Autodesk download manager stops receiving randomly.
I do not want adm on my comp! It makes me only problems, I do not need that!
Please send me direct dl link for Autodesk Inventor HSM 2015 EN-64
Solved by philip.s. Go to Solution.
Hello @brankoje57,
As an alternative to the download managers utilized in the Download Now and Install Now options, you can also utilize standard Browser Download option. This should be located next to the others, and can also be found directly in the Autodek Virtual Agent under Download Links.
*Edit: Missed the previous part about HSM which is not currently located in the VA. Here you go!
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
You're welcome 🙂
