Installation & Licensing
New Member
mal1981
Message 1 of 2 (7,596 Views)
Customization File Load Failed. File Not Found: .....Support\ACA
7596 Views, 1 Replies
12-02-2010 09:13 AM
Can someone please help me? I had a user who was using AutoCAD MEP 2011 on a workstation. This user has since left our company and AutoCAD was uninstalled. Recently a new hire started and we installed AutoCAD Arch 2011 for her to use. Installation completes fine but when I open the program I get the follow error/AutoCAD message: Customization File Load Failed. File Not Found: c:\documents and settings\"username"\application data\autodesk\ACA2011\enu\support\ACA. I've tried uninstalling and deleting all the local folders I could find in the profiles local and application settings folders, but nothing is working. If I click ok, AutoCAD will open but I get no toolbars or menus. Please help. Thanks!
Error I'm Receiving
Product Support
Message 2 of 2 (7,573 Views)
Re: Customization File Load Failed. File Not Found: .....Support\ACA
12-02-2010 11:32 PM in reply to: mal1981
Delete any reference to ACA from this Registry key,
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD
this will force the secondary installer when the user starts ACA. If the user has right permissions to edit the registry again, it will install all the necessary files.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
