I am a registered Autodesk student community user and have successfully downloaded AutoCAD before (through the old downloading tool). Now when I try to download through the student community free downloads page, I get a long, thin white bar with a [CLOSE] button and nothing else. Nothing seems to start automatically downloading either. What's wrong?
Solved by jessica.t. Go to Solution.
Hi Everyone,
This issue has been resolved and you should now all be able to log into the EDU site and download the Product. If you still cannot do so let me know.
Hi @Anonymous
Please, download the product from our Virtual Agent linked here (click on Download Links, select product and version), then use the serial number you should have received from the Education Community to activate the product.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Unfortunenately the link doesnt work. i just see an
autodesk-FAQs....
Please help me.
Are you not able to see this?
Please, make sure you are using the latest version of your browser. Chrome and Firefox are recommended.
Sir, I wish to download the Autodesk AutoCAD Design Suite Ultimate 2015, can i use the serial and key from EDU's 3-year free subscription?
Hi @Anonymous
Your Education Community serial number will only work with software downloaded from the Education Community.
The good news is that all programs included in the AutoCAD Design Suite Ultimate 2015 are available for download in the Education Community.
I hope this helps!
Hi John Carlo,
As long as you have downloaded all parts of the Suite it should be ok. Once you have clicked on the Part 1 .exe files and the installation is done it will automatically look for the Part 2 of the .exe and so on and so forth.
Hi CarloBV,
How long does the extraction process hang for? Do you get any error messages?
Here's a pic. . I let it hang for 30 minutes each attempt and nothing new happens, they are all stuck like that. . no error message appears
Thank you, that's helpful!
It looks like parts of your download may have been blocked, which can be causing the downloaded files to be incomplete and preventing the extractions process from completing. I would suggest disabling your firewall and anti-virus programs and re-downloading the program from our Virtual Agent linked here.
I hope this helps!
Im an architecture student too nad i cant seem to download autocad ive got the same problems with them its says download not available in my country.
Hello, I have a problem to activate 3ds max 2013. Please help me quiekly to activate the 3ds max 2013. Serial Number: XXX-XXXXXXXX Product Key: 495E1 Request code Thank you,
Hi @Anonymous
For security reasons I've removed your serial number from your post.
Please, check my reply to your other post for a resolution for this issue.
Thank you,
