Installation & Licensing
TravisNave
Message 1 of 4 (9,296 Views)
FLEXnet Licensing error:-15, "WinSock: Operation would block" : Server 2008 R2
9296 Views, 3 Replies
12-22-2011 12:09 PM
Problem:  You are running the Autodesk Network License Manager for 2012 products on Windows Server 2008 R2 and receive the following status enquiry error in LMTOOLS:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: servername
License path: 27000@servername
FLEXnet Licensing error:-15,570. System Error: 10035 "WinSock: Operation would block"
Solution:  There appears to be an issue with the vendor daemon adskflex.exe for version 11.9 included in the Autodesk 2012 product release.  This symptom does not exist with the previous adskflex.exe for version 11.7 included with prior release.  This symptom seems to only appear when running the version 11.9 vendor daemon and exists in both x64 and x86 versions.  The symptom seems to only appear in this fashion when running version 11.9 on Windows Server 2008 R2.  Other similar WinSock or -15 connectivity errors on other server host operating systems or license manager versions are not related to this problem.
To resolve the issue, please perform the following tasks:
Step 1:  Open LMTOOLS and stop the license manager service if it is running from the Start/Stop/Reread tab.  Verify that lmgrd.exe and adskflex.exe are not running in the processes tab of the Windows Task Manager.
Step 2:  Locate the installation folder for the license manager (i.e. C:\Program Files\Autodesk Network License Manager\) and rename the vendor daemon file from adskflex.exe to adskflex.bak
Step 3:  Replace the vendor daemon adskflex.exe file with the appropriate (x64) or (x86) version release 11.7 from your Autodesk 2011 media or from the following link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13737466&linkID=9241177
For your convenience, I will also attach the appropriate adskflex.exe files to this disccusion post.
Step 4:  Open LMTOOLS and repath the Config Services tab to the new adskflex.exe vendor daemon file and Save the service.  On the Start/Stop/Reread tab, click Start to start the service.  You may optionally Reread the license file if you choose.  Verify that the license manager is running from the System Status tab by running the Perform Status Enquiry button.  Your licenses should now read available.
Note:  It is recommended that you only change the vendor daemon file to the older version. You can keep the remaining master daemon file, LMTOOLS, and the utility file(s) all the latest version.
If you need additional information on setting up the Autodesk Network License Manager, please see my Quick-Start Installation Guide here:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
TravisNave
Message 2 of 4 (9,293 Views)
Re: FLEXnet Licensing error:-15, "WinSock: Operation would block"
12-22-2011 12:17 PM in reply to: TravisNave
For those of you running the (x64) version of the FLEXnet License Manager, you can find the 64-bit Autodesk vendor daemon file attached to this post below.
New Member
Akin_Autodesk
Message 3 of 4 (8,883 Views)
Re: FLEXnet Licensing error:-15, "WinSock: Operation would block" : Se
08-22-2012 01:10 PM in reply to: TravisNave
I'm helping a client of ours resolve a licensing failure issue, but I cant seem to get past the Flexnet licensing error -15. They have a 5 seat Building Design Suite Network license, and the Network license mgr seats on a Windows 2003 Small Business Server, and they regularly experience license outages.
When I logged into LMTools and performed status enquiry, I got Flexnet licensing Error -15.570.0, however subsequently after troubleshooting, it changed to Flexnet licensing Error -15.10 and eventually Flexnet Licensing Error: -15,10 System Error: 10061 "Winsock: Connection Refused".
Here's a brief listing of some of the things I've tried from several posts that I have read:
1 - I created exceptions on port 27000 -27002, 2080 and also on the 4 NLM programs in Windows firewall, and eventually I disabled the firewall
2 - disabled 3rd party antivirus firewall
3 - created exception for the 4 NLM programs on windows Data Execution Prevention
4 - Ensured flexlm1 service was running by checking in services.
5 - Ensured that the adskflex and lmgrd processes were running in task manager
6 - Replaced the network license manager version 11.10 with 11.7 just to be sure it wasnt a result of NLM
7 - Double checked that the details on the license file matched those on the LMTools Hostid file info
I ran out of ideas and have had to repeat all the steps mentioned above severally, all to no avail.
I've pasted the information from the debug log file below and will appreciate if a specific solution to this problem can be proferred by anyone. Thanks very much.
DEBUG LOG:
13:09:03 (lmgrd) -----------------------------------------------
13:09:03 (lmgrd) Please Note:
13:09:03 (lmgrd)
13:09:03 (lmgrd) This log is intended for debug purposes only.
13:09:03 (lmgrd) In order to capture accurate license
13:09:03 (lmgrd) usage data into an organized repository,
13:09:03 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
13:09:03 (lmgrd) software license administration solution,
13:09:03 (lmgrd) FLEXnet Manager, to readily gain visibility
13:09:03 (lmgrd) into license usage data and to create
13:09:03 (lmgrd) insightful reports on critical information like
13:09:03 (lmgrd) license availability and usage. FLEXnet Manager
13:09:03 (lmgrd) can be fully automated to run these reports on
13:09:03 (lmgrd) schedule and can be used to track license
13:09:03 (lmgrd) servers and usage across a heterogeneous
13:09:03 (lmgrd) network of servers including Windows NT, Linux
13:09:03 (lmgrd) and UNIX. Contact Acresso Software Inc. at
13:09:03 (lmgrd) www.acresso.com for more details on how to
13:09:03 (lmgrd) obtain an evaluation copy of FLEXnet Manager
13:09:03 (lmgrd) for your enterprise.
