Installation & Licensing
AutoCad Civil 3D .rar file won't open
4 REPLIES 4
5097 Views, 4 Replies
I have tried 3 times to unrar the second part of the 2 part AutoCad Civil 3D download and get an error message that says it could be corrupted etc.(it gets up to around 76% each time before it stops)
Does anyone know how I can unrar this .rar file. The .exe file (part 1 of the download) downloaded fine. I haven't tried to install it yet....I was waiting to be able to unrar the 1st one.  I followed all the instructions for downloading that the site said and they both downloaded fine but I can't get that .rar file to unrar. HELP!
4 REPLIES 4
c__h
Don't unrar it.
Simply have both files in the same folder, and run the exe. It automatically un-rars it.
in reply to: c__h
Thank you, I will do that.
cavemom
did this work for you? I am having the same problem
TravisNave
in reply to: cavemom
It's all self-extracting from the first .exe download.  So long as the other .rar file(s) are in the same location, it will extract without error.  If files are missing, you will receive an alert.  Afterwards run the setup and you'll be fine.
Autodesk Forums:
Administrator Productivity
