I've been trying to download the Revit 2012 on my new computer and its not working. This is the error shown:
Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
I already deleted all of the C++2005 files from my comp, but it still doesn't work.
I read on the forum that maybe creating a temp folder can resolve it, but it doesn't say where to create the folder. Please help.
Thanks!
Solved by TravisNave. Go to Solution.
Post the full log. The actual error will be above the rollback.
I am having a similar issue. I switched OS from Windows 7 Pro 32 bit to W7 Pro 64 bit. Autodesk sent new download file AutoCAD_LT_2012_English_Japanese_Win_64bit. I was having issues with the installation of Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603. I removed other verstions of C++ both 2008 and 2010 and tried install again and I now seem to be having another issue. I tried the install twice and still the same issue see below. Please help.
TRAndrews TRANDREWSOFFICE === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:06:36 TRAndrews TRANDREWSOFFICE Launch
2012/10/11:14:07:04 TRAndrews TRANDREWSOFFICE PageOpen LaunchDialog
2012/10/11:14:07:33 TRAndrews TRANDREWSOFFICE PageOpen LicenseDialog
2012/10/11:14:07:37 TRAndrews TRANDREWSOFFICE PageOpen ProductInfoDialog
2012/10/11:14:11:25 TRAndrews TRANDREWSOFFICE PageOpen ProductSelectionDialog2
2012/10/11:14:11:37 TRAndrews TRANDREWSOFFICE PageOpen FullProgressDialog
2012/10/11:14:11:37 TRAndrews TRANDREWSOFFICE Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\TRANDR~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/11:14:11:43 TRAndrews TRANDREWSOFFICE Install Microsoft Visual C++ 2010 Redistributable (x86) Succeeded
2012/10/11:14:11:43 TRAndrews TRANDREWSOFFICE Installing Autodesk® Design Review: TRANSFORMS="C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:12:29 TRAndrews TRANDREWSOFFICE Install Autodesk® Design Review Succeeded
2012/10/11:14:12:29 TRAndrews TRANDREWSOFFICE Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:13:03 TRAndrews TRANDREWSOFFICE Install DirectX Runtime Succeeded
2012/10/11:14:13:03 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:13:35 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 Succeeded
2012/10/11:14:13:35 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:14:07 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:14:14:07 TRAndrews TRANDREWSOFFICE Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:14:16 TRAndrews TRANDREWSOFFICE Install Autodesk Content Service Succeeded
2012/10/11:14:14:17 TRAndrews TRANDREWSOFFICE Installing AutoCAD LT® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:19:42 TRAndrews TRANDREWSOFFICE Install AutoCAD LT® 2012 Failed Installation aborted, Result=1603
2012/10/11:14:19:47 TRAndrews TRANDREWSOFFICE Rollback Autodesk Content Service Succeeded
2012/10/11:14:20:00 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:14:20:16 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 Succeeded
2012/10/11:14:20:16 TRAndrews TRANDREWSOFFICE Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/11:14:20:22 TRAndrews TRANDREWSOFFICE Rollback Autodesk® Design Review Succeeded
2012/10/11:14:20:22 TRAndrews TRANDREWSOFFICE Rollback Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1619
2012/10/11:14:20:22 TRAndrews TRANDREWSOFFICE PageOpen InstallCompleteDialog
2012/10/11:14:22:25 TRAndrews TRANDREWSOFFICE === Setup ended ===
2012/10/11:14:39:07 TRAndrews TRANDREWSOFFICE === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:07 TRAndrews TRANDREWSOFFICE Launch
2012/10/11:14:40:08 TRAndrews TRANDREWSOFFICE === Setup ended ===
2012/10/11:14:39:08 TRAndrews TRANDREWSOFFICE === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:08 TRAndrews TRANDREWSOFFICE Launch
2012/10/11:14:40:10 TRAndrews TRANDREWSOFFICE PageOpen LaunchDialog
2012/10/11:14:40:39 TRAndrews TRANDREWSOFFICE PageOpen LicenseDialog
2012/10/11:14:40:53 TRAndrews TRANDREWSOFFICE PageOpen ProductInfoDialog
2012/10/11:14:41:09 TRAndrews TRANDREWSOFFICE PageOpen ProductSelectionDialog2
2012/10/11:14:41:11 TRAndrews TRANDREWSOFFICE PageOpen FullProgressDialog
2012/10/11:14:41:11 TRAndrews TRANDREWSOFFICE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/10/11:14:41:41 TRAndrews TRANDREWSOFFICE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/10/11:14:41:41 TRAndrews TRANDREWSOFFICE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/10/11:14:41:50 TRAndrews TRANDREWSOFFICE Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/10/11:14:41:50 TRAndrews TRANDREWSOFFICE Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:42:32 TRAndrews TRANDREWSOFFICE Install DirectX Runtime Succeeded
2012/10/11:14:42:32 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:43:01 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 Succeeded
2012/10/11:14:43:01 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:43:52 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:14:43:52 TRAndrews TRANDREWSOFFICE Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:14:44:12 TRAndrews TRANDREWSOFFICE Install Autodesk Content Service Succeeded
2012/10/11:14:44:13 TRAndrews TRANDREWSOFFICE Installing AutoCAD LT® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI3F9E.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:15:00:54 TRAndrews TRANDREWSOFFICE Install AutoCAD LT® 2012 Failed Installation aborted, Result=1603
2012/10/11:15:00:58 TRAndrews TRANDREWSOFFICE Rollback Autodesk Content Service Succeeded
2012/10/11:15:01:11 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:15:01:25 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 Succeeded
2012/10/11:15:01:25 TRAndrews TRANDREWSOFFICE Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/11:15:01:25 TRAndrews TRANDREWSOFFICE PageOpen InstallCompleteDialog
2012/10/11:15:09:09 TRAndrews TRANDREWSOFFICE === Setup ended ===
2012/10/11:15:09:47 TRAndrews TRANDREWSOFFICE === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:47 TRAndrews TRANDREWSOFFICE Launch
2012/10/11:15:09:55 TRAndrews TRANDREWSOFFICE === Setup ended ===
2012/10/11:15:09:50 TRAndrews TRANDREWSOFFICE === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:50 TRAndrews TRANDREWSOFFICE Launch
2012/10/11:15:09:55 TRAndrews TRANDREWSOFFICE PageOpen LaunchDialog
2012/10/11:15:10:26 TRAndrews TRANDREWSOFFICE PageOpen LicenseDialog
2012/10/11:15:10:29 TRAndrews TRANDREWSOFFICE PageOpen ProductInfoDialog
2012/10/11:15:10:53 TRAndrews TRANDREWSOFFICE PageOpen ProductSelectionDialog2
2012/10/11:15:10:54 TRAndrews TRANDREWSOFFICE PageOpen FullProgressDialog
2012/10/11:15:10:54 TRAndrews TRANDREWSOFFICE Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:15:11:14 TRAndrews TRANDREWSOFFICE Install DirectX Runtime Succeeded
2012/10/11:15:11:14 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:15:11:29 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 Succeeded
2012/10/11:15:11:29 TRAndrews TRANDREWSOFFICE Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:15:11:56 TRAndrews TRANDREWSOFFICE Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:15:11:56 TRAndrews TRANDREWSOFFICE Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:15:12:19 TRAndrews TRANDREWSOFFICE Install Autodesk Content Service Succeeded
2012/10/11:15:12:21 TRAndrews TRANDREWSOFFICE Installing AutoCAD LT® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI5669.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/11:15:14:11 TRAndrews TRANDREWSOFFICE Install AutoCAD LT® 2012 Failed Installation aborted, Result=1603
2012/10/11:15:14:14 TRAndrews TRANDREWSOFFICE Rollback Autodesk Content Service Succeeded
2012/10/11:15:14:27 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/10/11:15:14:41 TRAndrews TRANDREWSOFFICE Rollback Autodesk Material Library 2012 Succeeded
2012/10/11:15:14:41 TRAndrews TRANDREWSOFFICE Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Have you ever tried to install DirectX Runtime but only that component and then install Revit?, Maybe the installation of DirectX is not the correct when you try to install REVIT
2013/1/28:02:09:14 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:02:09:14 Ardy ARDY-PC Launch 2013/1/28:02:09:14 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:02:09:29 Ardy ARDY-PC === Setup ended ===
2013/1/28:02:09:16 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:02:09:16 Ardy ARDY-PC Launch 2013/1/28:02:09:16 Ardy ARDY-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:02:09:28 Ardy ARDY-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:02:09:30 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:02:10:14 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:02:10:14 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:02:10:14 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:02:12:25 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:02:12:26 Ardy ARDY-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:02:12:32 Ardy ARDY-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:02:12:32 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:02:12:36 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:02:12:36 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:02:29:47 Ardy ARDY-PC === Setup ended ===
