Installation & Licensing
AutoCAD 2011 Trial Asks for S/N & Product Key ~ Will not run
2 REPLIES 2
1665 Views, 2 Replies
I downloaded CAD 2011 trial version and installed it.  During install, I chose to run it as a trial version on one of the early screens.  After installation, a dialog box appears that asks for serial number and product info.  I've searched for temp SN & product code, but have found nothing.  I'm looking for a resolution.  Any clues?
2 REPLIES 2
TravisNave
If you have previously run a trial, then you cannot reinstall a trial.  Otherwise, you can try putting in all zeroes and see if it will work for you.  However, if your trial thinks it is expired already, then you are probably out of luck.
Autodesk Forums:
I have not previously run a trial and have tried entering all zeros with no success.
Administrator Productivity
