Installation & Licensing
Member
Message 1 of 10 (7,343 Views)
Error Msg Seen During Installaiton "Cant find setupUi.dll"
7343 Views, 9 Replies
01-14-2013 11:58 AM
To Whom This May Concern:
A couple of days ago, I attempted to install the AutoCAD LT 2013 software on my laptop from a CD media. Before I could continue with the installation process, an error message comes on that says, "Can't find setupUi.dll".
To rectify the problem, I have done the following:
1) Logged on to Twitter and posted my problem and was given the following suggestions:
a) Copy the media files into my hard drive.
Result: After this process, I proceeded to load the files from there. No luck was encountered as the same error
     message was displayed.
b) Download AutoCAD LT from autodesk.com.
Result: Action was unsuccessful due to a virus detection message generated by my company's internet protection software.
2) Visited autodesk.com and downloaded free trial version of AutoCAD LT 2013.
Result: Files were successfully downloaded
3) Loaded AutoCAD files after performing action #2, but unfortunately, same error message was displayed again.
Result: I'm not happy, so I created this post to obtain further technical support.
Please help asap.......
PS
Based on my knowledge, this particular CD that I have was purchased last year and was first registered back in April 2012.
Sincerely,
Katherine Plummer
Product Support
byron.morales
Message 2 of 10 (7,323 Views)
Re: Error Msg Seen During Installaiton "Cant find setupUi.dll"
01-14-2013 03:45 PM in reply to: katvplummer
Hello Katherine:
Please create a new local user account onto the computer and give it administrator permissions. Then log into the computer with this newly created test account. Turn Off UAC (user account control settings) in the control panel, then Turn off your Antivirus program and proceed to install by Right Clicking on the setup.exe and selecting to Run As Admionistrator.
Let me know if the above helps to install the program, if it fails please post the Setup.log and the Install.log found under the %temp% folder.
Byron Morales
Member
Message 3 of 10 (7,288 Views)
01-16-2013 03:44 PM in reply to: byron.morales
Tried what you suggested and smae thing happened. Attached is the Setup log file.
Member
Message 4 of 10 (7,283 Views)
01-16-2013 04:22 PM in reply to: katvplummer
Byron,
FYI: The other day, I downloaded a free trial of this AutoCAD LT 2013 in 32-Bit file from your website. This action didn't seem to solve my problem. Today, I logged in again and downloaded a 64-bit file from your website, and again, the same issue remains. Today, I elected to have my HelpDesk focals assist me with this issue...two hours into it, I'm still at square one.
From what I heard, my teammates also had problems installing this SW in their PCs. I'm just the lucky one who cannot proceed at all at this point. As far as I know, we bought enough licenses, so this can't be the cause of this problem. It makes me ask though as to why is it so difficult to install this program? What am I doing wrong? This has been the most times I've spent installing a SW, which of course, translates to downtime in my productivity. Please help asap.
Thank you....
Kat
Member
Message 5 of 10 (7,281 Views)
01-16-2013 04:23 PM in reply to: katvplummer
Byron,
Thank you....
Kat
Product Support
byron.morales
Message 6 of 10 (7,265 Views)
01-16-2013 04:43 PM in reply to: katvplummer
Hello Katherine:
It could be a permissions issue, since you mentioned that your co-workers have also ran into problems installing.
We created a support case for you and we'll contact you through the case to help you resolve this issue.
Byron Morales
Member
Message 7 of 10 (7,245 Views)
01-17-2013 09:29 AM in reply to: byron.morales
Byron,
I sent you my contact information. Please let me know if you can accomodate the specified time. If not, then I'm available again around 3PM today.
Sincerely,
Kat
Active Member
Message 8 of 10 (5,905 Views)
05-17-2013 01:57 AM in reply to: katvplummer
at the moment we have the same problem installing AutoCadLT 2013.
Is there any sollution available?
Regards
Daniel
New Member
Message 9 of 10 (5,847 Views)
05-20-2013 03:53 PM in reply to: daniel26
Found a solution that works.
Copy the Disks to the Hard drive.  Doesn't matter where.  C:\AutoCAD\ for example
This is the STUPID part... Rename a directory in the newly copied folder.
C:\AutoCAD\setup
to
C:\AutoCAD\Setup  <--- Case sensitive "S"
Run install and it works.
If you open up the setup INI file, you'll see the reference is to .\Setup\SetupUi.dll. Disregard the fact that the error message shows the file as setupUi.dll and just leave the file alone. Just rename the directory like I stated above and call it a day.
*** Edited shoes to shows
Active Member
Message 10 of 10 (5,827 Views)
05-21-2013 02:39 AM in reply to: katvplummer
Thanks, that works. Very strange.
Regards
Daniel
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
