Installation & Licensing
Autodesk 2014 Failure to Install Student Version
1 REPLY 1
kdemares
360 Views, 1 Reply
Hello great gurus of the internet.
Here is the set up, Over the past couple of weeks, I have been getting error messages from Autodesk Job Simulator everytime I restart my computer.  The error message just requests that I send in a report but does not specify what is wrong.  Talking with a collegue, I was recommended that I re-install all my autodesk programs.  Now I find myself unable to finish any installations of autodesk software.  I have reboot-ed my computer. I have checked to make sure everything from Autodesk had been uninstalled, and even got an ethernet cable to insure a solid internet connection to my laptop.
Despite my mesures, I keep coming to the error message below.
Not knowing what this is, I went to the installation log files (Transcription Below) to see if there was something I could find but to no avail.  I am at wit's end because I cannot seem to get this resolved.
All help would be appreciated.  Thank you!
2014/2/7:13:38:32 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/2/7:13:38:32 Kim KAPITOL Path_Length: 155
2014/2/7:13:38:32 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/2/7:13:38:32 Kim KAPITOL Launch
2014/2/7:13:38:32 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/2/7:13:38:32 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AI3BA7.tmp
2014/2/7:13:38:41 Kim KAPITOL === Setup ended ===
2014/2/7:13:38:34 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/2/7:13:38:34 Kim KAPITOL Path_Length: 155
2014/2/7:13:38:34 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AI3BA7.tmp
2014/2/7:13:38:34 Kim KAPITOL Launch
2014/2/7:13:38:36 Kim KAPITOL PageOpen MaintenanceDialog
2014/2/7:13:38:44 Kim KAPITOL PageOpen RepairDialog
2014/2/7:13:38:47 Kim KAPITOL PageOpen MaintVerifyReadyDialog
2014/2/7:13:38:47 Kim KAPITOL PageOpen FullProgressDialog
2014/2/7:13:38:47 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE="" SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:13:48:52 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-1102-0060B0CE6BBA}) Succeeded
2014/2/7:13:48:57 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-2102-0060B0CE6BBA}) Succeeded
2014/2/7:13:48:57 Kim KAPITOL Reinstall Autodesk® AutoCAD® 2014 Succeeded
2014/2/7:13:48:57 Kim KAPITOL PageOpen MaintCompleteDialog
2014/2/7:18:38:00 Kim KAPITOL === Setup ended ===
2014/4/8:23:24:26 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/8:23:24:26 Kim KAPITOL Path_Length: 155
2014/4/8:23:24:26 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/4/8:23:24:26 Kim KAPITOL Launch
2014/4/8:23:24:26 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/4/8:23:24:26 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AI2026.tmp
2014/4/8:23:24:28 Kim KAPITOL === Setup ended ===
2014/4/8:23:24:28 Kim KAPITOL PageOpen MaintenanceDialog
2014/4/8:23:24:33 Kim KAPITOL PageOpen RepairDialog
2014/4/8:23:24:42 Kim KAPITOL PageOpen MaintVerifyReadyDialog
2014/4/8:23:24:42 Kim KAPITOL PageOpen FullProgressDialog
2014/4/8:23:24:56 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE="" SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:23:24:57 Kim KAPITOL Reinstall Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1602
2014/4/8:23:24:58 Kim KAPITOL PageOpen MaintFailedDialog
2014/4/8:23:25:08 Kim KAPITOL === Setup ended ===
2014/4/8:23:25:09 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/8:23:25:09 Kim KAPITOL Path_Length: 155
2014/4/8:23:25:09 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/4/8:23:25:09 Kim KAPITOL Launch
2014/4/8:23:25:09 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/4/8:23:25:09 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIC937.tmp
2014/4/8:23:25:10 Kim KAPITOL === Setup ended ===
2014/4/8:23:25:10 Kim KAPITOL PageOpen MaintenanceDialog
2014/4/8:23:25:12 Kim KAPITOL PageOpen RepairDialog
2014/4/8:23:25:15 Kim KAPITOL PageOpen MaintVerifyReadyDialog
2014/4/8:23:25:15 Kim KAPITOL PageOpen FullProgressDialog
2014/4/8:23:25:15 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE="" SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:23:30:14 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-1102-0060B0CE6BBA}) Succeeded
2014/4/8:23:30:20 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-2102-0060B0CE6BBA}) Succeeded
2014/4/8:23:30:20 Kim KAPITOL Reinstall Autodesk® AutoCAD® 2014 Succeeded
2014/4/8:23:30:20 Kim KAPITOL PageOpen MaintCompleteDialog
2014/4/8:23:30:34 Kim KAPITOL === Setup ended ===
2014/4/9:07:09:12 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:09:12 Kim KAPITOL Path_Length: 155
2014/4/9:07:09:12 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/4/9:07:09:12 Kim KAPITOL Launch
2014/4/9:07:09:12 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/4/9:07:09:12 Kim KAPITOL Setup Windows update reboot is pending
2014/4/9:07:09:19 Kim KAPITOL Setup Autodesk® AutoCAD® 2014 Will restart automatically.
