Installation & Licensing
Building Design Suite license with regular Revit MEP 2011 installer?
1 REPLY 1
1corey
383 Views, 1 Reply
I'm trying to install Revit MEP 2011.  I have a standalone Building Design Suite 2011 license, but the install discs are at another office so I was hoping I could just use my Revit MEP 2011 installer which I have, with the Building Design Suite serial and key.  Will this work, or will I have to download all 12GB of the Design Suite?
1 REPLY 1
TravisNave
in reply to: 1corey
If your Revit Installer is from the Building Design Suite, it wil work.  If it is from another suite or a stand-alone install, then it will likely not accept your product key as it will not match the suite and will come back as invalid.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
