if the UK version is the same as the Finnish version (International
English), there is no PLU. You move the program from workstation to
workstation by deleting the old installation and installing on the new
workstation. Authorization is done using the same authorizationcode you
received for the 1st workstation. The code is only serialnumber
dependent. Remember to read the license agreement carefully! Especially
this part (from the cd's EULA directory, file named United Kingdom.rtf):
Additional Installation: Except with Educational, Student and
Evaluation Versions, you may make a second copy of the Software on the
hard disk of a second computer owned by you or under your control
provided that (1) the original and second copies are used only by the
same person; (2) the second copy is installed and used only on a
notebook computer, home computer, or other non-server computer away from
your usual work location for the purpose of enabling you to perform work
while away from your usual work location; (3) only one of the Software
copies is in use at any one time; (4) the second copy of the Software is
used exclusively with the copy protection device (if any) supplied with
the Software, and (5) the Software is not licensed and/or labelled as an
Educational Version or Student Version.
Cheers,
Petri Ahava
CAD-Q Finland
Joe Bloggs wrote:
> Does anyone know how to install the PLU for a UK version of LT2002?
> thanks in advance
> Martin Aitken
