After I install AutoCAD 2013 trial install, I try to open it and it gets hung up on checking license then closes immdiately.
I also have AutoCAD Mechanical on this computer, not sure if this would cause problems.
The problem is with the ProductInformatin.pit file, most likely. This file will need to be renamed.
Windows XP: C:\Documents and settings\All Users\Application Data\Autodesk\ADLM
Windows 7: C:\ProgramData\Autodesk\ADLM
By default, the AdlM folder is hidden. In Explorer, click Tools > Folder Options, and go to the View tab. Select the Show hidden files and folders option. You should now be able to see that folder.
The problem is, if you rename/delete this file, your Mechanical will not work anymore. Might not be worth the trial...
I tried what you said and renamed productinformation.pit to productinformation1.pit and reinstalled Autocaad 2013 and I'm still having the same problem. below is a copy of the log from that file.
4332 2012/04/06 08:33:08 Reason=Fatal error 4332 2012/04/06 08:33:08 ComputerName=SSIPC1
4332 2012/04/06 08:33:08 OS=6.1.7601.Service Pack 1
4332 2012/04/06 08:33:08 File=AdlmIntSATSLicense.cpp,Line=342 4332 2012/04/06 08:33:08 AdlmIntError=5 [Unable to launch or connect to LMU] 4332 2012/04/06 08:33:08 Reason=Fatal error
4332 2012/04/06 08:33:08 ComputerName=SSIPC1 4332 2012/04/06 08:33:08 OS=6.1.7601.Service Pack 1
4332 2012/04/06 08:33:08 File=AdlmIntSATSLicense.cpp,Line=2278 4332 2012/04/06 08:33:08 AdlmIntError=17 [The license was not found] 3792 2012/04/06 08:36:21 Reason=Fatal error
3792 2012/04/06 08:36:21 ComputerName=SSIPC1 3792 2012/04/06 08:36:21 OS=6.1.7601.Service Pack 1
3792 2012/04/06 08:36:21 File=AdlmIntSATSLicense.cpp,Line=342 3792 2012/04/06 08:36:21 AdlmIntError=5 [Unable to launch or connect to LMU] 4428 2012/04/06 08:39:11 Reason=Fatal error
4428 2012/04/06 08:39:11 ComputerName=SSIPC1 4428 2012/04/06 08:39:11 OS=6.1.7601.Service Pack 1
4428 2012/04/06 08:39:11 File=AdlmIntSATSLicense.cpp,Line=342 4428 2012/04/06 08:39:11 AdlmIntError=5 [Unable to launch or connect to LMU] 1664 2012/04/06 09:03:57 Reason=Fatal error
1664 2012/04/06 09:03:57 ComputerName=SSIPC1 1664 2012/04/06 09:03:57 OS=6.1.7601.Service Pack 1
1664 2012/04/06 09:03:57 File=AdlmIntSATSLicense.cpp,Line=342 1664 2012/04/06 09:03:57 AdlmIntError=5 [Unable to launch or connect to LMU] 1664 2012/04/06 09:03:57 Reason=Fatal error
1664 2012/04/06 09:03:57 File=AdlmIntSATSLicense.cpp,Line=2278 1664 2012/04/06 09:03:57 AdlmIntError=17 [The license was not found] 6096 2012/04/06 13:54:00 Reason=Fatal error
6096 2012/04/06 13:54:00 ComputerName=SSIPC1 6096 2012/04/06 13:54:00 OS=6.1.7601.Service Pack 1
6096 2012/04/06 13:54:00 File=AdlmIntSATSLicense.cpp,Line=342 6096 2012/04/06 13:54:00 AdlmIntError=5 [Unable to launch or connect to LMU] 6096 2012/04/06 13:54:00 Reason=Fatal error
6096 2012/04/06 13:54:00 File=AdlmIntSATSLicense.cpp,Line=2278 6096 2012/04/06 13:54:00 AdlmIntError=17 [The license was not found] 1468 2012/04/06 13:57:08 Reason=Fatal error
1468 2012/04/06 13:57:08 ComputerName=SSIPC1 1468 2012/04/06 13:57:08 OS=6.1.7601.Service Pack 1
1468 2012/04/06 13:57:08 File=AdlmIntLicense.cpp,Line=584 1468 2012/04/06 13:57:08 VendorID=6 [ADLMPIT]
1468 2012/04/06 13:57:08 VendorError=24 [Unable to locate the Product Information Table File]
1468 2012/04/06 13:57:08 Reason=Fatal error 1468 2012/04/06 13:57:08 ComputerName=SSIPC1
1468 2012/04/06 13:57:08 File=AdlmIntLicense.cpp,Line=585 1468 2012/04/06 13:57:08 AdlmIntError=41 [Product Information Table file is not found] 1268 2012/04/06 13:57:20 Reason=Fatal error
1268 2012/04/06 13:57:20 ComputerName=SSIPC1 1268 2012/04/06 13:57:20 OS=6.1.7601.Service Pack 1
1268 2012/04/06 13:57:20 File=AdlmIntLicense.cpp,Line=584 1268 2012/04/06 13:57:20 VendorID=6 [ADLMPIT]
1268 2012/04/06 13:57:20 VendorError=24 [Unable to locate the Product Information Table File]
1268 2012/04/06 13:57:20 Reason=Fatal error 1268 2012/04/06 13:57:20 ComputerName=SSIPC1
1268 2012/04/06 13:57:20 File=AdlmIntLicense.cpp,Line=585 1268 2012/04/06 13:57:20 AdlmIntError=41 [Product Information Table file is not found] 5540 2012/04/06 14:13:01 Reason=Fatal error
5540 2012/04/06 14:13:01 ComputerName=SSIPC1 5540 2012/04/06 14:13:01 OS=6.1.7601.Service Pack 1
5540 2012/04/06 14:13:01 File=AdlmIntLicense.cpp,Line=584 5540 2012/04/06 14:13:01 VendorID=6 [ADLMPIT]
5540 2012/04/06 14:13:01 VendorError=24 [Unable to locate the Product Information Table File]
5540 2012/04/06 14:13:01 Reason=Fatal error 5540 2012/04/06 14:13:01 ComputerName=SSIPC1
5540 2012/04/06 14:13:01 File=AdlmIntLicense.cpp,Line=585 5540 2012/04/06 14:13:01 AdlmIntError=41 [Product Information Table file is not found] 2668 2012/04/06 14:18:00 Reason=Fatal error
2668 2012/04/06 14:18:00 ComputerName=SSIPC1 2668 2012/04/06 14:18:00 OS=6.1.7601.Service Pack 1
2668 2012/04/06 14:18:00 File=AdlmIntSATSLicense.cpp,Line=342 2668 2012/04/06 14:18:00 AdlmIntError=5 [Unable to launch or connect to LMU]
Yeah, it's not recreating the pit file. Licensing will not work correctly.
