Installation & Licensing
Dumb question about remote performance...
1 REPLY 1
180 Views, 1 Reply
When working on an LDD project on a remote server across a T1 line it runs slow. Opening and closing the file and general commands work okay. There is a big slow down when civil and survey functions are used. What is the solution? Rich
1 REPLY 1
The problem is that LDT opens 3 or 4 Access databases in addition to the .dwg file and the dynamic nature of these database connections causes excess reads and writes every time you initiate a LDT function. I usually recommend that users try not to use LDT across the T1 unless absolutely necessary. Use Land Enabled Acad instead. If Autodesk ever goes to a true enterprise database solution such as SQL server or Oracle to house the LDT data I suspect this will not be such an issue. Dale "rich keitz" wrote in message news:4075bbdf_1@newsprd01... > When working on an LDD project on a remote server across a T1 line it runs > slow. Opening and closing the file and general commands work okay. There > is a big slow down when civil and survey functions are used. What is the > solution? > Rich > >
Administrator Productivity
