Installation & Licensing
Error creating Inventor 2010 64-bit deployment
7 REPLIES 7
Message 1 of 8
bscott
617 Views, 7 Replies
Attempting to create an Inventor 2010 64-bit deployment using Win XP 64. The deployment creation fails with the error: Failed to copy the following files "c:\Inv2010Install\INVDISK1\x64\Inventor\EULA" to my deployment location on a network drive. The folder specified does not exist on the installation DVD or on the local folder that I've created by copying the DVD. Anyone found a workaround for this error?
Bruce
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: bscott
Did you copy the files from the 64-bit DVD also to your hard drive before starting this process?
Autodesk Forums:
Message 3 of 8
TravisNave
in reply to: bscott
Wait a minute, did you copy each disc into individual INVDISK# folders? If so, this won't work. They all have to go into the same folder...
Autodesk Forums:
Message 4 of 8
bscott
in reply to: bscott
I copied each of the Suite 2010 DVDs into seperate folders. Should they be combined into a single folder?
Message 5 of 8
TravisNave
in reply to: bscott
Correct!
Autodesk Forums:
Message 6 of 8
bscott
in reply to: bscott
Thanks, I'll give it a try. Just to clarify concerning 64-bit content, is it all on the same DVD set as the 32-bit install?
Message 7 of 8
TravisNave
in reply to: bscott
I believe the 64-bit is on a separate disc. In any case, you will want to copy the whole suite together into one folder.
Autodesk Forums:
Message 8 of 8
in reply to: bscott
You can copy all DVD file into a single folder include 32bit and 64bit
files, cover the files that when you encounter a prompt message "the file
already exist". then you can launch Installer and select to create a 32bit
or 64bit deployment on the Begin Deployment page.
Kevin Hu, Autodesk
Administrator Productivity