2013/1/28:02:56:51 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:02:56:51 Ardy ARDY-PC Launch 2013/1/28:02:56:51 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:02:57:04 Ardy ARDY-PC === Setup ended ===
2013/1/28:02:56:53 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:02:56:53 Ardy ARDY-PC Launch 2013/1/28:02:56:54 Ardy ARDY-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:02:57:04 Ardy ARDY-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:02:57:04 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:02:57:46 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:02:57:46 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:02:57:46 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:02:57:53 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:02:57:53 Ardy ARDY-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:02:57:54 Ardy ARDY-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:02:57:54 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:02:57:58 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:02:57:58 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:02:58:32 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:32:50 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:32:50 Ardy ARDY-PC Launch 2013/1/28:03:32:50 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:03:32:56 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:32:51 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:32:51 Ardy ARDY-PC Launch 2013/1/28:03:32:54 Ardy ARDY-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:03:32:57 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:03:33:33 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:03:33:33 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:03:33:33 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:03:33:51 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:03:33:52 Ardy ARDY-PC Download Play VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:33:54 Ardy ARDY-PC Download Complete VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:33:54 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:03:34:01 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:03:34:01 Ardy ARDY-PC Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:34:01 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:03:34:03 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:03:34:03 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:03:34:03 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:03:36:30 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:47:47 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:47:47 Ardy ARDY-PC Launch 2013/1/28:03:47:47 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:03:48:02 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:47:49 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:47:49 Ardy ARDY-PC Launch 2013/1/28:03:47:50 Ardy ARDY-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:03:48:01 Ardy ARDY-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:03:48:03 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:03:48:46 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:03:48:46 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:03:48:46 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:03:49:01 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:03:49:01 Ardy ARDY-PC Download Play VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:49:04 Ardy ARDY-PC Download Complete VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:49:04 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:03:49:12 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:03:49:12 Ardy ARDY-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:49:13 Ardy ARDY-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:49:13 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:03:49:16 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:03:49:16 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:03:49:16 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:03:49:29 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:50:03 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:50:03 Ardy ARDY-PC Launch 2013/1/28:03:50:03 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:03:50:06 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:50:04 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:50:04 Ardy ARDY-PC Launch 2013/1/28:03:50:04 Ardy ARDY-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:03:50:06 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:03:50:39 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:03:50:39 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:03:50:39 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:03:50:42 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:03:50:42 Ardy ARDY-PC Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:50:42 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:03:50:43 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:03:50:44 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:03:52:55 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:53:12 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:53:12 Ardy ARDY-PC Launch 2013/1/28:03:53:12 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:03:53:14 Ardy ARDY-PC === Setup ended ===
2013/1/28:03:53:13 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:03:53:13 Ardy ARDY-PC Launch 2013/1/28:03:53:13 Ardy ARDY-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:03:53:13 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:03:53:46 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:03:53:46 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:03:53:46 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:03:54:03 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:03:54:03 Ardy ARDY-PC Download Skipped VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:54:03 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:03:54:06 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:03:54:06 Ardy ARDY-PC Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:03:54:06 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:03:54:07 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:03:54:07 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:03:54:07 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:04:03:35 Ardy ARDY-PC === Setup ended ===
2013/1/28:13:59:44 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:13:59:44 Ardy ARDY-PC Launch 2013/1/28:13:59:44 Ardy ARDY-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-18679592 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/28:14:00:06 Ardy ARDY-PC === Setup ended ===
2013/1/28:13:59:46 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:13:59:46 Ardy ARDY-PC Launch 2013/1/28:13:59:47 Ardy ARDY-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:14:00:05 Ardy ARDY-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:14:00:06 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:14:00:59 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:14:01:00 Ardy ARDY-PC Download Play VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:02 Ardy ARDY-PC Download Complete VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:02 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:14:01:06 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:14:01:06 Ardy ARDY-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:07 Ardy ARDY-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:07 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:14:01:09 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:14:01:09 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis
I remove the all C++ program and restart my computer and tried to install the Revit, but the program re-install the C++ program and give me the error message. Please help. You can reach me at xxx-xxx-xxxx.
Edited by
Discussion_Admin
Please do not post personal information on this public peer forum.
Try installing the C++ manually from the file provided in the downloads or download and install direct from Microsoft.
http://support.microsoft.com/kb/2019667
I reinstalled the C++ 2008 and 2012 (please see attachment) and tried to install the revit again I got tis error message.
