I'm working on setting up a deployment for civil3d 2013. We have a custom acad.exe.config file and a modified custom.cui. Where do I add these in when working on setting up the deployment? In Autocad we can see the full installation paths of where all the files go but I don't see that in Civil 3d. So again how can I add these files in.
Dylan
Solved by avto. Go to Solution.
Hi Dylan,
Unfortunately, AutoCAD C3D 2013 deployment creation wizard doesn’t support adding customized files to the deployment image. You can try creating a default deployment image and replaying the original files with your customized files and see if that helps.
acad.exe.config can be found in:
\\your_network_share_name\AdminImage\x64\C3D\Program Files\root\C3D_AppRootOverrides
custom.cuix can be found in:
\\your_network_share_name\AdminImage\x64\en-us\C3D\Acad\Program Files\root\UserDataCache\en-us\Support
Here is the link to another post regarding customizing C3D deployment that may help as well.
