Yes, I tried that, but it didn't help.
The strange thing is that everything works with R14! Autodesk seems to have
changed the way AutoCAD opens files.
Juha
"jason martin" wrote in message
news:D736CE5250BE554CB782A3926D231BCC@in.WebX.maYIadrTaRb...
> Juha -
> I don't know if this will help but have you tried marking the file as
shareable in netware???
> jason martin
> frankfurt-short-bruza
> "Juha Hänninen" wrote in message
news:813BBE069B82731A0AA1B0E7DC2B6481@in.WebX.maYIadrTaRb...
> > Hi,
> > While trying to get everything to work with AutoCAD 2002 and Windows
2000 I
> > got an strange error message while trying to load an arx from Netware
server
> > Command: arx
> > Enter an option [?/Load/Unload/Commands/Options]: l
> > Error code (0x20) The process cannot access the file because it is being
> > used
> > by another process.
> > AcRxDynamicLinker failed to load 'M:\ACAD\PID\WHOHAS.ARX'
> > C:\Program Files\AutoCAD 2002\acad.exe
> > Command
> > With AutoCAD R14 everything works. Is 2002 not supported in Windows 2000
> > client / Netware environment?
> > I´m using Microsoft client for Netware. The same happens with every arx
I
> > try to open from the network. Opening from local disk works.
> > Is there anybody else having the same problem?
> > Regards,
> > Juha Hanninen