2013/1/28:13:59:46 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:13:59:46 Ardy ARDY-PC Launch 2013/1/28:13:59:47 Ardy ARDY-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:14:00:05 Ardy ARDY-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/28:14:00:06 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:14:00:51 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:14:00:59 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:14:01:00 Ardy ARDY-PC Download Play VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:02 Ardy ARDY-PC Download Complete VCREDIST2008X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:02 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:14:01:06 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:14:01:06 Ardy ARDY-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:07 Ardy ARDY-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/1/28:14:01:07 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:14:01:09 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:14:01:09 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:14:01:09 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:14:02:17 Ardy ARDY-PC === Setup ended ===
2013/1/28:14:47:09 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:14:47:09 Ardy ARDY-PC Launch 2013/1/28:14:47:36 Ardy ARDY-PC === Setup ended ===
2013/1/28:14:47:13 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:14:47:13 Ardy ARDY-PC Launch 2013/1/28:14:47:29 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:14:47:41 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:14:47:46 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:14:48:32 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:14:49:08 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:14:49:08 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:14:49:14 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:14:49:14 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:14:49:17 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:14:49:17 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:14:49:19 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:14:49:56 Ardy ARDY-PC === Setup ended ===
2013/1/28:14:50:37 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:14:50:37 Ardy ARDY-PC Launch 2013/1/28:14:50:43 Ardy ARDY-PC === Setup ended ===
2013/1/28:14:50:39 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:14:50:39 Ardy ARDY-PC Launch 2013/1/28:14:50:43 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:14:50:45 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:14:50:52 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:14:51:34 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:14:51:58 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:14:51:59 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:14:52:00 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:14:52:01 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:14:52:21 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:35:24 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:35:24 Ardy ARDY-PC Launch 2013/1/28:15:35:42 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:35:27 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:35:27 Ardy ARDY-PC Launch 2013/1/28:15:35:39 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:15:35:53 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:15:35:57 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:15:37:35 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:15:37:40 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:15:37:40 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:15:37:44 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:15:37:44 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:15:37:46 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:15:37:46 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:15:37:48 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:15:38:31 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:42:10 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:42:10 Ardy ARDY-PC Launch 2013/1/28:15:42:14 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:42:11 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:42:11 Ardy ARDY-PC Launch 2013/1/28:15:42:14 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:15:42:20 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:15:42:26 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:15:43:07 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:15:43:35 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:15:43:35 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/28:15:43:37 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/28:15:43:37 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:15:43:38 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:15:43:38 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/28:15:43:38 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:15:43:50 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:45:40 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:45:40 Ardy ARDY-PC Launch 2013/1/28:15:45:43 Ardy ARDY-PC === Setup ended ===
2013/1/28:15:45:41 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/28:15:45:41 Ardy ARDY-PC Launch 2013/1/28:15:45:44 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/28:15:45:45 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/28:15:45:49 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/28:15:51:04 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/28:15:51:10 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/28:15:51:10 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/28:15:51:11 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/28:15:51:11 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/28:15:51:30 Ardy ARDY-PC === Setup ended ===
2013/1/29:00:27:45 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:00:27:45 Ardy ARDY-PC Launch 2013/1/29:00:28:33 Ardy ARDY-PC === Setup ended ===
2013/1/29:00:58:17 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:00:58:17 Ardy ARDY-PC Launch 2013/1/29:00:58:47 Ardy ARDY-PC === Setup ended ===
2013/1/29:01:21:09 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:01:21:09 Ardy ARDY-PC Launch 2013/1/29:01:22:02 Ardy ARDY-PC === Setup ended ===
2013/1/29:01:21:41 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:01:21:41 Ardy ARDY-PC Launch 2013/1/29:01:22:04 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/29:01:22:11 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/29:01:22:21 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/29:01:23:38 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/29:01:23:42 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/29:01:23:43 Ardy ARDY-PC Installing Microsoft Visual C++ 2008 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\Ardy\AppData\Local\Temp\vcredist_x64_2008.log 2013/1/29:01:23:53 Ardy ARDY-PC Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded 2013/1/29:01:23:53 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/29:01:24:00 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/29:01:24:00 Ardy ARDY-PC Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/29:01:24:03 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/29:01:28:49 Ardy ARDY-PC === Setup ended ===
2013/1/29:16:21:11 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:16:21:11 Ardy ARDY-PC Launch 2013/1/29:16:21:42 Ardy ARDY-PC === Setup ended ===
2013/1/29:16:21:19 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:16:21:19 Ardy ARDY-PC Launch 2013/1/29:16:21:39 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/29:16:22:20 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/29:16:22:24 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/29:16:23:00 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/29:16:23:06 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/29:16:23:06 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/29:16:23:09 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Those aren't the problematic versions. It's this one:
See if you can install that manually. If not, you might need to use the .NET Cleanup Tool and try again. Generally speaking, this is not an easy fix.
Also, this software is not supported with Windows 8 or Vista, so if you happen to be running either or those, this is the reason for your failure.
I manually installed the C++5 and I got error message again. Please see attachment
2013/1/29:16:21:19 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:16:21:19 Ardy ARDY-PC Launch 2013/1/29:16:21:39 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/29:16:22:20 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/29:16:22:24 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/29:16:23:00 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/29:16:23:06 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/29:16:23:06 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/29:16:23:09 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/29:16:23:11 Ardy ARDY-PC PageOpen InstallCompleteDialog 2013/1/29:16:36:16 Ardy ARDY-PC === Setup ended ===
2013/1/29:17:01:04 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:17:01:04 Ardy ARDY-PC Launch 2013/1/29:17:01:20 Ardy ARDY-PC === Setup ended ===
2013/1/29:17:01:12 Ardy ARDY-PC === Setup started on ARDY-PC by Ardy === 2013/1/29:17:01:12 Ardy ARDY-PC Launch 2013/1/29:17:01:19 Ardy ARDY-PC PageOpen LaunchDialog 2013/1/29:17:01:23 Ardy ARDY-PC PageOpen LicenseDialog 2013/1/29:17:01:27 Ardy ARDY-PC PageOpen ProductInfoDialog 2013/1/29:17:02:02 Ardy ARDY-PC PageOpen ProductSelectionDialog2 2013/1/29:17:02:08 Ardy ARDY-PC PageOpen FullProgressDialog 2013/1/29:17:02:08 Ardy ARDY-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ardy\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/29:17:02:09 Ardy ARDY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
What is your OS?
Well if you manually installed C++ 2005 successfully, then you can try the setup.ini modification in the second post of my KB link here. It is severely advanced.
Good Luck!
@Anonymous wrote:
i have the same problem. Can you help me?
Try installing your language pack manually.
Good Luck!
