Installation & Licensing
Deactivate license from dead computer?
1 REPLY 1
1920 Views, 1 Reply
How do I deactivate or transfer a license from a computer with a dead harddrive?  The Online License Transfer Utility seems to only export the License from the computer that is running the OLTU.  Is there a way to do this thru the Autodesk website or do we have to call customer support?
1 REPLY 1
TravisNave
Simply reactivate the software on a new machine.  If you have problems, then you can call the Activation hotline at 1-800-551-1490.  This is a common problem.
Autodesk Forums:
Administrator Productivity
