Installation & Licensing
Building design suite license
4 REPLIES 4
jdcho
326 Views, 4 Replies
Hopefully this is the right forum for this question.
I have a network license for 2 seats of Building Design Suite and 3 seats for Revit Architecture.  It seems that BDS will only use the BDS license but the revit architecture will use what ever is open.  Is there a way for BDS to use what ever is open or confine revit architecture to only use revit architecture licenses?
4 REPLIES 4
DarrenP
in reply to: jdcho
no you can't change the cascading rules
what you can do is reserve licenses for a specific user using an options file
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
DarrenP
DarrenP
in reply to: DarrenP
or you could split the license file up to 2 separate single license servers
1 for the revit arch license and 1 for the Building design licenses
DarrenP
jdcho
easier of the two solutions, but not what I was looking for.  This will have to do until we upgrade all the machines to building design suites.
Thanks for all the help everybody.
simonn
in reply to: jdcho
hi hijacking your thread!
have you found if you can run revit and max on a building design suite lic at the same time with out revit getting it from else where.
thanks!
Smiley Happy
Administrator Productivity
