17 Microsoft Visual C++ 2015 Redistributable (x86) return code: 1638
2019/1/22:20:54:17 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2019/1/22:20:54:17 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:20:54:17 Microsoft Visual C++ 2015 Redistributable (x64) return code: 1638
2019/1/22:20:54:17 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2019/1/22:20:54:17 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:20 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:20:54:20 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:26 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:20:54:26 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:32 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:20:54:32 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:37 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:20:54:37 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:40 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:20:54:40 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:47 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:20:54:47 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:53 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:20:54:53 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:20:54:58 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:20:54:58 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:20:55:21 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:20:55:21 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:20:55:21 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:20:55:38 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:20:55:38 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:20:55:38 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:20:55:40 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:20:55:43 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:20:55:46 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:20:55:48 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:20:55:50 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:20:55:53 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:20:55:56 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:20:55:58 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:20:55:58 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:20:55:58 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:20:56:06 PageOpen InstallCompleteDialog
2019/1/22:21:02:12 === Setup ended ===
2019/1/22:21:02:21 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:21:02:21 Path_Length: 155
2019/1/22:21:02:21 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:21:02:21 Launch
2019/1/22:21:02:21 CommandLine
2019/1/22:21:02:21 Current Directory C:\Users\shirl\AppData\Local\Temp\_AID584.tmp
2019/1/22:21:02:38 === Setup ended ===
2019/1/22:21:02:23 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:21:02:23 Path_Length: 155
2019/1/22:21:02:23 Current Directory C:\Users\shirl\AppData\Local\Temp\_AID584.tmp
2019/1/22:21:02:23 Launch
2019/1/22:21:02:24 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AID584.tmp\Setup\RevitSetup.dll
2019/1/22:21:02:24 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:21:02:37 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AID584.tmp\Setup\RevitSetup.dll
2019/1/22:21:02:37 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:21:02:38 PageOpen LaunchDialog
2019/1/22:21:03:58 PageOpen LicenseDialog
2019/1/22:21:04:12 PageOpen ProductInfoDialog
2019/1/22:21:04:12 PageOpen ProductSelectionDialog2
2019/1/22:21:04:18 PageOpen FullProgressDialog
2019/1/22:21:04:18 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2019/1/22:21:04:35 Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 0
2019/1/22:21:04:35 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2019/1/22:21:04:35 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2019/1/22:21:04:51 Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 return code: 0
2019/1/22:21:04:51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2019/1/22:21:04:51 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:21:05:07 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:21:05:07 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:21:05:07 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:21:05:23 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:21:05:23 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:21:05:23 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2019/1/22:21:05:39 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 0
2019/1/22:21:05:39 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2019/1/22:21:05:39 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2019/1/22:21:05:55 Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 return code: 0
2019/1/22:21:05:55 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2019/1/22:21:05:55 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2019/1/22:21:06:02 Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2019/1/22:21:06:02 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2019/1/22:21:06:03 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2019/1/22:21:06:11 Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2019/1/22:21:06:11 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2019/1/22:21:06:11 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2019/1/22:21:06:14 Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2019/1/22:21:06:14 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2019/1/22:21:06:14 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2019/1/22:21:06:18 Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2019/1/22:21:06:18 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2019/1/22:21:06:18 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:21:06:21 Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2019/1/22:21:06:21 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2019/1/22:21:06:21 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:21:06:24 Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2019/1/22:21:06:24 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2019/1/22:21:06:24 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:06:28 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:21:06:28 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:06:36 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:21:06:36 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:06:43 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:21:06:43 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:06:49 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:21:06:49 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:06:52 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:21:06:52 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:07:00 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:21:07:00 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:07:06 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:21:07:06 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:07:12 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:21:07:12 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:21:07:37 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:21:07:37 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:21:07:37 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:21:07:57 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:21:07:57 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:21:07:57 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:21:08:00 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:21:08:03 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:21:08:06 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:21:08:08 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:21:08:11 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:21:08:15 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:21:08:18 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:21:08:20 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:21:08:21 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:21:08:30 PageOpen InstallCompleteDialog
2019/1/22:21:08:58 === Setup ended ===
2019/1/22:21:29:03 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:21:29:03 Path_Length: 155
2019/1/22:21:29:03 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:21:29:03 Launch
2019/1/22:21:29:03 CommandLine
2019/1/22:21:29:03 Current Directory C:\Users\shirl\AppData\Local\Temp\_AI45DD.tmp
