Can we deploy AutoCAD2011 in the same server where I have AutoCAD 2008 and use license file of AutoCAD2011 on LMTOOLS where I have I have AutoCAD2008?
Would you let me know if there is any impact if I do that?
Please advice
Yes you can install AutoCAD 2011 on a machine which already has AutoCAD 2008 installed.
You can have the licenses merged and continue using both versions.
Please contact ap.resgister@activation.autodesk.com to have the same done.
Technically you should be able to deploy both versions from the same machine, as they are independent installations.(different folders)
LMTOOLS need to be the latest version (for 2011, ver.11.7), it is backward compatible for 2008 licenses.
You can see more details on combining license files here
http://usa.autodesk.com/getdoc/id=TS65928
