Installation & Licensing
Active Contributor
Message 1 of 6 (497 Views)
Can't uninstall Revit 2012
497 Views, 5 Replies
10-10-2013 06:30 AM
I am trying to unistall Revit 2012 and I cannot access the uninstaller.  I go to add/remove programs and click uninstall and nothing happens.  I briefly see the windows circle 'thinking' but then nothing.
Furthermore, I have tried to open the program and it hangs on the splash screen and won't open.  I have followed all directions from this post:
http://revitclinic.typepad.com/my_weblog/2011/05/revit-2012-hangs-at-splash-screen-or-crashes-with-u...
and it still hangs up and must be forced to close.
I don't want to get the software functioning anymore.  I just want it gone.  Any help would be GREATLY appreciated.
Thanks!
Customer Service
t_gaisf
Message 2 of 6 (492 Views)
Re: Can't uninstall Revit 2012
10-10-2013 06:42 AM in reply to: dgt.mantis
This link might help:
How to remove all Autodesk products from a Windows system
Franz Gaisbauer
Active Contributor
Message 3 of 6 (488 Views)
10-10-2013 06:52 AM in reply to: t_gaisf
Thank you for the replay....however that link definately does not help.
The link you provided basically walks you through Add/Remove programs.  Did you not see the first part of my post?  The uninstaller will not even start when I go to Add/Remove programs.   The program is listed but nothing happens when I double-click it, right click and select uninstall or select uninstall from the menu at the top.
I need an alternative method to remove the program or fix the reason why it is not accessable through Add/Remove programs.
TravisNave
Message 4 of 6 (478 Views)
10-10-2013 07:41 AM in reply to: dgt.mantis
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Contributor
Message 5 of 6 (464 Views)
10-10-2013 11:37 AM in reply to: TravisNave
Thank you Travis.
The first link to the Microsoft Fixit article worked.  It was successfully uninstalled.
Thanks again.
TravisNave
Message 6 of 6 (459 Views)
10-10-2013 12:00 PM in reply to: dgt.mantis
Excellent!  Happy to help!
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