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M Launch
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A8nv7QAB /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/12:21:39:49 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AIE4BA.tmp
2017/1/12:21:40:08 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/12:21:39:50 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/12:21:39:50 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/12:21:39:50 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AIE4BA.tmp
2017/1/12:21:39:50 camer DESKTOP-OBLKB8M Launch
2017/1/12:21:39:52 camer DESKTOP-OBLKB8M Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/12:21:39:52 camer DESKTOP-OBLKB8M Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/12:21:39:52 camer DESKTOP-OBLKB8M Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/12:21:40:08 camer DESKTOP-OBLKB8M Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/12:21:40:08 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/12:21:40:28 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/12:21:40:28 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/12:21:41:03 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/12:21:41:05 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/12:21:41:05 camer DESKTOP-OBLKB8M Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/12:21:41:05 camer DESKTOP-OBLKB8M Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/12:21:41:05 camer DESKTOP-OBLKB8M Download Play VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/12:21:41:08 camer DESKTOP-OBLKB8M Download Complete VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/12:21:41:08 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/12:21:41:38 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/12:21:41:38 camer DESKTOP-OBLKB8M Download Play VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/12:21:41:41 camer DESKTOP-OBLKB8M Download Complete VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/12:21:41:41 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/12:21:41:54 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/12:21:41:54 camer DESKTOP-OBLKB8M Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/12:21:41:56 camer DESKTOP-OBLKB8M Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/12:21:41:56 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/12:21:42:01 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/12:21:42:01 camer DESKTOP-OBLKB8M Download Play CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:42:19 camer DESKTOP-OBLKB8M Download Complete CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:42:19 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/12:21:42:29 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/12:21:42:30 camer DESKTOP-OBLKB8M Download Play CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:42:53 camer DESKTOP-OBLKB8M Download Complete CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:42:53 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/12:21:42:59 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/12:21:43:00 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:46:33 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/12:21:46:33 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/12:21:46:42 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/12:21:46:56 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/12:21:46:56 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/12:21:46:56 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/12:21:46:56 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/12:21:46:56 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/12:22:01:17 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M CommandLine
2017/1/15:09:17:28 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI67C0.tmp
2017/1/15:09:17:39 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:17:31 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:17:31 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:17:31 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI67C0.tmp
2017/1/15:09:17:31 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:17:40 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M CommandLine
2017/1/15:09:18:24 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI46B6.tmp
2017/1/15:09:18:30 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:18:25 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:18:25 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:18:25 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI46B6.tmp
2017/1/15:09:18:25 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:09:18:53 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AIB2ED.tmp
2017/1/15:09:18:57 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:18:56 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:09:18:56 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:09:18:57 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:09:19:04 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:09:19:04 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:09:19:17 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:09:19:21 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:09:19:21 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:09:19:21 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:09:19:21 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:09:19:41 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:09:19:41 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:09:19:41 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:09:20:34 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:09:20:34 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:09:20:34 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:09:20:49 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:09:20:49 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:20:51 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:09:21:17 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:09:21:17 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:21:18 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:09:21:32 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:09:21:37 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:26:19 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:26:19 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:09:26:30 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:09:26:45 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:09:26:45 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:09:26:45 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:09:26:45 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/15:09:26:45 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/15:09:29:53 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:09:30:21 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI38F5.tmp
2017/1/15:09:30:23 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI38F5.tmp
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M Launch
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:09:30:22 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:09:30:23 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:09:30:26 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:09:30:26 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:09:30:52 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:09:30:53 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:09:30:53 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:09:30:54 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:09:30:54 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:09:30:54 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:09:30:54 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:09:30:54 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:09:30:55 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:09:30:55 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:09:30:55 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:09:30:57 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:09:30:57 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:30:57 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:09:31:08 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:09:31:08 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:31:08 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:09:31:14 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:09:31:14 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:35:17 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:09:35:17 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:09:35:26 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:09:35:41 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:09:35:41 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:09:35:41 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:09:35:41 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/15:09:35:41 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/15:11:21:44 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:11:21:56 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI5F98.tmp
2017/1/15:11:21:57 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:21:57 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:21:57 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:21:57 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:11:22:02 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:11:22:02 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:11:22:24 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:11:22:25 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:22:26 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:11:22:27 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:11:22:27 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:11:22:27 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:11:22:29 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:11:22:29 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:22:29 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:22:38 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:11:22:38 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:22:38 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:22:44 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:11:22:45 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:26:57 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:26:57 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:11:27:06 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:11:27:20 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:11:27:20 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:11:27:20 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:11:27:20 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/15:11:27:21 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/15:11:30:37 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI3ADA.tmp
2017/1/15:11:36:00 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:35:59 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:36:00 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:11:36:04 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:11:36:04 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:11:37:40 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:11:37:41 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:11:37:41 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:11:37:41 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:37:41 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:11:37:42 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:11:37:45 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:11:37:45 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:37:45 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:37:53 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:11:37:53 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:37:53 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:37:59 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:11:37:59 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:41:50 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:41:50 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:11:41:59 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:11:42:14 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:11:42:14 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:11:42:14 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:11:42:14 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/15:11:42:15 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/15:11:44:33 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:11:44:39 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI2CE9.tmp
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI2CE9.tmp
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:44:40 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M CommandLine
2017/1/15:11:54:59 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI865C.tmp
2017/1/15:11:55:04 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:55:00 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:55:00 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:55:00 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI865C.tmp
2017/1/15:11:55:00 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:55:45 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:55:45 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:55:45 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI3A1C.tmp
2017/1/15:11:55:45 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:56:14 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M CommandLine
2017/1/15:11:55:44 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI3A1C.tmp
2017/1/15:11:56:15 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9JF3QAN /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:11:56:36 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI471.tmp
2017/1/15:11:56:38 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AI471.tmp
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M Launch
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:56:37 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:11:56:39 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:11:56:57 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:11:56:57 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:11:57:19 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:11:57:21 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:11:57:21 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:11:57:21 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:57:21 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:11:57:28 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:11:57:28 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:11:57:28 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:11:57:29 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:11:57:29 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:11:57:29 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:11:57:36 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:11:57:36 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:57:37 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:57:50 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:11:57:50 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:11:57:51 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:11:58:05 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:11:58:05 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:03:33 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:03:33 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:12:03:46 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:12:04:08 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:12:04:08 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:12:04:08 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:12:04:08 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/15:12:04:09 camer DESKTOP-OBLKB8M PageOpen InstallCompleteDialog
2017/1/15:12:09:22 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M === Setup started on DESKTOP-OBLKB8M by camer ===
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M Path_Length: 153
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M Launch
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M CommandLine /akamai /sid a1b3A00000A9HznQAF /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi..."
2017/1/15:12:30:09 camer DESKTOP-OBLKB8M Current Directory C:\Users\camer\AppData\Local\Temp\_AIBAA0.tmp
2017/1/15:12:30:10 camer DESKTOP-OBLKB8M === Setup ended ===
2017/1/15:12:30:10 camer DESKTOP-OBLKB8M Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:12:30:10 camer DESKTOP-OBLKB8M Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SE...
2017/1/15:12:30:10 camer DESKTOP-OBLKB8M PageOpen LaunchDialog
2017/1/15:12:30:13 camer DESKTOP-OBLKB8M PageOpen LicenseDialog
2017/1/15:12:30:13 camer DESKTOP-OBLKB8M PageOpen ProductInfoDialog
2017/1/15:12:30:33 camer DESKTOP-OBLKB8M PageOpen ProductSelectionDialog2
2017/1/15:12:30:35 camer DESKTOP-OBLKB8M PageOpen FullProgressDialog
2017/1/15:12:30:35 camer DESKTOP-OBLKB8M Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/ST...
2017/1/15:12:30:35 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:12:30:35 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/1/15:12:30:35 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/15:12:30:36 camer DESKTOP-OBLKB8M Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VC...
2017/1/15:12:30:36 camer DESKTOP-OBLKB8M Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/1/15:12:30:36 camer DESKTOP-OBLKB8M Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/15:12:30:36 camer DESKTOP-OBLKB8M Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DI...
2017/1/15:12:30:36 camer DESKTOP-OBLKB8M Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:12:30:38 camer DESKTOP-OBLKB8M Install DirectX® Runtime Succeeded
2017/1/15:12:30:38 camer DESKTOP-OBLKB8M Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:30:38 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:12:30:47 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 Succeeded
2017/1/15:12:30:47 camer DESKTOP-OBLKB8M Download Skipped CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:30:47 camer DESKTOP-OBLKB8M Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/15:12:30:54 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:12:30:54 camer DESKTOP-OBLKB8M Download Play CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:35:20 camer DESKTOP-OBLKB8M Download Aborted CMILM http://efulfillment.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM...
