You can copy the 6 DVD on the same directory and then install from. During
the copy answer yes if there are already one same file or directory.
You can also create an install image but for 2010 you will have some tricks
depends on how you use Vault.
Franck Hervet
"Randall_R" a écrit dans le message de groupe de discussion :
6373781@discussion.autodesk.com...
> We are having problems with installing AutoDesk Inventor 2010 from the 6
> DVD drives, as this process is becoming laboriously slow. Yesterday we
> tried 3 times, but used up a whole day.
> Can the 6 install disks be copied to the hard drive and used as the
> install image rather than to depend upon the slow DVD drive to shuttle the
> data? It is much much faster to read data from the hard drive rather than
> to rely on the DVD drive.
> Thanks for letting us know.
> Randall
> Oh, btw, during install, the program pops a new screen image but erases
> the progress bar with its messages, so a person has to popup a new install
> screen to refresh the data in order to get back to the progress bar.
