I'm trying to install Civil3D 2012 from disk on a new laptop (Windows 7, I5 2.5 Ghz, 6 Gb ram). When it gets to "Installing 4 of 13" I get the error message "Can't find file fbxrenderermr-2_5.dll. Make sure you have access to it". It gives the full path, the file is there and there is access. I found 1 post on another blog which had the same problem. The next comment is from the poster who says he is now past that and is having another problem, but doesn't say how he got past this problem.
Thanks for any help,
Eric Black
Check the file permissions and make sure your account, the system, (even everyone if necessary) has full access. Then in your Run box, type regsvr32 and drag that file in. Hit enter and it should register. Try again.
Make sure you are installing with local admin rights, UAC off, and anti-virus disabled. Always.
I have full administrative rights, I unloaded anti-virus software, UAC is off. I started the install again and got to the same spot with the same error message. I opened run "regsvr32, located and dragged the dll file in and hit run. I got an error message "The module (full path)fbxrenderermr-2_5.dll failed to load. Make sure the binary is stored at the specified path or debug it to check to check for problems with the binary or dependent .DLL files. The specified module could not be found". This is the originial disk which I have used several times without this problem. Anything else you can think of?
Eric Black
It's possible the disc has been damaged. Have you considered copying the entire contents to a folder on your HDD and running setup.exe from there? You might have better results.