2017/1/15:12:35:20 camer DESKTOP-OBLKB8M Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2017/1/15:12:35:29 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/1/15:12:35:43 camer DESKTOP-OBLKB8M Rollback Autodesk® Material Library 2016 Succeeded
2017/1/15:12:35:43 camer DESKTOP-OBLKB8M Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/15:12:35:43 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:12:35:43 camer DESKTOP-OBLKB8M Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
@Anonymous
Welcome to the community...
Your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Tive um problema parecido. Alguém poderia ajudar?
2017/6/5:15:10:25 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/5:15:10:25 lucas X556URK Path_Length: 179
2017/6/5:15:10:25 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/5:15:10:25 lucas X556URK Launch
2017/6/5:15:10:25 lucas X556URK CommandLine /akamai /sid SESSION_ID /trialMode /url "http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/Inventor_..."
2017/6/5:15:10:25 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp
2017/6/5:16:25:13 lucas X556URK === Setup ended ===
2017/6/5:15:10:27 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/5:15:10:27 lucas X556URK Path_Length: 179
2017/6/5:15:10:27 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp
2017/6/5:15:10:27 lucas X556URK Launch
2017/6/5:15:10:37 lucas X556URK Download Play SETUPMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:15:10:38 lucas X556URK Download Complete SETUPMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:15:10:38 lucas X556URK Download Play SETUP_CONFIG http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:15:44:48 lucas X556URK Download Error SETUP_CONFIG <B>Erro de rede, não é possível descarregar</B>Verifique as conexões e tente novamente. Deseja tentar novamente? http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:15:44:58 lucas X556URK Download Error SETUP_CONFIG <B>Erro de rede, não é possível descarregar</B>Verifique as conexões e tente novamente. Deseja tentar novamente? http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:25:11 lucas X556URK Download Complete SETUP_CONFIG http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:25:13 lucas X556URK PageOpen LaunchDialog
2017/6/5:16:32:47 lucas X556URK Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp\Setup\AcadeUI.dll
2017/6/5:16:32:47 lucas X556URK Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O banco de dados de fabricantes está disponível para download. URLTitle=Saiba mais URLLink=https://accounts.autodesk.com/
2017/6/5:16:32:55 lucas X556URK PageOpen LicenseDialog
2017/6/5:16:42:33 lucas X556URK PageOpen ProductInfoDialog
2017/6/5:16:42:33 lucas X556URK PageOpen InventorFlavorSelectionDialog
2017/6/5:16:42:33 lucas X556URK Inventorui==DefaultLanguage: pt-br
2017/6/5:16:42:33 lucas X556URK Inventorui==InstallName: INVENTOR
2017/6/5:16:42:33 lucas X556URK Inventorui==ProductName: Autodesk Inventor 2018
2017/6/5:16:42:33 lucas X556URK Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/6/5:16:42:33 lucas X556URK Inventorui==DeploymentName:
2017/6/5:16:42:33 lucas X556URK Inventorui==SetupTitle: Autodesk Inventor 2018
2017/6/5:16:42:33 lucas X556URK Inventorui==ConfigTransform:
2017/6/5:16:42:33 lucas X556URK Inventorui==ExeParams:
2017/6/5:16:42:33 lucas X556URK Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/6/5:16:42:33 lucas X556URK Inventorui==SupportLink:
2017/6/5:16:42:33 lucas X556URK Inventorui==InfotainmentLink:
2017/6/5:16:42:33 lucas X556URK Inventorui==MsiFileName: inventor.msi
2017/6/5:16:42:33 lucas X556URK Inventorui==AdminImageConfigName: Imgx64
2017/6/5:16:42:33 lucas X556URK Inventorui==AdminImageRoot:
2017/6/5:16:42:33 lucas X556URK Inventorui==GetBaseDeploymentName:
2017/6/5:16:42:33 lucas X556URK Inventorui==DeploymentLocation:
2017/6/5:16:42:33 lucas X556URK Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-ptb
2017/6/5:16:42:33 lucas X556URK Inventorui==InstallDeploymentShortcut:
2017/6/5:16:42:33 lucas X556URK Inventorui==ModifyDeploymentShortcut:
2017/6/5:16:42:33 lucas X556URK Inventorui==SetupLockType: 2
2017/6/5:16:42:33 lucas X556URK Inventorui==SetupNetworkType: 0
2017/6/5:16:42:33 lucas X556URK Inventorui==SystemLocale: 1046
2017/6/5:16:42:33 lucas X556URK Inventorui==EvalMsiFilePath: C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp\SetupRes\eval.msi
2017/6/5:16:42:33 lucas X556URK Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2018\EULA
2017/6/5:16:42:33 lucas X556URK Inventorui==InstallLogPath: C:\Users\lucas\AppData\Local\Temp\Inventor2018Install.log
2017/6/5:16:42:33 lucas X556URK Inventorui==ConfigFile: C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp\Setup.ini
2017/6/5:16:42:33 lucas X556URK Inventorui==SetupPath: C:\Users\lucas\AppData\Local\Temp\_AICA2B.tmp\
2017/6/5:16:42:33 lucas X556URK Inventorui==NetworkLogPath:
2017/6/5:16:42:33 lucas X556URK Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2018
2017/6/5:16:42:39 lucas X556URK Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/6/5:16:42:39 lucas X556URK PageOpen ProductSelectionDialog2
2017/6/5:16:45:22 lucas X556URK PageOpen FullProgressDialog
2017/6/5:16:45:23 lucas X556URK Download Play STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:45:23 lucas X556URK Download Complete STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:45:24 lucas X556URK Download Play VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:46:19 lucas X556URK Download Complete VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:46:19 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/6/5:16:46:21 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 return code: 0
2017/6/5:16:46:21 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 Succeeded
2017/6/5:16:46:22 lucas X556URK Download Play VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:47:25 lucas X556URK Download Complete VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:47:25 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/6/5:16:47:26 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 return code: 0
2017/6/5:16:47:26 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 Succeeded
2017/6/5:16:47:27 lucas X556URK Download Play VCREDIST2013X86 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:48:25 lucas X556URK Download Complete VCREDIST2013X86 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:48:25 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x86): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2013.log
2017/6/5:16:48:26 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x86) return code: 0
2017/6/5:16:48:26 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x86) Succeeded
2017/6/5:16:48:26 lucas X556URK Download Play VCREDIST2013X64 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:49:30 lucas X556URK Download Complete VCREDIST2013X64 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:49:30 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x64): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2013.log
2017/6/5:16:49:31 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x64) return code: 0
2017/6/5:16:49:31 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x64) Succeeded
2017/6/5:16:49:31 lucas X556URK Download Play UCRT http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:50:24 lucas X556URK Download Complete UCRT http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:50:24 lucas X556URK Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/6/5:16:50:24 lucas X556URK Universal C Runtime (KB3118401) return code: 0
2017/6/5:16:50:24 lucas X556URK Install Universal C Runtime (KB3118401) Succeeded
2017/6/5:16:50:25 lucas X556URK Download Play VCREDIST2015X86UPD3 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:52:16 lucas X556URK Download Complete VCREDIST2015X86UPD3 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:52:16 lucas X556URK Installing Microsoft Visual C++ 2015 Redistribuível (x86) Atualização 3: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2015UPD3\vcredist_x86.exe" /install /q /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2015_UPD3.log
2017/6/5:16:52:22 lucas X556URK Microsoft Visual C++ 2015 Redistribuível (x86) Atualização 3 return code: 0
2017/6/5:16:52:22 lucas X556URK Install Microsoft Visual C++ 2015 Redistribuível (x86) Atualização 3 Succeeded
2017/6/5:16:52:22 lucas X556URK Download Play CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:52:48 lucas X556URK Download User Pause CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:16:52:48 lucas X556URK Download Paused CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:16:18 lucas X556URK Download User Resume CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:20:47 lucas X556URK Download Aborted CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:20:47 lucas X556URK Install Biblioteca de materiais do Autodesk® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/6/5:18:20:48 lucas X556URK Rollback Universal C Runtime (KB3118401) Failed Failure is ignored, Result=1619
2017/6/5:18:20:48 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x64) Failed Installation aborted, Result=1619
2017/6/5:18:20:48 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x86) Failed Installation aborted, Result=1619
2017/6/5:18:20:50 lucas X556URK PageOpen InstallCompleteDialog
2017/6/5:18:21:12 lucas X556URK === Setup ended ===
2017/6/5:18:22:21 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/5:18:22:21 lucas X556URK Path_Length: 179
2017/6/5:18:22:21 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/5:18:22:21 lucas X556URK Launch
2017/6/5:18:22:21 lucas X556URK CommandLine /akamai /sid SESSION_ID /trialMode /url "http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/Inventor_..."