13:09:03 (lmgrd)
13:09:03 (lmgrd)
13:09:03 (lmgrd)
13:09:03 (lmgrd) pid 1884
13:09:03 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:09:03 (lmgrd) Done rereading
13:09:03 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_n3) started on conserver (IBM PC) (8/22/2012)
13:09:03 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
13:09:03 (lmgrd) US Patents 5,390,297 and 5,671,412.
13:09:03 (lmgrd) World Wide Web: http://www.acresso.com
13:09:03 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\Licenses\Autodesk Building Design Suite 2013 Licenses_FILes\BDSADV2013enlicense.lic
13:09:03 (lmgrd) lmgrd tcp-port 27000
13:09:03 (lmgrd) Starting vendor daemons ...
13:09:03 (lmgrd) Starting vendor daemon at port 2080
13:09:03 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:03 (lmgrd) Started adskflex (pid 2664)
13:09:03 (adskflex) Unable to initialize access to trusted storage: 1
13:09:03 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:04 (adskflex) Server started on conserver for:
13:09:04 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:04 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:04 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:04 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:04 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:04 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:04 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:04 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:04 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:04 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:04 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:04 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:04 (adskflex) 73100REVSYP_2010_0F)
13:09:04 (adskflex) EXTERNAL FILTERS are OFF
13:09:04 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:04 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:08 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:08 (lmgrd) Since this is an unknown status, license server
13:09:08 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:08 (lmgrd) Starting vendor daemon at port 2080
13:09:08 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:08 (lmgrd) REStarted adskflex (pid 852)
13:09:09 (adskflex) Unable to initialize access to trusted storage: 1
13:09:09 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:10 (adskflex) Server started on conserver for:
13:09:10 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:10 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:10 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:10 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:10 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:10 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:10 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:10 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:10 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:10 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:10 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:10 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:10 (adskflex) 73100REVSYP_2010_0F)
13:09:10 (adskflex) EXTERNAL FILTERS are OFF
13:09:10 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:10 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:13 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:13 (lmgrd) Since this is an unknown status, license server
13:09:13 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:13 (lmgrd) Starting vendor daemon at port 2080
13:09:13 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:13 (lmgrd) REStarted adskflex (pid 924)
13:09:13 (adskflex) Unable to initialize access to trusted storage: 1
13:09:13 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:14 (adskflex) Server started on conserver for:
13:09:14 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:14 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:14 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:14 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:14 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:14 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:14 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:14 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:14 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:14 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:14 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:14 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:14 (adskflex) 73100REVSYP_2010_0F)
13:09:14 (adskflex) EXTERNAL FILTERS are OFF
13:09:14 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:14 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:18 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:18 (lmgrd) Since this is an unknown status, license server
13:09:18 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:18 (lmgrd) Starting vendor daemon at port 2080
13:09:18 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:18 (lmgrd) REStarted adskflex (pid 688)
13:09:18 (adskflex) Unable to initialize access to trusted storage: 1
13:09:18 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:19 (adskflex) Server started on conserver for:
13:09:19 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:19 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:19 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:19 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:19 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:19 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:19 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:19 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:19 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:19 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:19 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:19 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:19 (adskflex) 73100REVSYP_2010_0F)
13:09:19 (adskflex) EXTERNAL FILTERS are OFF
13:09:19 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:19 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:23 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:23 (lmgrd) Since this is an unknown status, license server
13:09:23 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:23 (lmgrd) Starting vendor daemon at port 2080
13:09:23 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:23 (lmgrd) REStarted adskflex (pid 6036)
13:09:23 (adskflex) Unable to initialize access to trusted storage: 1
13:09:23 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:24 (adskflex) Server started on conserver for:
13:09:24 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:24 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:24 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:24 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:24 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:24 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:24 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:24 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:24 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:24 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:24 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:24 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:24 (adskflex) 73100REVSYP_2010_0F)
13:09:24 (adskflex) EXTERNAL FILTERS are OFF
13:09:24 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:24 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:28 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:28 (lmgrd) Since this is an unknown status, license server
13:09:28 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:28 (lmgrd) Starting vendor daemon at port 2080
13:09:28 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:28 (lmgrd) REStarted adskflex (pid 5956)
13:09:28 (adskflex) Unable to initialize access to trusted storage: 1
13:09:28 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:29 (adskflex) Server started on conserver for:
