Installation & Licensing
Auto desk building design premium 2012 fails to install
10 REPLIES 10
Message 1 of 11
deanwalsh2013
363 Views, 10 Replies
HI,
      I tried to install the above many times the whole suite or just autocad 2012 on its own but everytime see's the same result error 1619 direct x failure and 1603 error also.  Now I have been reading alot of these forums and done several things and none have worked. I have installed direct x manual redistrubition package, uninstalled Microsoft C++ 2005 sp1 , deleted temp folders files and edited the registry, checked the permisions but I am at a loss. This is a fresh install of XP PRO SP3 updated, No AV installed. Please if anyone has more suggestions here the log.
Dean
10 REPLIES 10
Message 2 of 11
TravisNave
in reply to: deanwalsh2013
Are you installing any service packs during the installation?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 11
No I am not instaslling  any service packs sp3 is installed. Just doing a fresh install now as we speak.
Message 4 of 11
RAMasterson
in reply to: TravisNave
Travis,
We were having the same issue as the OP and excluding the service packs did the trick.
I realize the there are no service packs for 2014 yet, but have you heard if this issue has been addressed in the 2014 installer? We typically wait for the first SP before I deploy the new release.
Message 5 of 11
deanwalsh2013
in reply to: RAMasterson
are you talking about autodesk service pack or windows service pack?
Message 6 of 11
TravisNave
Autodesk service packs. They often fail the installer. Choose never to
install them. Update after install.
Autodesk Forums:
Message 7 of 11
TravisNave
@RAMasterson wrote:
Travis,
Guess we won't know until SP1!  Smiley Very Happy
Autodesk Forums:
Message 8 of 11
deanwalsh2013
is that an option under customer install?? Do you see anything obvious in the log file I might be missing???
My installer is on the Autodesk usb stick aswell if that makes a difference, now yesterday i did copy this to the machine but that never worked either!
Message 9 of 11
TravisNave
Message 10 of 11
deanwalsh2013
Thank you very much will try this and let you know!
Message 11 of 11
After the long haul I got this some what installed, I did not succeed getting it installed on XP PRO SP3, but wiping the machine and putting XP PRO SP2 with no updates finally got it installing with NO SERVICE PACKS for autodesk instailling. Revit did not get installed but it's ok for the moment.
Travis thank you very much I had such a nightmare with this for quite a while. Smiley Happy
Administrator Productivity
