We need to dimension hardware and Citrix needs for running 40 AutoCAD Civil 3D in a virtual environment. Can you help me? Is there a technical brochure? The graphical performance is important.
Start here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16785740&linkID=9240617
You might also discuss with your Reseller. Keep in mind that special network licenses are required to use AutoCAD in a Citrix environment to comply with the EULA.
Hey Travis,
do you know yet if using Citrix with Civil 3D 2013 violates your license agreement. I really need to get this setup.
Thanks!
From what I can tell thus far, Citrix is still supported from the other 2012 suites that supported it previously. However, I do not find anything in the support for Civil 3D 2013 that has support for Citrix yet. It may be announced later, but as for the time of this post, it is still not supported. Let's hope that changes in the near future.
