Is it possible for you to install the building design suite premium 2014 on a 32 bit machine, as our IT Department have tried and failed.
Hello and Welcome to the community!
You can install Building Design Suite 2014 on a windows 7 32 bit machine. Please refer to Building Design Suite 2014 System requirements for all editions to make sure you meet all system requirements.
http://images.autodesk.com/adsk/files/product_design_suite_2014.pdf
Thank you for using the community.
hello
What edition of windows do you have?
http://images.autodesk.com/adsk/files/building_design_suite_premium_2014.pdf < here is the pdf with requirments.
although says win 7 32bit.. ..i think it is only for few programs.
I think that Win 32 bit can't recognize more than 3 Giga ram.. and at requirments needs 4... minimum..
thanks. 🙂
Thanks for the replies, I went online and downloaded the system requirements and sent this to IT but they still cant install it as they say its a 64 bit installation package, but we use the same installer for both bit types wether its 32 or 64.(on our subscription centre it states name of product then 32/64 so it can be used for both. Guess they have to keep on trying.
Thanks again
Oh and we are using windows 7
Please try to download it from http://usa.autodesk.com/adsk/servlet/pc/index?id=19759203&siteID=123112
i mean from Virtual Agent : ASK..
By pressing there appears a windows and then press Download Links > and after that chose the product that u want.
Maybe the file is corrupted..
thanks
Hello.
You cannot use a 64 bit installer on a 32 bit system. It sounds like the installer you are using is the wrong architecture. If you built the install from a USB key, you likely only have the 64 bit version.
You can download the installer that has both from here:
Thank you for taking part in our community!