2019/1/22:21:29:21 === Setup ended ===
2019/1/22:21:29:06 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:21:29:06 Path_Length: 155
2019/1/22:21:29:06 Current Directory C:\Users\shirl\AppData\Local\Temp\_AI45DD.tmp
2019/1/22:21:29:06 Launch
2019/1/22:21:29:06 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AI45DD.tmp\Setup\RevitSetup.dll
2019/1/22:21:29:06 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:21:29:20 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AI45DD.tmp\Setup\RevitSetup.dll
2019/1/22:21:29:20 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:21:29:21 PageOpen LaunchDialog
2019/1/22:21:30:25 PageOpen LicenseDialog
2019/1/22:21:30:29 PageOpen ProductInfoDialog
2019/1/22:21:30:29 PageOpen ProductSelectionDialog2
2019/1/22:21:30:38 PageOpen FullProgressDialog
2019/1/22:21:30:38 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:21:30:54 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:21:30:54 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:21:30:54 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:21:31:09 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:21:31:09 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:21:31:09 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:21:31:10 Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2019/1/22:21:31:10 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2019/1/22:21:31:10 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:21:31:10 Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2019/1/22:21:31:10 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2019/1/22:21:31:10 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:13 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:21:31:13 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:20 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:21:31:20 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:25 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:21:31:25 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:30 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:21:31:30 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:33 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:21:31:33 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:41 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:21:31:41 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:46 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:21:31:46 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:21:31:51 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:21:31:51 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:21:32:14 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:21:32:14 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:21:32:14 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:21:32:30 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:21:32:30 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:21:32:30 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:21:32:33 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:21:32:36 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:21:32:38 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:21:32:40 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:21:32:43 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:21:32:46 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:21:32:49 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:21:32:51 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:21:32:51 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:21:32:51 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:21:32:51 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:21:32:51 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2019/1/22:21:32:59 PageOpen InstallCompleteDialog
2019/1/22:21:33:27 === Setup ended ===
2019/1/22:22:22:16 === Setup started on DESKTOP-ILJ50HA by shirl ===
2019/1/22:22:22:16 Path_Length: 155
2019/1/22:22:22:16 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_dlm
2019/1/22:22:22:16 Launch
2019/1/22:22:22:16 CommandLine
2019/1/22:22:22:16 Current Directory C:\Users\shirl\AppData\Local\Temp\_AIFE56.tmp
2019/1/22:22:22:31 === Setup ended ===
2019/1/22:22:22:17 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AIFE56.tmp\Setup\RevitSetup.dll
2019/1/22:22:22:17 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/1/22:22:22:30 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\shirl\AppData\Local\Temp\_AIFE56.tmp\Setup\RevitSetup.dll
2019/1/22:22:22:30 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=取消选择内容安装将影响 Autodesk® Revit® 2018 中的关键设置。 URLTitle= URLLink=
2019/1/22:22:22:31 PageOpen LaunchDialog
2019/1/22:22:23:16 PageOpen LicenseDialog
2019/1/22:22:24:11 PageOpen ProductInfoDialog
2019/1/22:22:24:11 PageOpen ProductSelectionDialog2
2019/1/22:22:24:18 PageOpen FullProgressDialog
2019/1/22:22:24:18 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:22:24:35 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2019/1/22:22:24:35 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2019/1/22:22:24:36 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:22:24:58 Microsoft Visual C++ 2005 Redistributable (x64) return code: 0
2019/1/22:22:24:58 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2019/1/22:22:24:58 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2015.log
2019/1/22:22:24:59 Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2019/1/22:22:24:59 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2019/1/22:22:24:59 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2015.log
2019/1/22:22:25:00 Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2019/1/22:22:25:00 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2019/1/22:22:25:00 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:03 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:22:25:03 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:11 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:22:25:11 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:18 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:22:25:18 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:23 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:22:25:23 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:26 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:22:25:26 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:34 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:22:25:34 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:40 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:22:25:41 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/1/22:22:25:46 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:22:25:46 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x86_2005.log"" "
2019/1/22:22:26:12 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) return code: 0
2019/1/22:22:26:12 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2019/1/22:22:26:12 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\shirl\AppData\Local\Temp\vcredist_x64_2005.log"" "
2019/1/22:22:26:31 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) return code: 0
2019/1/22:22:26:31 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2019/1/22:22:26:31 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2019/1/22:22:26:35 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2019/1/22:22:26:38 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2019/1/22:22:26:41 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2019/1/22:22:26:43 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2019/1/22:22:26:46 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2019/1/22:22:26:49 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2019/1/22:22:26:52 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2019/1/22:22:26:54 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2019/1/22:22:26:54 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2019/1/22:22:26:54 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2019/1/22:22:26:55 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2019/1/22:22:26:55 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
This problem is caused by windows iis version.
Please visit
Change iis version in regedit
"HKLM\SYSTEM\CurrentControlSet\Services\W3SVC\Parameters\MajorVersion" set to 8
restore iis versiyon than install finished
"HKLM\SYSTEM\CurrentControlSet\Services\W3SVC\Parameters\MajorVersion" set to a
