Installation & Licensing
Civil 3D SP1 can not be installed
5 REPLIES 5
JEFFJONES8251
355 Views, 5 Replies
I ahve tried to install Civil 3D SP1, on a Windows 7 64 bit, and get the following "Service Pack can not be installed because the expected Autodesk product can not be located"
I am using the 64 bit update, not the 32.  I also have Civil 3d 2011 loaded and running on this machine.
5 REPLIES 5
TravisNave
in reply to: JEFFJONES8251
Make sure you download the appropriate service pack for your product.  You may need to download one that is part of a suite or a different cpu architecture that matches your install.  Clearly, the one you have is not correct.
Autodesk Forums:
JEFFJONES8251
in reply to: TravisNave
Thanks, but I am using the appropriate one for the product loaded on the machine.  I have Civil 3D v2012 64 bit and am trying to install the Civil 3D SP1 v2012 for 64 bit on a 64 bit machine.
TravisNave
Try downloading it again.  Maybe it was corrupted?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18133124&linkID=9240698
Autodesk Forums:
JEFFJONES8251
I had downloaded and saved the file several times and it would not change. Civil 3D crashed on me on Tue and I had to uninstall and reinstall and it still would not work. I just tried to run it from the site instead of downloading/save/run and it worked fine.
THANK YOU!!
TravisNave
Excellent.  Glad you are up and running.
Autodesk Forums:
Administrator Productivity
