Installation & Licensing
Error assigning serial number to product.
5 REPLIES 5
869 Views, 5 Replies
I'm having a problem with my AutoCAD activation, I am simply unable to activate my product since my license code is not valid, and when I looked what was wrong I saw this:
Error assigning serial number to product: This is an operation implementation generated fault
So if you could help me I would appreciate it thanks.
Thank you for your time.
Sincerely yours Dean Babic
5 REPLIES 5
I am getting the same error. What can I do to fix it?
philip.s
Hi Dean,
This is typically an Education Community account issue where the only workaround is to create a new account using a different email address. Please let us know if you continue to experience issues and we'll gladly troubleshoot accordingly!
Hi, I'm experiencing the same problem, i says ''Error assigning serial number to product: This is an operation implementation generated fault'', and the serial number listed is not valid... Thank you for your help.
jggerth
Two possibilities come to mind.... one is that the authorization process is havig problems on autodesk's end of the internet.  The second is a bad serial number.  Presuming that you purchased this through a VAR, the best bet is to contact your reseller.  Thye are generally the first stop for initial installation support.
philip.s
in reply to: jggerth
The "Error Assigning Serial Number to Product" error message is actually in regards to an Education Community account issue, where the only workaround at the moment is to create a new account using a different email address.
Administrator Productivity
