Installation & Licensing
New Member
Message 1 of 2 (1,441 Views)
Error 1603 Installing 30-Day Trial of Revit 2014
1441 Views, 1 Replies
05-23-2013 12:25 AM
Hi, I'm trying to install the 30-Day Trial Version of Revit 2014, but I always end up with abort installation, here is the Installation Log:
2013/4/19:05:45:31 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:05:45:31 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:05:45:31 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:05:45:31 Charbel CHARBEL-PC Launch
2013/4/19:05:45:31 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:05:45:31 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp
2013/4/19:05:48:54 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:05:45:35 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:05:45:35 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:05:45:35 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp
2013/4/19:05:45:35 Charbel CHARBEL-PC Launch
2013/4/19:05:46:51 Charbel CHARBEL-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:05:48:53 Charbel CHARBEL-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:05:48:53 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp\Setup\RevitSetup.dll
2013/4/19:05:48:53 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:05:48:54 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:05:50:32 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:05:50:39 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:05:52:17 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:05:52:46 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:05:52:47 Charbel CHARBEL-PC Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:05:53:00 Charbel CHARBEL-PC Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:05:53:00 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:05:53:15 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:05:53:15 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:05:53:50 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:06:06:13 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:06:06:13 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:06:06:13 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:06:06:13 Charbel CHARBEL-PC Launch
2013/4/19:06:06:13 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:06:06:13 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp
2013/4/19:06:06:21 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:06:06:16 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:06:06:16 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:06:06:16 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp
2013/4/19:06:06:16 Charbel CHARBEL-PC Launch
2013/4/19:06:06:17 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:06:06:18 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp\Setup\RevitSetup.dll
2013/4/19:06:06:19 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:06:06:20 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:06:06:30 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:06:06:35 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:06:08:31 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:06:09:18 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:06:09:18 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:06:09:18 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:06:09:29 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:06:09:30 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:06:10:01 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:15:57:21 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:15:57:21 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:15:57:21 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:15:57:21 Charbel CHARBEL-PC Launch
2013/4/19:15:57:21 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:15:57:21 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp
2013/4/19:15:59:17 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:15:57:24 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:15:57:24 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:15:57:24 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp
2013/4/19:15:57:24 Charbel CHARBEL-PC Launch
2013/4/19:15:59:17 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:15:59:17 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp\Setup\RevitSetup.dll
2013/4/19:15:59:17 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:15:59:17 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:15:59:25 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:15:59:30 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:01:08 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:01:17 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:01:18 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:01:18 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:01:23 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:01:24 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:07:11 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:07:30 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:07:30 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:07:30 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:16:07:30 Charbel CHARBEL-PC Launch
2013/4/19:16:07:30 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:16:07:30 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp
2013/4/19:16:07:35 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:07:32 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:07:32 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:07:32 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp
2013/4/19:16:07:32 Charbel CHARBEL-PC Launch
2013/4/19:16:07:33 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:16:07:33 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp\Setup\RevitSetup.dll
2013/4/19:16:07:33 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:16:07:34 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:16:07:45 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:16:07:57 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:09:12 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:09:20 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:09:20 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:09:20 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:09:25 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:09:26 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:14:07 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:21:38 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:21:38 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:21:38 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:16:21:38 Charbel CHARBEL-PC Launch
2013/4/19:16:21:38 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:16:21:38 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp
2013/4/19:16:21:44 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:21:41 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:21:41 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:21:41 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp
2013/4/19:16:21:41 Charbel CHARBEL-PC Launch
2013/4/19:16:21:42 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:16:21:42 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp\Setup\RevitSetup.dll
2013/4/19:16:21:42 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:16:21:43 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:16:21:55 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:16:22:00 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:24:12 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:24:30 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:24:30 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:24:30 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:24:38 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:24:41 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:25:14 Charbel CHARBEL-PC === Setup ended ===
2013/5/23:00:05:44 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/5/23:00:05:44 Charbel CHARBEL-PC Path_Length: 149
2013/5/23:00:05:44 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/5/23:00:05:44 Charbel CHARBEL-PC Launch
2013/5/23:00:05:44 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/5/23:00:05:44 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp
2013/5/23:00:06:31 Charbel CHARBEL-PC === Setup ended ===
2013/5/23:00:05:48 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/5/23:00:05:48 Charbel CHARBEL-PC Path_Length: 149
2013/5/23:00:05:48 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp
2013/5/23:00:05:48 Charbel CHARBEL-PC Launch
2013/5/23:00:06:31 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/5/23:00:06:31 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp\Setup\RevitSetup.dll
2013/5/23:00:06:31 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/5/23:00:06:31 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/5/23:00:06:41 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/5/23:00:06:45 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/5/23:00:08:38 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/5/23:00:08:59 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/5/23:00:08:59 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/5/23:00:08:59 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/5/23:00:09:06 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
The only Microsoft Visual C++ 2008 SP1 Redistributable (x64) installed on my laptop is [ Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 ]
Is there any solution to this? I tried following the solutions I found in Googled but still nothing works:
- Turn off UAC
- Turn off Anti-Virus Software (mine is Avast)
- Uninstall the existing Microsoft Visual C++ 2008 SP1 Redistributable (x64) in 'Uninstall Program', re-reun installation, then let Autodesk install it during Revit installation
- Uninstall ALL other Microsoft Visual C++ then re-reun installation
- Create a [ C:\Temp ] folder
- Re-register [ msiexec.exe ] in [command prompt] and type [ msiexec.exe/unreg ], then type [ msiexec.exe -regserver ]
- A combination of everything above in [ Safe Mode with Internet ]
Please help me, I really need to study Revit within the next 30 days. And I don't want to reformat/reset my laptop because I can't afford to have all my files there deleted & I couldn't afford to get an external hard drive right now to back-up my files & saving them in a blank DVD-R would take soo much time. Thank you in advance to anyone who can help me.
TravisNave
Message 2 of 2 (1,417 Views)
Re: Error 1603 Installing 30-Day Trial of Revit 2014
05-23-2013 11:04 AM in reply to: lefthandthought
Remove the prerequisite check for this in the setup.ini.  See my follow up on this thread:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
