Installation & Licensing
*Teff, Michael
Message 1 of 3 (148 Views)
AutoCAD 2000 on a Windows NT Cluster Server
148 Views, 2 Replies
02-07-2000 02:30 PM
Ok, I have a question. I would like to setup AutoCAD 2000 on a MS Windows
Cluster Server. The way the cluster is setup is, two physical nodes share
the hard drives where the software is to be installed. The end user will
be accessing the nodes through a virtual server.
What would be the process to have ADLM setup so that it can work...no matter
which physical node is being used. Since the process requires a specific
autorization number based on the server. Is it possible to setup ADLM as a
cluster service?
*Milana, Jerry
Message 2 of 3 (148 Views)
Re: AutoCAD 2000 on a Windows NT Cluster Server
02-08-2000 12:25 PM in reply to: *Teff, Michael
Michael,
We have never tested any component of AutoCAD in a cluster environment, so there
is no telling what may or may not work with one exception, AdLM. AdLM is not
going to work in this kind of environment. AdLM server binds its authentication
to the primary network adapter. This is why we also do not support AdLM server
on a system with multiple network adapters because if primary status flips, you
loose authentication and AdLM will not issue licenses.
Jerry Milana,
Autodesk Product Support
> cluster service?
*Teff, Michael
Message 3 of 3 (148 Views)
Re:
02-08-2000 01:46 PM in reply to: *Teff, Michael
Not the answer I wanted.... but that's what I figured would be the
answer.... Thanks
"Jerry Milana" wrote in message
news:38A07BAE.C167C85@autodesk.com...
> Michael,
there
not
authentication
server
flips, you
> Jerry Milana,
Windows
share
will
matter
specific
as a
> > cluster service?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