2017/6/5:18:22:21 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp
2017/6/5:18:22:28 lucas X556URK === Setup ended ===
2017/6/5:18:22:25 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/5:18:22:25 lucas X556URK Path_Length: 179
2017/6/5:18:22:25 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp
2017/6/5:18:22:25 lucas X556URK Launch
2017/6/5:18:22:27 lucas X556URK Download Skipped SETUPMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:22:27 lucas X556URK Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:22:29 lucas X556URK PageOpen LaunchDialog
2017/6/5:18:22:42 lucas X556URK Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp\Setup\AcadeUI.dll
2017/6/5:18:22:42 lucas X556URK Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O banco de dados de fabricantes está disponível para download. URLTitle=Saiba mais URLLink=https://accounts.autodesk.com/
2017/6/5:18:22:51 lucas X556URK PageOpen LicenseDialog
2017/6/5:18:24:17 lucas X556URK PageOpen ProductInfoDialog
2017/6/5:18:24:17 lucas X556URK PageOpen InventorFlavorSelectionDialog
2017/6/5:18:24:17 lucas X556URK Inventorui==DefaultLanguage: pt-br
2017/6/5:18:24:17 lucas X556URK Inventorui==InstallName: INVENTOR
2017/6/5:18:24:17 lucas X556URK Inventorui==ProductName: Autodesk Inventor 2018
2017/6/5:18:24:17 lucas X556URK Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/6/5:18:24:17 lucas X556URK Inventorui==DeploymentName:
2017/6/5:18:24:17 lucas X556URK Inventorui==SetupTitle: Autodesk Inventor 2018
2017/6/5:18:24:17 lucas X556URK Inventorui==ConfigTransform:
2017/6/5:18:24:17 lucas X556URK Inventorui==ExeParams:
2017/6/5:18:24:17 lucas X556URK Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/6/5:18:24:17 lucas X556URK Inventorui==SupportLink:
2017/6/5:18:24:17 lucas X556URK Inventorui==InfotainmentLink:
2017/6/5:18:24:17 lucas X556URK Inventorui==MsiFileName: inventor.msi
2017/6/5:18:24:17 lucas X556URK Inventorui==AdminImageConfigName: Imgx64
2017/6/5:18:24:17 lucas X556URK Inventorui==AdminImageRoot:
2017/6/5:18:24:17 lucas X556URK Inventorui==GetBaseDeploymentName:
2017/6/5:18:24:17 lucas X556URK Inventorui==DeploymentLocation:
2017/6/5:18:24:17 lucas X556URK Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-ptb
2017/6/5:18:24:17 lucas X556URK Inventorui==InstallDeploymentShortcut:
2017/6/5:18:24:17 lucas X556URK Inventorui==ModifyDeploymentShortcut:
2017/6/5:18:24:17 lucas X556URK Inventorui==SetupLockType: 2
2017/6/5:18:24:17 lucas X556URK Inventorui==SetupNetworkType: 0
2017/6/5:18:24:17 lucas X556URK Inventorui==SystemLocale: 1046
2017/6/5:18:24:17 lucas X556URK Inventorui==EvalMsiFilePath: C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp\SetupRes\eval.msi
2017/6/5:18:24:17 lucas X556URK Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2018\EULA
2017/6/5:18:24:17 lucas X556URK Inventorui==InstallLogPath: C:\Users\lucas\AppData\Local\Temp\Inventor2018Install.log
2017/6/5:18:24:17 lucas X556URK Inventorui==ConfigFile: C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp\Setup.ini
2017/6/5:18:24:17 lucas X556URK Inventorui==SetupPath: C:\Users\lucas\AppData\Local\Temp\_AI7F40.tmp\
2017/6/5:18:24:17 lucas X556URK Inventorui==NetworkLogPath:
2017/6/5:18:24:17 lucas X556URK Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2018
2017/6/5:18:24:30 lucas X556URK Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/6/5:18:24:30 lucas X556URK PageOpen ProductSelectionDialog2
2017/6/5:18:24:36 lucas X556URK PageOpen FullProgressDialog
2017/6/5:18:24:37 lucas X556URK Download Play STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:38 lucas X556URK Download Complete STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:38 lucas X556URK Download Skipped VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:38 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/6/5:18:24:39 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 return code: 0
2017/6/5:18:24:39 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 Succeeded
2017/6/5:18:24:39 lucas X556URK Download Skipped VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:39 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/6/5:18:24:39 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 return code: 0
2017/6/5:18:24:39 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 Succeeded
2017/6/5:18:24:39 lucas X556URK Download Skipped VCREDIST2013X86 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:39 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x86): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2013.log
2017/6/5:18:24:40 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x86) return code: 0
2017/6/5:18:24:40 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x86) Succeeded
2017/6/5:18:24:40 lucas X556URK Download Skipped VCREDIST2013X64 http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:24:40 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x64): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2013.log
2017/6/5:18:24:41 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x64) return code: 0
2017/6/5:18:24:41 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x64) Succeeded
2017/6/5:18:24:41 lucas X556URK Download Play CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:30:33 lucas X556URK Download Aborted CM http://trial2.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833D5C...