2014/4/9:07:09:19 Kim KAPITOL === Setup ended ===
2014/4/9:07:12:32 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:12:32 Kim KAPITOL Path_Length: 155
2014/4/9:07:12:32 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/4/9:07:12:32 Kim KAPITOL Launch
2014/4/9:07:12:32 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/4/9:07:12:32 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIFF0C.tmp
2014/4/9:07:13:18 Kim KAPITOL === Setup ended ===
2014/4/9:07:12:34 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:12:34 Kim KAPITOL Path_Length: 155
2014/4/9:07:12:34 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIFF0C.tmp
2014/4/9:07:12:34 Kim KAPITOL Launch
2014/4/9:07:13:19 Kim KAPITOL PageOpen MaintenanceDialog
2014/4/9:07:13:56 Kim KAPITOL PageOpen RepairDialog
2014/4/9:07:13:58 Kim KAPITOL PageOpen MaintVerifyReadyDialog
2014/4/9:07:13:58 Kim KAPITOL PageOpen FullProgressDialog
2014/4/9:07:13:59 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="" REINSTALLMODE="ocum" REMOVE="" SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:14:26 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-1102-0060B0CE6BBA}) Succeeded
2014/4/9:07:14:33 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-2102-0060B0CE6BBA}) Succeeded
2014/4/9:07:14:33 Kim KAPITOL Reinstall Autodesk® AutoCAD® 2014 Succeeded
2014/4/9:07:14:33 Kim KAPITOL PageOpen MaintCompleteDialog
2014/4/9:07:16:06 Kim KAPITOL === Setup ended ===
2014/4/9:07:19:47 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:19:47 Kim KAPITOL Path_Length: 155
2014/4/9:07:19:47 Kim KAPITOL Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/4/9:07:19:47 Kim KAPITOL Launch
2014/4/9:07:19:47 Kim KAPITOL CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/4/9:07:19:47 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIA4D4.tmp
2014/4/9:07:19:50 Kim KAPITOL === Setup ended ===
2014/4/9:07:19:48 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:19:48 Kim KAPITOL Path_Length: 155
2014/4/9:07:19:48 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIA4D4.tmp
2014/4/9:07:19:48 Kim KAPITOL Launch
2014/4/9:07:19:49 Kim KAPITOL PageOpen MaintenanceDialog
2014/4/9:07:19:50 Kim KAPITOL PageOpen MaintVerifyReadyDialog
2014/4/9:07:19:52 Kim KAPITOL PageOpen FullProgressDialog
2014/4/9:07:19:52 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:20:55 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-1102-0060B0CE6BBA}) Succeeded
2014/4/9:07:21:01 Kim KAPITOL Reinstall/uninstall Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-2102-0060B0CE6BBA}) Succeeded
2014/4/9:07:21:01 Kim KAPITOL Uninstall Autodesk® AutoCAD® 2014 Succeeded
2014/4/9:07:21:01 Kim KAPITOL PageOpen MaintCompleteDialog
2014/4/9:07:21:05 Kim KAPITOL === Setup ended ===
2014/4/9:07:51:41 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:51:41 Kim KAPITOL Path_Length: 155
2014/4/9:07:51:41 Kim KAPITOL Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/9:07:51:41 Kim KAPITOL Launch
2014/4/9:07:51:41 Kim KAPITOL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-24861377 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:07:51:41 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AID50F.tmp
2014/4/9:07:54:30 Kim KAPITOL === Setup ended ===
2014/4/9:07:51:42 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:07:51:42 Kim KAPITOL Path_Length: 155
2014/4/9:07:51:42 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AID50F.tmp
2014/4/9:07:51:42 Kim KAPITOL Launch
2014/4/9:07:52:13 Kim KAPITOL Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/9:07:54:30 Kim KAPITOL Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/9:07:54:30 Kim KAPITOL Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Kim\AppData\Local\Temp\_AID50F.tmp\Setup\AcSetup.dll
2014/4/9:07:54:30 Kim KAPITOL Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/9:07:54:30 Kim KAPITOL PageOpen LaunchDialog
2014/4/9:07:55:04 Kim KAPITOL PageOpen LicenseDialog
2014/4/9:07:55:04 Kim KAPITOL PageOpen ProductInfoDialog
2014/4/9:07:55:04 Kim KAPITOL PageOpen ProductSelectionDialog2
2014/4/9:07:55:20 Kim KAPITOL PageOpen FullProgressDialog
2014/4/9:07:55:20 Kim KAPITOL Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/4/9:07:55:28 Kim KAPITOL Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/4/9:07:55:28 Kim KAPITOL Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/9:07:55:40 Kim KAPITOL Install DirectX Runtime Succeeded
2014/4/9:07:55:40 Kim KAPITOL Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:56:01 Kim KAPITOL Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:07:56:02 Kim KAPITOL Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/4/9:07:56:30 Kim KAPITOL Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/4/9:07:56:30 Kim KAPITOL Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:56:43 Kim KAPITOL Install Autodesk Material Library 2014 Succeeded
