Show only
Search instead for
Autocad 2011 Fail to unistall or Repair to a working condition
I get error message when try to to unistall.
Try repair and reinstall : Autocad 2011 would not launch.
Try down load program for Solution Center, it down load on C drive C: Autodesk , it does not allow to install shows ("new version of 2011). Service packs where added and removed. No succes
Remove the applicaiton from Add/Remove programs using the Microsoft Installer Clean-up Utility (msicuu2.exe) and then delete the AutoCAD 2011 program files folder. At that point you should be able to reinstall.
Travis Nave Need help in your post? Mention me with @TravisNave