2017/6/5:18:30:33 lucas X556URK Install Biblioteca de materiais do Autodesk® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/6/5:18:30:33 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x64) Failed Installation aborted, Result=1619
2017/6/5:18:30:33 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x86) Failed Installation aborted, Result=1619
2017/6/5:18:30:38 lucas X556URK PageOpen InstallCompleteDialog
2017/6/5:22:57:43 lucas X556URK === Setup ended ===
2017/6/7:18:53:52 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/7:18:53:52 lucas X556URK Path_Length: 179
2017/6/7:18:53:52 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/7:18:53:52 lucas X556URK Launch
2017/6/7:18:53:52 lucas X556URK CommandLine /PK 797J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/Invent..."
2017/6/7:18:53:52 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp
2017/6/7:19:15:59 lucas X556URK === Setup ended ===
2017/6/7:18:53:53 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/7:18:53:53 lucas X556URK Path_Length: 179
2017/6/7:18:53:53 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp
2017/6/7:18:53:53 lucas X556URK Launch
2017/6/7:18:53:56 lucas X556URK Download Play SETUPMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:18:53:57 lucas X556URK Download Complete SETUPMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:18:53:58 lucas X556URK Download Play SETUP_CONFIG https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:15:58 lucas X556URK Download Complete SETUP_CONFIG https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:15:59 lucas X556URK PageOpen LaunchDialog
2017/6/7:19:18:05 lucas X556URK Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp\Setup\AcadeUI.dll
2017/6/7:19:18:05 lucas X556URK Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O banco de dados de fabricantes está disponível para download. URLTitle=Saiba mais URLLink=https://accounts.autodesk.com/
2017/6/7:19:18:17 lucas X556URK PageOpen LicenseDialog
2017/6/7:19:18:17 lucas X556URK PageOpen ProductInfoDialog
2017/6/7:19:18:18 lucas X556URK PageOpen InventorFlavorSelectionDialog
2017/6/7:19:18:18 lucas X556URK Inventorui==DefaultLanguage: pt-br
2017/6/7:19:18:18 lucas X556URK Inventorui==InstallName: INVENTOR
2017/6/7:19:18:18 lucas X556URK Inventorui==ProductName: Autodesk Inventor 2018
2017/6/7:19:18:18 lucas X556URK Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/6/7:19:18:18 lucas X556URK Inventorui==DeploymentName:
2017/6/7:19:18:18 lucas X556URK Inventorui==SetupTitle: Autodesk Inventor 2018
2017/6/7:19:18:18 lucas X556URK Inventorui==ConfigTransform:
2017/6/7:19:18:18 lucas X556URK Inventorui==ExeParams:
2017/6/7:19:18:18 lucas X556URK Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/6/7:19:18:18 lucas X556URK Inventorui==SupportLink:
2017/6/7:19:18:18 lucas X556URK Inventorui==InfotainmentLink:
2017/6/7:19:18:18 lucas X556URK Inventorui==MsiFileName: inventor.msi
2017/6/7:19:18:18 lucas X556URK Inventorui==AdminImageConfigName: Imgx64
2017/6/7:19:18:18 lucas X556URK Inventorui==AdminImageRoot:
2017/6/7:19:18:18 lucas X556URK Inventorui==GetBaseDeploymentName:
2017/6/7:19:18:18 lucas X556URK Inventorui==DeploymentLocation:
2017/6/7:19:18:18 lucas X556URK Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-ptb
2017/6/7:19:18:18 lucas X556URK Inventorui==InstallDeploymentShortcut:
2017/6/7:19:18:18 lucas X556URK Inventorui==ModifyDeploymentShortcut:
2017/6/7:19:18:18 lucas X556URK Inventorui==SetupLockType: 2
2017/6/7:19:18:18 lucas X556URK Inventorui==SetupNetworkType: 0
2017/6/7:19:18:18 lucas X556URK Inventorui==SystemLocale: 1046
2017/6/7:19:18:18 lucas X556URK Inventorui==EvalMsiFilePath: C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp\SetupRes\eval.msi
2017/6/7:19:18:18 lucas X556URK Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2018\EULA
2017/6/7:19:18:18 lucas X556URK Inventorui==InstallLogPath: C:\Users\lucas\AppData\Local\Temp\Inventor2018Install.log
2017/6/7:19:18:18 lucas X556URK Inventorui==ConfigFile: C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp\Setup.ini
2017/6/7:19:18:18 lucas X556URK Inventorui==SetupPath: C:\Users\lucas\AppData\Local\Temp\_AI142A.tmp\
2017/6/7:19:18:18 lucas X556URK Inventorui==NetworkLogPath:
2017/6/7:19:18:18 lucas X556URK Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2018
2017/6/7:19:22:29 lucas X556URK Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/6/7:19:22:29 lucas X556URK PageOpen ProductSelectionDialog2
2017/6/7:19:24:47 lucas X556URK PageOpen FullProgressDialog
2017/6/7:19:24:48 lucas X556URK Download Play STARTMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:24:49 lucas X556URK Download Complete STARTMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:24:50 lucas X556URK Download Play VCREDIST2012X86UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:10 lucas X556URK Download Complete VCREDIST2012X86UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:10 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/6/7:19:25:11 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 return code: 0
2017/6/7:19:25:11 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 Succeeded
2017/6/7:19:25:12 lucas X556URK Download Play VCREDIST2012X64UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:32 lucas X556URK Download Complete VCREDIST2012X64UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:32 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/6/7:19:25:33 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 return code: 0
2017/6/7:19:25:33 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 Succeeded
2017/6/7:19:25:35 lucas X556URK Download Play VCREDIST2013X86 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:54 lucas X556URK Download Complete VCREDIST2013X86 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:25:54 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x86): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2013.log
2017/6/7:19:25:55 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x86) return code: 0
2017/6/7:19:25:55 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x86) Succeeded
2017/6/7:19:25:56 lucas X556URK Download Play VCREDIST2013X64 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:26:15 lucas X556URK Download Complete VCREDIST2013X64 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:26:15 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x64): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2013.log
2017/6/7:19:26:16 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x64) return code: 0
2017/6/7:19:26:16 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x64) Succeeded
2017/6/7:19:26:17 lucas X556URK Download Play CM https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:38:59 lucas X556URK Download Aborted CM https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/7:19:38:59 lucas X556URK Install Biblioteca de materiais do Autodesk® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/6/7:19:39:00 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x64) Failed Installation aborted, Result=1619
2017/6/7:19:39:00 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x86) Failed Installation aborted, Result=1619
2017/6/8:08:14:27 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:14:27 lucas X556URK Path_Length: 179
2017/6/8:08:14:27 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/8:08:14:27 lucas X556URK Launch
2017/6/8:08:14:27 lucas X556URK CommandLine
2017/6/8:08:14:27 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI6EBD.tmp
2017/6/8:08:14:49 lucas X556URK === Setup ended ===
2017/6/8:08:14:34 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:14:34 lucas X556URK Path_Length: 179
2017/6/8:08:14:34 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AI6EBD.tmp
2017/6/8:08:14:34 lucas X556URK Launch
2017/6/8:08:14:50 lucas X556URK === Setup ended ===
2017/6/8:08:16:07 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:16:07 lucas X556URK Path_Length: 179
2017/6/8:08:16:07 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/8:08:16:07 lucas X556URK Launch
2017/6/8:08:16:07 lucas X556URK CommandLine
2017/6/8:08:16:07 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AIF609.tmp
2017/6/8:08:16:31 lucas X556URK === Setup ended ===
2017/6/8:08:16:13 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:16:13 lucas X556URK Path_Length: 179
2017/6/8:08:16:13 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AIF609.tmp
2017/6/8:08:16:13 lucas X556URK Launch
2017/6/8:08:16:32 lucas X556URK === Setup ended ===
2017/6/8:08:18:01 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:18:01 lucas X556URK Path_Length: 179
2017/6/8:08:18:01 lucas X556URK Current Directory C:\Autodesk\Inventor_2018_Portuguese_Brazil_Win_64bit_wi_pt-BR
2017/6/8:08:18:01 lucas X556URK Launch
2017/6/8:08:18:01 lucas X556URK CommandLine /PK 797J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/Invent..."
