Dear Sirs,
I've been using Autocad almost since i was born, from 2000 to 2010. Never had any problems with drawing, functions, and installation too. Recently, I tried to install Autocad Mecanical 2012 but installation failed after few minutes. The window just has shown : Some products failed to install (acad mechanical 2012, autodesk inventor 2012).
I tried also to downnload and install a trial version, failed again
I'm using windows 7 pro,full updates, with net framework 4 (client profile and extended), temporaty folder and registery clean, antivirus turned off
Does any of you genious have any idea how to solve this installation failure
Thanks in advance
Dave
would you please attach the installation log file which located in %temp% folder? see how to find the log file:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8254094&linkID=9240617.
Also,please make sure that using local administrator to login and install, ture off UAC.
Would you please upload your installation log file and the error image?
Stuck at where? Initialization or somewhere? Did you try to copy all the contents of disc to your local hard drive and then install?
