Installation & Licensing
Can Expired Trial AutoCAD and Rental License Coexist
1 REPLY 1
jwalsh52
1376 Views, 1 Reply
An AutoCAD user I know installed the AutoCAD trial download, used the 30 day license (now expired), and susequently has been attempting to install "Revit Lt Suite - Monthly Rental License with Auto-Renewal With Advanced Support".  He hasn't been able to successfully install and run the rental product.  Is it necessary to uninstall the AutoCAD trial software to install and successfully run the rental license version?
1 REPLY 1
TravisNave
in reply to: jwalsh52
No, the other Autodesk software will not interfere with additional packages.  If you are having installation woes, then please post any screencaps and log files here.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