2014/4/9:07:56:44 Kim KAPITOL Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/4/9:07:57:25 Kim KAPITOL Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/4/9:07:57:25 Kim KAPITOL Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:57:32 Kim KAPITOL Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:07:57:32 Kim KAPITOL Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:57:36 Kim KAPITOL Install Autodesk Content Service Succeeded
2014/4/9:07:57:36 Kim KAPITOL Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:07:57:40 Kim KAPITOL Install Autodesk Content Service Language Pack Succeeded
2014/4/9:07:57:41 Kim KAPITOL Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/9:08:04:28 Kim KAPITOL Download Complete ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/9:08:04:32 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Kim\AppData\Local\Temp\_AID50F.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:08:34 Kim KAPITOL Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1603
2014/4/9:08:08:35 Kim KAPITOL Rollback Autodesk Content Service Language Pack Succeeded
2014/4/9:08:08:37 Kim KAPITOL Rollback Autodesk Content Service Succeeded
2014/4/9:08:08:46 Kim KAPITOL Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:08:09:01 Kim KAPITOL Rollback Autodesk Material Library 2014 Succeeded
2014/4/9:08:09:06 Kim KAPITOL Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:08:09:06 Kim KAPITOL Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/9:08:09:06 Kim KAPITOL PageOpen InstallCompleteDialog
2014/4/9:08:09:13 Kim KAPITOL === Setup ended ===
2014/4/9:08:16:55 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:08:16:55 Kim KAPITOL Path_Length: 155
2014/4/9:08:16:55 Kim KAPITOL Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/9:08:16:55 Kim KAPITOL Launch
2014/4/9:08:16:55 Kim KAPITOL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-24861377 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:08:16:55 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIF0C4.tmp
2014/4/9:08:16:58 Kim KAPITOL === Setup ended ===
2014/4/9:08:16:56 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:08:16:56 Kim KAPITOL Path_Length: 155
2014/4/9:08:16:56 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIF0C4.tmp
2014/4/9:08:16:56 Kim KAPITOL Launch
2014/4/9:08:16:57 Kim KAPITOL Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/9:08:16:57 Kim KAPITOL Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Kim\AppData\Local\Temp\_AIF0C4.tmp\Setup\AcSetup.dll
2014/4/9:08:16:57 Kim KAPITOL Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/9:08:16:58 Kim KAPITOL PageOpen LaunchDialog
2014/4/9:08:17:10 Kim KAPITOL PageOpen LicenseDialog
2014/4/9:08:17:10 Kim KAPITOL PageOpen ProductInfoDialog
2014/4/9:08:17:10 Kim KAPITOL PageOpen ProductSelectionDialog2
2014/4/9:08:17:59 Kim KAPITOL PageOpen FullProgressDialog
2014/4/9:08:17:59 Kim KAPITOL Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/4/9:08:17:59 Kim KAPITOL Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/9:08:18:15 Kim KAPITOL Install DirectX Runtime Succeeded
2014/4/9:08:18:15 Kim KAPITOL Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:18:31 Kim KAPITOL Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:08:18:31 Kim KAPITOL Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/4/9:08:18:32 Kim KAPITOL Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:18:46 Kim KAPITOL Install Autodesk Material Library 2014 Succeeded
2014/4/9:08:18:46 Kim KAPITOL Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/4/9:08:18:46 Kim KAPITOL Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:19:05 Kim KAPITOL Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:08:19:06 Kim KAPITOL Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:19:12 Kim KAPITOL Install Autodesk Content Service Succeeded
2014/4/9:08:19:12 Kim KAPITOL Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:19:16 Kim KAPITOL Install Autodesk Content Service Language Pack Succeeded
2014/4/9:08:19:16 Kim KAPITOL Download Skipped ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/9:08:19:16 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Kim\AppData\Local\Temp\_AIF0C4.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:24:41 Kim KAPITOL Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1603
2014/4/9:08:24:43 Kim KAPITOL Rollback Autodesk Content Service Language Pack Succeeded
2014/4/9:08:24:48 Kim KAPITOL Rollback Autodesk Content Service Succeeded
2014/4/9:08:24:58 Kim KAPITOL Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:08:25:14 Kim KAPITOL Rollback Autodesk Material Library 2014 Succeeded
