Installation & Licensing
Member
Message 1 of 7 (2,522 Views)
AutoCad Install Failure. Please Help!!
2522 Views, 6 Replies
01-11-2013 01:32 PM
Hello, I am trying to install this AutoCad for my class, and I have an assignment due next monday. Like many others, I am having problems downloading this software. I am not sure what I am doing wrong and have tried reinstalling sevferal times. I have seen someone suggest deleting C++ files that are on my computer. I found these files and deleted them accordingly. However, after doing this and reinstalling multiple times, I am still unable to download this program. If someone could help my, I'd sure appreciate it.
To help, I copied and pasted my failure log for AutoCad and Inventor Fusion below. Please help as I have an assignment due by the end of this weekend. If there is anymore information you would like, just tell me.
Thank you in advance.
AutoCad Failure Log:
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:06:57 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:06:57 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:07:27 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:18:13:21 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:18:13:22 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:23 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:23 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:18:13:31 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:18:13:31 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:32 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:32 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:18:13:40 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:18:13:40 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:13:45 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:13:45 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:18:14:33 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:18:14:33 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:14:49 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:18:14:49 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:15:10 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:15:10 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:15:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:18:15:50 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:15:55 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:16:16 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:07 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:07 Yosef #2 YOSEFSLAPTOP2 Download Paused CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:54 Yosef #2 YOSEFSLAPTOP2 Download User Resume CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:18:41 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:18:41 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:18 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:19:18 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:26 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:18:19:26 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:37 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:18:19:37 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:19:42 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:20:03 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:23:18 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:23:19 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AIAC87.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:28:28 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:18:28:28 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:28:34 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD_en-us <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:28:54 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD_en-us <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:30:45 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:30:45 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AIAC87.tmp\_la7A8D.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:50 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:18:31:50 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:55 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:18:31:58 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:18:31:58 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:18:32:08 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:18:32:22 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:18:33:25 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:18:33:29 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:18:33:38 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:18:33:43 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:34:32 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:18:34:38 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:18:35:10 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:18:45:03 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:44:27 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:44:27 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:44:30 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:45:02 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:45:03 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:18:47:46 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:18:47:46 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:47:50 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:47:50 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:18:48:29 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:18:48:29 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:48:40 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:18:48:40 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:48:57 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:48:57 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:49:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:18:49:36 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:49:54 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:49:54 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:50:36 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:44 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:18:50:44 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:18:50:50 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:52:15 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:54:14 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:54:15 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI254.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:59:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:18:59:53 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:00:49 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:00:50 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI254.tmp\_la2FD.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:19:02:08 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:19:02:08 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:19:02:09 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:19:02:09 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:19:02:11 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:19:02:24 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:19:02:38 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:19:03:51 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:19:03:56 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:19:04:05 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:19:04:09 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:19:04:58 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:19:05:01 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:19:05:01 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:19:05:03 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:20:13:15 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:20:14:37 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:20:14:37 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:20:14:41 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:20:17:48 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:20:17:49 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:20:17:55 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:20:17:55 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:20:18:38 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:20:18:38 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:18:52 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:20:18:52 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:20:19:13 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:20:19:13 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:19:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:20:19:51 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:20:20:10 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:20:20:10 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:06 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:20:21:06 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:16 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:20:21:16 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:23 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:20:21:23 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:21:57 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:23:51 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:23:53 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI918A.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:29:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:20:29:52 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:30:43 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:30:43 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI918A.tmp\_la5024.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:32:18 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:20:32:18 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:20:32:22 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:20:32:22 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:20:32:23 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:20:32:35 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:20:32:53 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:20:34:11 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:20:34:16 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:20:34:27 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:20:34:31 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:20:35:27 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:20:35:30 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:20:35:30 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:20:35:32 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:20:47:06 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:21:41:17 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:21:41:12 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:21:41:12 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:21:41:16 Yosef #2 YOSEFSLAPTOP2 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:21:41:17 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:21:41:36 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:21:41:37 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:41:47 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:41:47 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:21:41:53 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:21:41:53 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:42:03 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:42:03 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:21:42:49 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:21:42:49 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:43:02 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:21:43:03 Yosef #2 YOSEFSLAPTOP2 Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:21:43:03 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:12 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:21:44:12 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:24 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:21:44:24 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:33 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:21:44:33 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:44:34 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AID4F1.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:50:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:21:50:53 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:50:54 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AID4F1.tmp\_laB569.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:30 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:21:52:30 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:21:52:42 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:21:52:42 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:21:52:53 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:21:53:07 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:21:54:25 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:21:54:29 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:21:54:38 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:21:55:02 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:21:55:50 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:21:55:55 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:21:56:12 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:22:30:13 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:22:28:33 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:22:28:33 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:22:28:36 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:22:30:12 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:22:30:13 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:22:30:50 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:22:30:50 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:30:57 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:30:57 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/10:22:31:01 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/10:22:31:01 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:03 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:03 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/1/10:22:31:07 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/1/10:22:31:07 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:11 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:11 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:22:31:18 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:22:31:18 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:21 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:21 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:22:31:28 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:22:31:28 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:22:31:44 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:22:31:44 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:22:32:21 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:22:32:21 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:32:35 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:22:32:35 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:22:33:23 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:22:33:23 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:33:44 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:22:33:44 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:22:34:58 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:22:34:58 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:13 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:22:35:13 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:25 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:22:35:25 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:32 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:22:35:32 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:41:06 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:41:08 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI2E67.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:47:36 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:22:47:36 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:48:45 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:48:46 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI2E67.tmp\_laB31F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:50:04 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:22:50:04 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:50:10 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:22:50:10 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:50:17 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:50:17 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:22:50:20 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:22:50:20 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:22:50:31 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:22:50:45 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:22:52:08 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:22:52:13 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:22:52:22 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:22:52:47 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:22:53:28 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:22:53:34 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:22:55:04 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:23:13:46 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:23:13:43 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:23:13:43 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:23:13:45 Yosef #2 YOSEFSLAPTOP2 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:23:13:46 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:23:14:05 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:23:14:06 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:06 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:23:15:12 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:23:15:12 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:26 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:23:16:26 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:39 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:23:16:39 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:47 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:23:16:47 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:16:48 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI89E0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:23:14 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:23:23:14 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:23:15 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI89E0.tmp\_la43A3.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:24:55 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:23:24:55 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:23:25:10 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:23:25:10 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:23:25:19 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:23:25:32 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:23:26:55 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:23:27:00 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:23:27:08 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:23:27:34 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:23:28:15 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed
Member
Message 2 of 7 (2,519 Views)
Re: AutoCad Install Failure. Please Help!!
01-11-2013 01:33 PM in reply to: ymaynie
Me again. I promised the Fusion error log, so here it is as well.
Inventor Fusion Failure Log:
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
DarrenP
Message 3 of 7 (2,508 Views)
01-11-2013 01:57 PM in reply to: ymaynie
Member
Message 4 of 7 (2,505 Views)
01-11-2013 02:12 PM in reply to: DarrenP
I have looked through the list you sent. I'm not trying to be insulting, but there don't seem to be any solutions, just more people asking similar questions.
DarrenP
Message 5 of 7 (2,503 Views)
01-11-2013 02:14 PM in reply to: ymaynie
DarrenP
Message 6 of 7 (2,504 Views)
01-11-2013 02:15 PM in reply to: DarrenP
Member
Message 7 of 7 (2,480 Views)
01-11-2013 07:02 PM in reply to: DarrenP
I did the C++ thing already, multiple times. It still won't download.
Also, I must be dumber than I thought, because I can not figure this out. Anything more specific you could suggest?
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
