Installation & Licensing
Cannot Install Civil 3D 2014 Service Pack 1 - Error Code 1603
2 REPLIES 2
neilyj666
2077 Views, 2 Replies
Service pack 1 for Civil 3D 2014 will not install as it asks for the installation DVD but I only have the USB key that IDSP 2014 was supplied on.
Screen shots show the errors I'm getting (to be read in order 08_36_35 then 08_36_55 then 08_37_42)
I have successfully installed the Service pack on my laptop and was not required to insert the original media
The screenshot below shows the Registry Key for the installer - (I browsed to this location when prompted to located the install files but the install still failed)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
2 REPLIES 2
TravisNave
in reply to: neilyj666
That's annoying...
Have you tried browsing out to your USB media especially for that file and choosing it manually?  I guess worst case, you can burn a DVD.  Hmm...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
neilyj666
in reply to: TravisNave
Yes I tried browsing to find the file which is when the error appeared about admin privileges.
My workaround was to copy the folder containing the MSI file to a temp folder on my C drive and the installation worked
Administrator Productivity
