Installation & Licensing
*Johnson, Paul
Message 1 of 11 (114 Views)
ADLM (2000i) and Win2000
114 Views, 10 Replies
01-08-2001 04:57 AM
I have a Pentium 200 computer that i specifically use as just a license
manager (TCP/IP)
it has 48 mb RAM
2 GB Hard Drive
Windows 2000 SP1
and the ADLM Only install of the License Manager from the AutoCAD 2000i CD
No Modem
computer name is lower case
only one NIC card
Static IP (subnet, DNS servers, etc.)
can ping to other computers
etc.......
Even after rebooting i can't run the Admin appliation
Error is "Can't generate a server code .........."
Please help
Paul Johnson
Crawford, Murphy & Tilly, Inc.
600 N. Commons Drive Ste. 107
Aurora, Illinois 60504
630-820-1022 Voice
630-820-0350 Fax
http://www.cmtengr.com
pjohnson@cmtengr.com
*martin, jason
Message 2 of 11 (114 Views)
Re: ADLM (2000i) and Win2000
01-08-2001 05:20 AM in reply to: *Johnson, Paul
According to autodesk TS18368 the only os's that are supported for installing adlm are
w95
w98
nt4w
nt4s
I've not tried it on w2k but a response to a post of mine back in November implied that it
should work. I don't know if TS18368 is old and incorrect of still up todate.
sorry I'm not more help.
"Paul Johnson" wrote in message
news:1847E837C5CBDE57210D97C9174D8A01@in.WebX.SaUCah8kaAW...
> manager (TCP/IP)
> it has 48 mb RAM
> 2 GB Hard Drive
> Windows 2000 SP1
> No Modem
> only one NIC card
> etc.......
> Please help
> Paul Johnson
> 630-820-1022 Voice
> 630-820-0350 Fax
*Johnson, Paul
Message 3 of 11 (114 Views)
Re:
01-08-2001 05:24 AM in reply to: *Johnson, Paul
Thank You for your comments. Hope some one from AutoDESK is seeing this and
can confirm yes or no about ADLM and Windows 2000
"jason martin" wrote in message
news:7B252DC54957707D376239B47452594F@in.WebX.SaUCah8kaAW...
installing adlm are
> w95
> w98
> nt4w
> nt4s
implied that it
todate.
> > manager (TCP/IP)
> > it has 48 mb RAM
> > 2 GB Hard Drive
> > Windows 2000 SP1
CD
> > No Modem
> > only one NIC card
> > etc.......
> > Please help
> > Paul Johnson
> > 630-820-1022 Voice
> > 630-820-0350 Fax
*kanotspell
Message 4 of 11 (114 Views)
01-08-2001 05:32 AM in reply to: *Johnson, Paul
I am running the 2000i adlm on a w2k pro machine, I haven't authorized it
yet but the server code is stable. Just so you know it can work. can you
ping and be pinged by name and IP?
Paul Johnson wrote in message
> manager (TCP/IP)
> it has 48 mb RAM
> 2 GB Hard Drive
> Windows 2000 SP1
> No Modem
> only one NIC card
> etc.......
> Please help
> Paul Johnson
> 630-820-1022 Voice
> 630-820-0350 Fax
*Johnson, Paul
Message 5 of 11 (114 Views)
Re:
01-08-2001 05:39 AM in reply to: *Johnson, Paul
I can ping no problem
just can't run the AdLM Admin Application.
"kanotspell" wrote in message
news:C9A245010997D5BB2AD64E6CC6BE2671@in.WebX.SaUCah8kaAW...
> > manager (TCP/IP)
> > it has 48 mb RAM
> > 2 GB Hard Drive
> > Windows 2000 SP1
CD
> > No Modem
> > only one NIC card
> > etc.......
> > Please help
> > Paul Johnson
> > 630-820-1022 Voice
> > 630-820-0350 Fax
*Support\, Autodesk
Message 6 of 11 (114 Views)
01-08-2001 05:54 PM in reply to: *Johnson, Paul
Paul,
Just for Information TS 18368 is out of date. When you installed were you
logged in as Administrator ? Also, will the ADLM Admin application not run
at all or do you get the dialog with the host name etc ?