2014/4/9:08:25:17 Kim KAPITOL Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:08:25:17 Kim KAPITOL Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/9:08:32:46 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:08:32:46 Kim KAPITOL Path_Length: 155
2014/4/9:08:32:46 Kim KAPITOL Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/9:08:32:46 Kim KAPITOL Launch
2014/4/9:08:32:46 Kim KAPITOL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-24861377 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:08:32:46 Kim KAPITOL An instance of setup is already running. Only one instance of setup can run at a time.2014/4/9:08:32:49 Kim KAPITOL === Setup ended ===
2014/4/9:08:25:18 Kim KAPITOL PageOpen InstallCompleteDialog
2014/4/9:08:32:52 Kim KAPITOL === Setup ended ===
2014/4/9:08:44:16 Kim KAPITOL === Setup started on KAPITOL by Kim ===
2014/4/9:08:44:16 Kim KAPITOL Path_Length: 155
2014/4/9:08:44:16 Kim KAPITOL Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/9:08:44:16 Kim KAPITOL Launch
2014/4/9:08:44:16 Kim KAPITOL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-24861377 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:08:44:16 Kim KAPITOL Current Directory C:\Users\Kim\AppData\Local\Temp\_AIE66C.tmp
2014/4/9:08:44:20 Kim KAPITOL === Setup ended ===
2014/4/9:08:44:17 Kim KAPITOL Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/9:08:44:19 Kim KAPITOL Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Kim\AppData\Local\Temp\_AIE66C.tmp\Setup\AcSetup.dll
2014/4/9:08:44:19 Kim KAPITOL Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/9:08:44:19 Kim KAPITOL PageOpen LaunchDialog
2014/4/9:08:44:42 Kim KAPITOL PageOpen LicenseDialog
2014/4/9:08:44:42 Kim KAPITOL PageOpen ProductSelectionDialog2
2014/4/9:08:44:48 Kim KAPITOL PageOpen LicenseDialog
2014/4/9:08:44:48 Kim KAPITOL PageOpen LaunchDialog
2014/4/9:08:44:52 Kim KAPITOL PageOpen LicenseDialog
2014/4/9:08:44:52 Kim KAPITOL PageOpen ProductInfoDialog
2014/4/9:08:44:52 Kim KAPITOL PageOpen ProductSelectionDialog2
2014/4/9:08:45:33 Kim KAPITOL PageOpen FullProgressDialog
2014/4/9:08:45:33 Kim KAPITOL Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/4/9:08:45:33 Kim KAPITOL Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/9:08:45:45 Kim KAPITOL Install DirectX Runtime Succeeded
2014/4/9:08:45:45 Kim KAPITOL Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:46:00 Kim KAPITOL Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:08:46:00 Kim KAPITOL Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/4/9:08:46:00 Kim KAPITOL Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:46:13 Kim KAPITOL Install Autodesk Material Library 2014 Succeeded
2014/4/9:08:46:14 Kim KAPITOL Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/4/9:08:46:14 Kim KAPITOL Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:46:28 Kim KAPITOL Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:08:46:28 Kim KAPITOL Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:46:33 Kim KAPITOL Install Autodesk Content Service Succeeded
2014/4/9:08:46:34 Kim KAPITOL Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:46:40 Kim KAPITOL Install Autodesk Content Service Language Pack Succeeded
2014/4/9:08:46:40 Kim KAPITOL Download Skipped ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/9:08:46:40 Kim KAPITOL Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Kim\AppData\Local\Temp\_AIE66C.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:08:54:30 Kim KAPITOL Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1603
2014/4/9:08:54:31 Kim KAPITOL Rollback Autodesk Content Service Language Pack Succeeded
2014/4/9:08:54:37 Kim KAPITOL Rollback Autodesk Content Service Succeeded
2014/4/9:08:54:48 Kim KAPITOL Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/9:08:55:01 Kim KAPITOL Rollback Autodesk Material Library 2014 Succeeded
2014/4/9:08:55:05 Kim KAPITOL Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/9:08:55:05 Kim KAPITOL Rollback DirectX Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
byron.morales
in reply to: kdemares
We apologize for the inconvenience this is causing you. Please do a complete uninstall of All Autodesk software from the computer byt following instructions below, including removing the program folders and registry entries described:
http://usa.autodesk.com/getdoc/id=TS45252
Then please Rename or Delete the following file:
   Windows XP
   C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
   Vista/Windows 7/Windows 8
   C:\ProgramData\FLEXnet\adskflex_*_tsf.data
Reboot computer, Turn Antivirus Off, Clear the contents of the %temp% folder and then attempt to re-install the Autodesk software from oldest to newest versions.
Byron M.
Administrator Productivity