2017/6/8:08:18:01 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp
2017/6/8:08:18:14 lucas X556URK === Setup ended ===
2017/6/8:08:18:08 lucas X556URK === Setup started on X556URK by lucas ===
2017/6/8:08:18:08 lucas X556URK Path_Length: 179
2017/6/8:08:18:08 lucas X556URK Current Directory C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp
2017/6/8:08:18:08 lucas X556URK Launch
2017/6/8:08:18:11 lucas X556URK Download Skipped SETUPMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:18:11 lucas X556URK Download Skipped SETUP_CONFIG https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:18:15 lucas X556URK PageOpen LaunchDialog
2017/6/8:08:19:30 lucas X556URK Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp\Setup\AcadeUI.dll
2017/6/8:08:19:30 lucas X556URK Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O banco de dados de fabricantes está disponível para download. URLTitle=Saiba mais URLLink=https://accounts.autodesk.com/
2017/6/8:08:19:50 lucas X556URK PageOpen LicenseDialog
2017/6/8:08:19:50 lucas X556URK PageOpen ProductInfoDialog
2017/6/8:08:19:50 lucas X556URK PageOpen InventorFlavorSelectionDialog
2017/6/8:08:19:50 lucas X556URK Inventorui==DefaultLanguage: pt-br
2017/6/8:08:19:50 lucas X556URK Inventorui==InstallName: INVENTOR
2017/6/8:08:19:50 lucas X556URK Inventorui==ProductName: Autodesk Inventor 2018
2017/6/8:08:19:50 lucas X556URK Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/6/8:08:19:50 lucas X556URK Inventorui==DeploymentName:
2017/6/8:08:19:50 lucas X556URK Inventorui==SetupTitle: Autodesk Inventor 2018
2017/6/8:08:19:50 lucas X556URK Inventorui==ConfigTransform:
2017/6/8:08:19:50 lucas X556URK Inventorui==ExeParams:
2017/6/8:08:19:50 lucas X556URK Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/6/8:08:19:50 lucas X556URK Inventorui==SupportLink:
2017/6/8:08:19:50 lucas X556URK Inventorui==InfotainmentLink:
2017/6/8:08:19:50 lucas X556URK Inventorui==MsiFileName: inventor.msi
2017/6/8:08:19:50 lucas X556URK Inventorui==AdminImageConfigName: Imgx64
2017/6/8:08:19:50 lucas X556URK Inventorui==AdminImageRoot:
2017/6/8:08:19:50 lucas X556URK Inventorui==GetBaseDeploymentName:
2017/6/8:08:19:50 lucas X556URK Inventorui==DeploymentLocation:
2017/6/8:08:19:50 lucas X556URK Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-ptb
2017/6/8:08:19:50 lucas X556URK Inventorui==InstallDeploymentShortcut:
2017/6/8:08:19:50 lucas X556URK Inventorui==ModifyDeploymentShortcut:
2017/6/8:08:19:50 lucas X556URK Inventorui==SetupLockType: 2
2017/6/8:08:19:50 lucas X556URK Inventorui==SetupNetworkType: 0
2017/6/8:08:19:50 lucas X556URK Inventorui==SystemLocale: 1046
2017/6/8:08:19:50 lucas X556URK Inventorui==EvalMsiFilePath: C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp\SetupRes\eval.msi
2017/6/8:08:19:50 lucas X556URK Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2018\EULA
2017/6/8:08:19:50 lucas X556URK Inventorui==InstallLogPath: C:\Users\lucas\AppData\Local\Temp\Inventor2018Install.log
2017/6/8:08:19:50 lucas X556URK Inventorui==ConfigFile: C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp\Setup.ini
2017/6/8:08:19:50 lucas X556URK Inventorui==SetupPath: C:\Users\lucas\AppData\Local\Temp\_AIAEE4.tmp\
2017/6/8:08:19:50 lucas X556URK Inventorui==NetworkLogPath:
2017/6/8:08:19:50 lucas X556URK Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2018
2017/6/8:08:19:55 lucas X556URK Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/6/8:08:19:55 lucas X556URK PageOpen ProductSelectionDialog2
2017/6/8:08:20:10 lucas X556URK PageOpen FullProgressDialog
2017/6/8:08:20:12 lucas X556URK Download Play STARTMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:18 lucas X556URK Download Complete STARTMARKER https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:18 lucas X556URK Download Skipped VCREDIST2012X86UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:18 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/6/8:08:20:21 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 return code: 0
2017/6/8:08:20:21 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x86) Update 4 Succeeded
2017/6/8:08:20:21 lucas X556URK Download Skipped VCREDIST2012X64UPD4 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:21 lucas X556URK Installing Microsoft Visual C++ 2012 Redistribuível (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/6/8:08:20:22 lucas X556URK Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 return code: 0
2017/6/8:08:20:22 lucas X556URK Install Microsoft Visual C++ 2012 Redistribuível (x64) Update 4 Succeeded
2017/6/8:08:20:22 lucas X556URK Download Skipped VCREDIST2013X86 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:22 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x86): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x86_2013.log
2017/6/8:08:20:23 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x86) return code: 0
2017/6/8:08:20:23 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x86) Succeeded
2017/6/8:08:20:24 lucas X556URK Download Skipped VCREDIST2013X64 https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:20:24 lucas X556URK Installing Microsoft Visual C++ 2013 Redistribuível (x64): "C:\Autodesk\WI\Autodesk Inventor 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\lucas\AppData\Local\Temp\vcredist_x64_2013.log
2017/6/8:08:20:24 lucas X556URK Microsoft Visual C++ 2013 Redistribuível (x64) return code: 0
2017/6/8:08:20:24 lucas X556URK Install Microsoft Visual C++ 2013 Redistribuível (x64) Succeeded
2017/6/8:08:20:25 lucas X556URK Download Play CM https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:25:30 lucas X556URK Download Aborted CM https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/CB28DF62-AC69-43B0-AA02-ECD5F68B4106/WI/{52833...
2017/6/8:08:25:30 lucas X556URK Install Biblioteca de materiais do Autodesk® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/6/8:08:25:30 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x64) Failed Installation aborted, Result=1619
2017/6/8:08:25:30 lucas X556URK Rollback Microsoft Visual C++ 2013 Redistribuível (x86) Failed Installation aborted, Result=1619