Simon Gillis
Product Support Analyst
AMG Product Support UK
Worldwide Support & Services, Autodesk
> manager (TCP/IP)
> it has 48 mb RAM
> 2 GB Hard Drive
> Windows 2000 SP1
> No Modem
> only one NIC card
> etc.......
> Please help
> Paul Johnson
> 630-820-1022 Voice
> 630-820-0350 Fax
*Johnson, Paul
Message 7 of 11 (114 Views)
Re:
01-08-2001 09:26 PM in reply to: *Johnson, Paul
I was logged in as administrator
and
a "skeleton" dialog box opens it pauses for about 5 seconds then another
dialog box opens with the error message "can't generate server code. please
enter manually" once i ok that box the whole
admin application shuts down
"Simon Gillis (Autodesk Support)" wrote in message
news:57AB31A2B9D99E0ACB600B4D3FB1D433@in.WebX.SaUCah8kaAW...
> Paul,
> Simon Gillis
> > manager (TCP/IP)
> > it has 48 mb RAM
> > 2 GB Hard Drive
> > Windows 2000 SP1
CD
> > No Modem
> > only one NIC card
> > etc.......
> > Please help
> > Paul Johnson
> > 630-820-1022 Voice
> > 630-820-0350 Fax
*Johnson, Paul
Message 8 of 11 (114 Views)
Re:
01-09-2001 05:54 AM in reply to: *Johnson, Paul
Here is a graphic of what i get
> Paul,
> Simon Gillis
> > manager (TCP/IP)
> > it has 48 mb RAM
> > 2 GB Hard Drive
> > Windows 2000 SP1
CD
> > No Modem
> > only one NIC card
> > etc.......
> > Please help
> > Paul Johnson
> > 630-820-1022 Voice
> > 630-820-0350 Fax
*milana, jerry
Message 9 of 11 (114 Views)
Re:
01-09-2001 11:33 PM in reply to: *Johnson, Paul
Paul,
Are you running AdLM Admin on the license server or on a remote system? You
must run AdLM Admin on the system AdLM is to run on.
If you are running AdLM Admin locally, here are a few other things to look
at:
Reapply the service pack and try again
If the above does not help, get the latest driver for your network adapter
from the manufacturer, remove the TCP/IP protocol, apply the new driver,
install and configure TCP/IP and reinstall the service pack again.
jerry milana,
Autodesk Product Support
news:93CA2EE6F60AC4F66A9ED900E0CB48B0@in.WebX.SaUCah8kaAW...
message
> > Paul,
you
run
> > Simon Gillis
license
> > > manager (TCP/IP)
> > > it has 48 mb RAM
> > > 2 GB Hard Drive
> > > Windows 2000 SP1
2000i
> CD
> > > No Modem
> > > only one NIC card
> > > etc.......
> > > Please help
> > > Paul Johnson
> > > 630-820-1022 Voice
> > > 630-820-0350 Fax
*Johnson, Paul
Message 10 of 11 (114 Views)
Solved my ADLM on Win2000
01-10-2001 01:10 AM in reply to: *Johnson, Paul
I had unchecked "File and Printer Sharing for Microsoft Networks"
per Scott's Suggestion
You you need to enable file sharing, and the Administrator needs to log in
and have a profile in order to store the ADLM info correctly in the
registry.
I enabled "File and Print sharing" and IT WORKS !!!!!!!
message
> > Paul,
you
run
> > Simon Gillis
license
> > > manager (TCP/IP)
> > > it has 48 mb RAM
> > > 2 GB Hard Drive
> > > Windows 2000 SP1
2000i
> CD
> > > No Modem
> > > only one NIC card
> > > etc.......
> > > Please help
> > > Paul Johnson
> > > 630-820-1022 Voice
> > > 630-820-0350 Fax
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
