Hello, this error is happening when I try to install the AutoCAD 2014 64 bits version for studends. I tried to solve this problems looking in the forum, but none of them worked. This is the error log that shows when it fails:
2013/12/4:23:02:38 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:02:38 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:02:38 Rodrigo RODSCI Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/12/4:23:02:38 Rodrigo RODSCI Launch
2013/12/4:23:02:38 Rodrigo RODSCI CommandLine
2013/12/4:23:02:38 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC5FF.tmp
2013/12/4:23:02:51 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:02:42 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:02:42 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:02:42 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC5FF.tmp
2013/12/4:23:02:42 Rodrigo RODSCI Launch
2013/12/4:23:02:43 Rodrigo RODSCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rodrigo\AppData\Local\Temp\_AIC5FF.tmp\Setup\AcSetup.dll
2013/12/4:23:02:43 Rodrigo RODSCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/12/4:23:02:51 Rodrigo RODSCI PageOpen LaunchDialog
2013/12/4:23:03:08 Rodrigo RODSCI PageOpen LicenseDialog
2013/12/4:23:03:17 Rodrigo RODSCI PageOpen ProductInfoDialog
2013/12/4:23:05:42 Rodrigo RODSCI PageOpen ProductSelectionDialog2
2013/12/4:23:05:54 Rodrigo RODSCI PageOpen FullProgressDialog
2013/12/4:23:05:55 Rodrigo RODSCI Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/12/4:23:06:06 Rodrigo RODSCI Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/12/4:23:06:08 Rodrigo RODSCI PageOpen InstallCompleteDialog
2013/12/4:23:06:41 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:16:22 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:16:22 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:16:22 Rodrigo RODSCI Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/12/4:23:16:22 Rodrigo RODSCI Launch
2013/12/4:23:16:22 Rodrigo RODSCI CommandLine
2013/12/4:23:16:22 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI563E.tmp
2013/12/4:23:16:29 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:16:24 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:16:24 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:16:24 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI563E.tmp
2013/12/4:23:16:24 Rodrigo RODSCI Launch
2013/12/4:23:16:25 Rodrigo RODSCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rodrigo\AppData\Local\Temp\_AI563E.tmp\Setup\AcSetup.dll
2013/12/4:23:16:25 Rodrigo RODSCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/12/4:23:16:28 Rodrigo RODSCI PageOpen LaunchDialog
2013/12/4:23:16:31 Rodrigo RODSCI PageOpen LicenseDialog
2013/12/4:23:16:34 Rodrigo RODSCI PageOpen ProductInfoDialog
2013/12/4:23:17:02 Rodrigo RODSCI PageOpen ProductSelectionDialog2
2013/12/4:23:17:07 Rodrigo RODSCI PageOpen FullProgressDialog
2013/12/4:23:17:08 Rodrigo RODSCI Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/12/4:23:17:14 Rodrigo RODSCI Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/12/4:23:17:14 Rodrigo RODSCI PageOpen InstallCompleteDialog
2013/12/4:23:26:57 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:37:40 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:37:40 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:37:40 Rodrigo RODSCI Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/12/4:23:37:40 Rodrigo RODSCI Launch
2013/12/4:23:37:40 Rodrigo RODSCI CommandLine
2013/12/4:23:37:40 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC690.tmp
2013/12/4:23:38:35 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:37:50 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:37:50 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:37:50 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC690.tmp
2013/12/4:23:37:50 Rodrigo RODSCI Launch
2013/12/4:23:37:57 Rodrigo RODSCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rodrigo\AppData\Local\Temp\_AIC690.tmp\Setup\AcSetup.dll
2013/12/4:23:37:57 Rodrigo RODSCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/12/4:23:38:39 Rodrigo RODSCI PageOpen LaunchDialog
2013/12/4:23:39:39 Rodrigo RODSCI PageOpen LicenseDialog
2013/12/4:23:39:46 Rodrigo RODSCI PageOpen ProductInfoDialog
2013/12/4:23:40:10 Rodrigo RODSCI PageOpen ProductSelectionDialog2
2013/12/4:23:40:14 Rodrigo RODSCI PageOpen FullProgressDialog
2013/12/4:23:40:15 Rodrigo RODSCI Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/12/4:23:40:21 Rodrigo RODSCI Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/12/4:23:40:22 Rodrigo RODSCI PageOpen InstallCompleteDialog
2013/12/4:23:40:29 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:46:28 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:46:28 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:46:28 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\New folder\AutoCAD_2014_English_Win_64bit_dlm
2013/12/4:23:46:28 Rodrigo RODSCI Launch
2013/12/4:23:46:28 Rodrigo RODSCI CommandLine
2013/12/4:23:46:28 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC6E7.tmp
2013/12/4:23:46:46 Rodrigo RODSCI === Setup ended ===
2013/12/4:23:46:36 Rodrigo RODSCI === Setup started on RODSCI by Rodrigo ===
2013/12/4:23:46:36 Rodrigo RODSCI Path_Length: 155
2013/12/4:23:46:36 Rodrigo RODSCI Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC6E7.tmp
2013/12/4:23:46:36 Rodrigo RODSCI Launch
2013/12/4:23:46:38 Rodrigo RODSCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rodrigo\AppData\Local\Temp\_AIC6E7.tmp\Setup\AcSetup.dll
2013/12/4:23:46:38 Rodrigo RODSCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/12/4:23:46:45 Rodrigo RODSCI PageOpen LaunchDialog
2013/12/4:23:46:53 Rodrigo RODSCI PageOpen LicenseDialog
2013/12/4:23:46:56 Rodrigo RODSCI PageOpen ProductInfoDialog
2013/12/4:23:47:22 Rodrigo RODSCI PageOpen ProductSelectionDialog2
2013/12/4:23:48:36 Rodrigo RODSCI PageOpen FullProgressDialog
2013/12/4:23:48:37 Rodrigo RODSCI Installing .NET Framework Runtime 4.0 Language Pack: "C:\Users\Rodrigo\New folder\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/12/4:23:48:43 Rodrigo RODSCI Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Hello and welcome to the community.
You are getting the following error message ' Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603’.
Please try the following solution:
1) Launch your Control Panel -> Add/Remove Programs (XP) or Programs > Programs and Features (Windows 7)
2) Select and uninstall Microsoft .Net Framework 4 Extended
3) Select and uninstall Microsoft .Net Framework 4 Client Profile
4) Reboot your system after uninstalling both the components.
5) Install Autodesk software and this will successfully re-install .Net
Error: Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
Thank you for using the community.
Here's my take on what Brad also posted. Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
