Installation & Licensing
hgu
New Member
Message 1 of 4 (121 Views)
AdLM will not start on a Windows 2000 Server
121 Views, 3 Replies
07-04-2000 01:51 AM
AdLM was intalled on a Win2000 Server without problems. When we attempted to start it (both automatic and manual)
we got the following error:
Could not start ad:elmd.exe check system log for reason.
In this log the following was stated:
Only one usage of each socket adress (protocol/network/adress/port) is normalt admitted
Any idea out there? We have gone trough the usual checks (multiple network cards, RAS modems, port adresses)
*Hurley, Shaan
Message 2 of 4 (121 Views)
Re: AdLM will not start on a Windows 2000 Server
07-05-2000 05:38 AM in reply to: hgu
Please check the online Knowledge Base for the documented solution.
(copy the entire URL to your browser)
http://www3.autodesk.com/adsk/support/techdoc/0,,157553--125452-20022_21837,
00.html
Sincerely,
Shaan Hurley
Autodesk Beta Programs
http://betaprograms.autodesk.com
"hgu" wrote in message
news:ef281d4.-1@WebX.SaUCah8kaAW...
normalt admitted
*milana, jerry
Message 3 of 4 (121 Views)
Re:
07-05-2000 10:23 AM in reply to: hgu
Harald,
Actually, I do not think the Knowledge Base item Shaan points you to is
going to help much yet. That item deals with a DLL problem on Windows 2000
AutoCAD clients.
Your problem appears to be that some service is already grabbing udp port
1422. Autodesk has registered udp 1422, so any other service that happens
to be using this port is stepping outside of convention. Your best bet to
resolve this problem (unless you already know what is using udp 1422) is to
review all services running on your server and turn off everything that did
not come with the operating system. Then try AdLM, which should start.
Next turn on one service at a time until AdLM will not start again. Once
you find the offending service, contact the developer and ask them to switch
which port they use, explaining that 1422 is registered to Autodesk.
Jerry Milana,
Autodesk Product Support
"Shaan Hurley" wrote in message
news:ef281d4.0@WebX.SaUCah8kaAW...
> 00.html
> Sincerely,
> Shaan Hurley
attempted
> normalt admitted
network
*milana, jerry
Message 4 of 4 (121 Views)
Re:
07-05-2000 10:42 AM in reply to: hgu
By the way, you can confirm that rouge udp 1422 usage is in fact your
problem by entering the following at a command prompt (DOS Window):
netstat -a -p udp
In the output look for a line like:
UDP paradise:1422 *:*
where paradise is the hostname of the system. If udp 1422 shows up on this
report, something is using it and if it is not AdLM then it is stepping on
our registered port.
jerry
"jerry milana" wrote in message
news:ef281d4.1@WebX.SaUCah8kaAW...
> Harald,
2000
> AutoCAD clients.
to
did
switch
> Jerry Milana,
> > 00.html
> > Sincerely,
> > Shaan Hurley
> attempted
> > normalt admitted
> network
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