13:09:29 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:29 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:29 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:29 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:29 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:29 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:29 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:29 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:29 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:29 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:29 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:29 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:29 (adskflex) 73100REVSYP_2010_0F)
13:09:29 (adskflex) EXTERNAL FILTERS are OFF
13:09:29 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:29 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:33 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:33 (lmgrd) Since this is an unknown status, license server
13:09:33 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:33 (lmgrd) Starting vendor daemon at port 2080
13:09:33 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:33 (lmgrd) REStarted adskflex (pid 4104)
13:09:33 (adskflex) Unable to initialize access to trusted storage: 1
13:09:33 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:34 (adskflex) Server started on conserver for:
13:09:34 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:34 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:34 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:34 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:34 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:34 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:34 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:34 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:34 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:34 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:34 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:34 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:34 (adskflex) 73100REVSYP_2010_0F)
13:09:34 (adskflex) EXTERNAL FILTERS are OFF
13:09:35 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:35 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:38 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:38 (lmgrd) Since this is an unknown status, license server
13:09:38 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:38 (lmgrd) Starting vendor daemon at port 2080
13:09:38 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:38 (lmgrd) REStarted adskflex (pid 4176)
13:09:38 (adskflex) Unable to initialize access to trusted storage: 1
13:09:38 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:39 (adskflex) Server started on conserver for:
13:09:39 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:39 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:39 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:39 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:39 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:39 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:39 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:39 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:39 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:39 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:39 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:39 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:39 (adskflex) 73100REVSYP_2010_0F)
13:09:39 (adskflex) EXTERNAL FILTERS are OFF
13:09:39 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:39 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:43 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:43 (lmgrd) Since this is an unknown status, license server
13:09:43 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:43 (lmgrd) Starting vendor daemon at port 2080
13:09:43 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:43 (lmgrd) REStarted adskflex (pid 5972)
13:09:43 (adskflex) Unable to initialize access to trusted storage: 1
13:09:43 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:44 (adskflex) Server started on conserver for:
13:09:44 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:44 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:44 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:44 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:44 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:44 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:44 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:44 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:44 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:44 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:44 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:44 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:44 (adskflex) 73100REVSYP_2010_0F)
13:09:44 (adskflex) EXTERNAL FILTERS are OFF
13:09:44 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:44 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:48 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:48 (lmgrd) Since this is an unknown status, license server
13:09:48 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:48 (lmgrd) Starting vendor daemon at port 2080
13:09:48 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:48 (lmgrd) REStarted adskflex (pid 5216)
13:09:48 (adskflex) Unable to initialize access to trusted storage: 1
13:09:48 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:49 (adskflex) Server started on conserver for:
13:09:49 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:49 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:49 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:49 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:49 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:49 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:49 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:49 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:49 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:49 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:49 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:49 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:49 (adskflex) 73100REVSYP_2010_0F)
13:09:49 (adskflex) EXTERNAL FILTERS are OFF
13:09:50 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:50 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:53 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:53 (lmgrd) Since this is an unknown status, license server
13:09:53 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:09:53 (lmgrd) Starting vendor daemon at port 2080
13:09:53 (lmgrd) Using vendor daemon port 2080 specified in license file
13:09:53 (lmgrd) REStarted adskflex (pid 4572)
13:09:53 (adskflex) Unable to initialize access to trusted storage: 1
13:09:53 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
13:09:54 (adskflex) Server started on conserver for:
13:09:54 (adskflex) 85788BDSADV_F (consisting of: 85948BDSADV_2013_0F
13:09:54 (adskflex) 85788BDSADV_2012_0F 85778RSAPRO_2012_0F 85882INFMDR_2012_0F
13:09:54 (adskflex) 85793REVSYP_2012_0F 85792REVSU_2012_0F 85536ACD_2011_0F
13:09:54 (adskflex) 85651BDSADV_2011_0F 85607SHOWCASE_2011_0F 85586RSAPRO_2011_0F
13:09:54 (adskflex) 85583LDXSP_2011_0F 85579INVNTOR_2011_0F 85600NAVMAN_2011_0F
13:09:54 (adskflex) 85594REVSU_2011_0F 85541RVTMPB_2011_0F 85503MAXDES_2011_0F
13:09:54 (adskflex) 85561ARCHDESK_2011_0F 85562BLDSYS_2011_0F 85615ALSK_2011_0F
13:09:54 (adskflex) 85587REVIT_2011_0F 85624REVSYP_2011_0F 71200ACD_2010_0F
13:09:54 (adskflex) 82200STRDET_2010_0F 73000BLDSYS_2010_0F 72200ARCHDESK_2010_0F
13:09:54 (adskflex) 70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F
13:09:54 (adskflex) 73800RVTMPJ_2010_0F 71400NAVMAN_2010_0F 68600AQTO_2010_0F
13:09:54 (adskflex) 74000REVSU_2010_0F 75300RSAPRO_2010_0F 85577INVNTOR_2010_0F
13:09:54 (adskflex) 73100REVSYP_2010_0F)
13:09:54 (adskflex) EXTERNAL FILTERS are OFF
13:09:54 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10013 "WinSock: Access denied"))
13:09:54 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
13:09:58 (lmgrd) adskflex exited with status 28 (Communications error)
13:09:58 (lmgrd) Please correct problem and restart daemons
TravisNave
Message 4 of 4 (8,864 Views)
08-23-2012 11:24 AM in reply to: Akin_Autodesk
What is the version of adskflex.exe that you are using?  Also, can you PING the servername from itself and get a valid IPv4 address?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
