Installation & Licensing
Employee
Message 11 of 20 (1,035 Views)
Re: Cannot Activate Inventor 2012
10-09-2011 06:40 PM in reply to: phreaker
Hello phreaker,
Could you please email me to let me know which email account you inputed when sending the CER report to us?
My email address is: Helen.ChenATAutodeskDOTcom
Thank you.
Helen
Member
phreaker
Message 12 of 20 (1,034 Views)
10-09-2011 06:58 PM in reply to: HelenChen-Autodesk
Email sent,
please let me know if you did not get it.
will continue to post updates here as to assist other with this matter,
Employee
Message 13 of 20 (1,010 Views)
10-10-2011 04:08 AM in reply to: phreaker
Hello phreaker,
Could you please try below steps to see whether can resolve your problem?
  1. Uninstall Inventor 2012
  2. Delete the below files from your XP 64bit OS, you can find them under: C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
  • CascadeInfo.cas
  • ProductInformation.pit
Please note the folder “Application Data” is a hidden folder in OS, please change OS to show the hidden files and folders firstly.
3. Uninstall .Net Framework 3.5 SP1 from your machine from Control Panel->Add/Remove Program
4. Install .Net Framework 3.5 SP1 from the installation package under 3rdParty\NET\35SP1
5. Install Inventor 2012
Thank you very much for your assistant and patient.
I am sorry for any inconvenience.
Helen
Member
kcg231286
Message 14 of 20 (950 Views)
10-20-2011 02:33 PM in reply to: HelenChen-Autodesk
inventor 2012 not started. have installed the downloaded fre version but it does not start. i have sent the error reports. also while activation it asks for product request code, but i got the seriel no and key only
Member
phreaker
Message 15 of 20 (942 Views)
10-20-2011 03:33 PM in reply to: HelenChen-Autodesk
Ok just a heads up,
my problem ended up being caused by my all users folder being named different,
in my case my allusers folder was named "all users.windows"
so those users with dual boot or an upgraded OS would run into problems...
so i am all sorted as i ended up have to format and reinstall windows  but just wanted to fill users in on what my problem was.
Employee
Message 16 of 20 (936 Views)
10-20-2011 07:40 PM in reply to: phreaker
Thank phreaker's update very much. :smileyhappy:
Hello all,
In order to help you resolve the issue, here is more information for your reference.
Whether your reinstall your OS but without format the system harddisk?
Please check whether you have below 2 folders in your OS:
  • C:\Documents and Settings\All Users
  • C:\Documents and Settings\All Users.windows
And whether the AdLM folder is happened to be installed in:
  • C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
For your reference, please check out below 2 posts I googled from Internet:
http://www.techsupportforum.com/forums/f10/quick-question-about-all-users-windows-369826.html
http://www.pcreview.co.uk/forums/allusers-windows-t377813.html
Helen
Edited by
Discussion_Admin
Member
kcg231286
Message 17 of 20 (923 Views)
10-21-2011 02:34 AM in reply to: iechaurr
i have downloaded free version of inventor 2012 and installed. but it not yet stated. it gives error msg as failed to send SERIALNUM. i sent error reports but no useful response from autodesk. anybody got solved this solution?
Employee
Message 18 of 20 (918 Views)
10-21-2011 02:46 AM in reply to: kcg231286
Hello kcg231286,
Are you using XP 64 OS? Could you please read the previous post I sent to see whether you have All Users.windows folder as well?
Helen
Member
kcg231286
Message 19 of 20 (907 Views)
10-21-2011 06:25 AM in reply to: HelenChen-Autodesk
i have hp pavilion dv6 1319tx model laptop, windows 7 32bit OS. single boot.
Employee
Message 20 of 20 (835 Views)
10-24-2011 08:13 PM in reply to: kcg231286
Hello kcg231286,
Could you please check whether there is AdWindows.dll from the Bin folder of Inventor installation path?
If there is, what's the version of that file?
Thank you.
Helen
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
